#include "stm32f10x.h" GPIO_InitTypeDef GPIO_InitStructure; NVIC_InitTypeDef NVIC_InitStructure; EXTI_InitTypeDef EXTI_InitStructure; void LED_Init(void) { /* GPIOD Periph clock enable */ RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD, ENABLE); /* Configure PD6 and PD13 in output pushpull mode */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_13; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; GPIO_Init(GPIOD, &GPIO_InitStructure); /*GPIOC Periph clock enable*/ RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7; //choose gpio pin GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz; //set gpio speed GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //set gpio mode GPIO_Init(GPIOC, &GPIO_InitStructure); //initial gpio port } void GPIO_EXTIConfigration(void) { //GPIOE Periph clock enable RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOE, ENABLE); //set pe2 pe3 pe4 pe5 input mode GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2 | GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_5; // GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; GPIO_Init(GPIOE, &GPIO_InitStructure); //initial gpio port /* ENABLE AFIO CLOCK */ RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE); /* connect gpio to exti */ GPIO_EXTILineConfig(GPIO_PortSourceGPIOE, GPIO_PinSource2); GPIO_EXTILineConfig(GPIO_PortSourceGPIOE, GPIO_PinSource3); GPIO_EXTILineConfig(GPIO_PortSourceGPIOE, GPIO_PinSource4); GPIO_EXTILineConfig(GPIO_PortSourceGPIOE, GPIO_PinSource5); // config EXTI initial EXTI_InitStructure.EXTI_Line = EXTI_Line2|EXTI_Line3|EXTI_Line4|EXTI_Line5; EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt; EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling; EXTI_InitStructure.EXTI_LineCmd = ENABLE; EXTI_Init(&EXTI_InitStructure); } void NVIC_Configration(void) { NVIC_SetVectorTable(NVIC_VectTab_FLASH,0x0); //system default NVIC VECTTAB TO FLASH, so needn't NVIC_InitStructure.NVIC_IRQChannel = EXTI2_IRQn|EXTI3_IRQn|EXTI4_IRQn|EXTI9_5_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x0f ; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x0f; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); } void main() { LED_Init(); GPIO_EXTIConfigration(); NVIC_Configration(); while(1) { ; } } 中断子程序: /* * * * * */ void EXTI2_IRQHandler(void) { if( (EXTI_GetITStatus(EXTI_Line2))!=0 ) { GPIOD->BSRR = 0x00000040; EXTI_ClearITPendingBit(EXTI_Line2); } } /* * * * * */ void EXTI3_IRQHandler(void) { if( (EXTI_GetITStatus(EXTI_Line3))!=0 ) { GPIOD->BSRR = 0x00002000; EXTI_ClearITPendingBit(EXTI_Line3); } } /* * * * * */ void EXTI4_IRQHandler(void) { if( (EXTI_GetITStatus(EXTI_Line4))!=0 ) { GPIOC->BSRR = 0x00000080; EXTI_ClearITPendingBit(EXTI_Line4); } } /* * * * * */ void EXTI9_5_IRQHandler(void) { if( (EXTI_GetITStatus(EXTI_Line5))!=0 ) { GPIOC->BSRR = 0x00000040; EXTI_ClearITPendingBit(EXTI_Line5); } } 利用开发板仿真的时候可以看到对应的peng = 1,却进不了中断程序,请前辈帮忙指点 |
RE:STM32 EXTI外部中断进不了中断程序,指高手指点
还是先看看STM32权威指南
几个EXTI中断同时初始化的时候出错,
只要分开初始化就可以啦!
