主函数代码如下 int main(void) { /*!< At this stage the microcontroller clock setting is already configured, this is done through SystemInit() function which is called from startup file (startup_stm32f10x_xx.s) before to branch to application main. To reconfigure the default setting of SystemInit() function, refer to system_stm32f10x.c file */ u16 i, len, c2len; u16 x; u16 y; u8 c[] = "www.armjishu.com"; u8 c2[] = "TFT LCD 320X240"; u8 *str; u16 charColor; u16 bkColor; len = sizeof(c)-1; c2len = sizeof(c2)-1; /* USARTx configured as follow: - BaudRate = 115200 baud - Word Length = 8 Bits - One Stop Bit - No parity - Hardware flow control disabled (RTS and CTS signals) - Receive and transmit enabled */ USART_InitStructure.USART_BaudRate = 115200; USART_InitStructure.USART_WordLength = USART_WordLength_8b; USART_InitStructure.USART_StopBits = USART_StopBits_1; USART_InitStructure.USART_Parity = USART_Parity_No; USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; STM_EVAL_COMInit(COM1, &USART_InitStructure); /* Output a message on Hyperterminal using printf function */ printf("\n\rUSART Printf Example: retarget the C library printf function to the USART\n\r"); printf("\r\n\n\n WWW.ARMJISHU.COM %s configured....", EVAL_COM1_STR); printf("\n\r ############ WWW.ARMJISHU.COM! ############ ("__DATE__ " - " __TIME__ ")"); printf("\r\n"); printf(" _____ _______ __ __ ____ ___ ______ __ ___\r\n"); printf(" / ____|__ __| \\/ |___ \\__ \\| ____/_ |/ _ \\\r\n"); printf("| (___ | | | \\ / | __) | ) | |__ | | | | |_ __\r\n"); printf(" \\___ \\ | | | |\\/| ||__ < / /| __| | | | | \\ \\/ /\r\n"); printf(" ____) | | | | | | |___) / /_| | | | |_| |> |
RE:stm32TFT彩屏显示问题
RE:stm32TFT彩屏显示问题
回复:stm32TFT彩屏显示问题
慢慢 缩小包围圈,看问题出在哪?
就是那个printf函数那块,原来做串口的时候它工作就不正常。我做个彩屏,要USART串口功能干嘛,我把它注释掉,彩屏就不好使,不知道什么原因呢
RE:stm32TFT彩屏显示问题
回复:stm32TFT彩屏显示问题
要找原因,可以慢慢地注释掉不需要的,步子不要太大;(要不,留着串口输出也没什么大碍,需要的时候还可以用用 )
回复:stm32TFT彩屏显示问题
