spi发送不了,亲们,帮我看看
xinjitmzy-34588 提问时间:2012-12-19 14:54 /
     SPI_InitTypeDef SPI_InitStructure;
    /* SPI2 Periph clocks enable */
    RCC_APB1PeriphClockCmd (RCC_APB1Periph_SPI2, ENABLE);
    /* GPIOB clock enable */
    RCC_APB2PeriphClockCmd (RCC_APB2Periph_GPIOB| RCC_APB2Periph_AFIO, ENABLE);
    /* SCK, MISO and MOSI PB13=CLK,PB14=MISO,PB15=MOSI*/
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15;
    /* PB12 作片选*/
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
    GPIO_SetBits(GPIOB, GPIO_Pin_12); //预置为高
    /* SPI1 configuration */
    SPI_Cmd(SPI2, DISABLE);                                             //必须先禁能,才能改变MODE
    SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;  //两线全双工
    SPI_InitStructure.SPI_Mode = SPI_Mode_Master;       //主
    SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;      //8位
    SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;         //CPOL=0 时钟悬空低
    SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge;       //CPHA=0 数据捕获第1个
    SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;        //软件NSS
    SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_4;  //4分频=9M < 25M (LOW READ)
    SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;      //高位在前
    SPI_InitStructure.SPI_CRCPolynomial = 7;
    SPI_Init(SPI2, &SPI_InitStructure);
    SPI_Cmd(SPI2, ENABLE);
这是简单的配置
然后发送字节这样
uint8_t SPI_SendByte(uint8_t data)
  while((SPI2->SR & SPI_I2S_FLAG_TXE)==RESET);  /*等待发送寄存器空*/
  SPI2->DR = data;                              /*发送一个字节*/
  while((SPI2->SR & SPI_I2S_FLAG_RXNE)==RESET); /* 等待接收寄存器有效*/
  return(SPI2->DR);
然后测试发送的时候,用示波器总是看不到波波、
收藏 评论2 发布时间:2012-12-19 14:54
xinjitmzy-34588 回答时间:2012-12-19 15:43:35
回复:spi发送不了,亲们,帮我看看
大侠们帮我瞅瞅啊
xinjitmzy-34588 回答时间:2012-12-20 09:28:12
回复:spi发送不了,亲们,帮我看看
顶一下,求大虾们帮我看看
关于意法半导体
招聘信息
