void init_Gpio()//初始化 GPIO口 使用的是AE 两个口 { RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOE, ENABLE); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_All; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT; GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL; GPIO_Init(GPIOE, &GPIO_InitStructure); RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5 |GPIO_Pin_4 |GPIO_Pin_3 |GPIO_Pin_2 |GPIO_Pin_1 |GPIO_Pin_0; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT; GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL; GPIO_Init(GPIOA, &GPIO_InitStructure); } #define uint unsigned int #define uchar unsigned char 采用的宏定义 的方法 来实现程序函数的 #define LCD_RD0 GPIO_ResetBits(GPIOA,GPIO_Pin_0) #define LCD_WR0 GPIO_ResetBits(GPIOA,GPIO_Pin_1) #define LCD_RS0 GPIO_ResetBits(GPIOA,GPIO_Pin_2) #define LCD_CS0 GPIO_ResetBits(GPIOA,GPIO_Pin_3) #define LCD_REST0 GPIO_ResetBits(GPIOA,GPIO_Pin_4) #define LCD_RD1 GPIO_SetBits(GPIOA,GPIO_Pin_0) #define LCD_WR1 GPIO_SetBits(GPIOA,GPIO_Pin_1) #define LCD_RS1 GPIO_SetBits(GPIOA,GPIO_Pin_2) #define LCD_CS1 GPIO_SetBits(GPIOA,GPIO_Pin_3) #define LCD_REST1 GPIO_SetBits(GPIOA,GPIO_Pin_4) void delayms(int count) // /* X1ms */ { int i,j; for(i=0;i8,x1); //??X LCD_Write_COM(0x00,0x52);LCD_Write_DATA(y1>>8,y1); //??Y LCD_Write_COM(0x00,0x51);LCD_Write_DATA(x2>>8,x2); //??X LCD_Write_COM(0x00,0x53);LCD_Write_DATA(y2>>8,y2); //??Y LCD_Write_COM(0x00,0x22); } LCD的初始化 移植的函数 自己写比较麻烦的 void LCD_Init(void) { LCD_REST1; delayms(5); LCD_REST0; delayms(5); LCD_REST1; LCD_CS1; LCD_RD1; LCD_WR1; delayms(5); LCD_CS0; //?????? //************* Start Initial Sequence **********// LCD_Write_COM(0x00,0xE5); LCD_Write_DATA(0x78,0xF0); // set SRAM internal timing LCD_Write_COM(0x00,0x01); LCD_Write_DATA(0x01,0x00); // set SS and SM bit LCD_Write_COM(0x00,0x02); LCD_Write_DATA(0x07,0x00); // set 1 line inversion LCD_Write_COM(0x00,0x03); LCD_Write_DATA(0x10,0x30); // set GRAM write direction and BGR=1. LCD_Write_COM(0x00,0x04); LCD_Write_DATA(0x00,0x00); // Resize register LCD_Write_COM(0x00,0x08); LCD_Write_DATA(0x02,0x07); // set the back porch and front porch LCD_Write_COM(0x00,0x09); LCD_Write_DATA(0x00,0x00); // set non-display area refresh cycle ISC[3:0] LCD_Write_COM(0x00,0x0A); LCD_Write_DATA(0x00,0x00); // FMARK function LCD_Write_COM(0x00,0x0C); LCD_Write_DATA(0x00,0x00); // RGB interface setting LCD_Write_COM(0x00,0x0D); LCD_Write_DATA(0x00,0x00); // Frame marker Position LCD_Write_COM(0x00,0x0F); LCD_Write_DATA(0x00,0x00); // RGB interface polarity //*************Power On sequence ****************// LCD_Write_COM(0x00,0x10); LCD_Write_DATA(0x00,0x00); // SAP, BT[3:0], AP, DSTB, SLP, STB LCD_Write_COM(0x00,0x11); LCD_Write_DATA(0x00,0x07); // DC1[2:0], DC0[2:0], VC[2:0] LCD_Write_COM(0x00,0x12); LCD_Write_DATA(0x00,0x00); // VREG1OUT voltage LCD_Write_COM(0x00,0x13); LCD_Write_DATA(0x00,0x00); // VDV[4:0] for VCOM amplitude LCD_Write_COM(0x00,0x07); LCD_Write_DATA(0x00,0x01); delayms(50); // Dis-charge capacitor power voltage LCD_Write_COM(0x00,0x10); LCD_Write_DATA(0x10,0x90); // 1490//SAP, BT[3:0], AP, DSTB, SLP, STB LCD_Write_COM(0x00,0x11); LCD_Write_DATA(0x02,0x27); // DC1[2:0], DC0[2:0], VC[2:0] delayms(50); // Delay 50ms LCD_Write_COM(0x00,0x12); LCD_Write_DATA(0x00,0x1F); //001C// Internal reference voltage= Vci; delayms(50); // Delay 50ms LCD_Write_COM(0x00,0x13); LCD_Write_DATA(0x15,0x00); //0x1000//1400 Set VDV[4:0] for VCOM amplitude 1A00 LCD_Write_COM(0x00,0x29); LCD_Write_DATA(0x00,0x27); //0x0012 //001a Set VCM[5:0] for VCOMH //0x0025 0034 LCD_Write_COM(0x00,0x2B); LCD_Write_DATA(0x00,0x0D); // Set Frame Rate 000C delayms(50); // Delay 50ms LCD_Write_COM(0x00,0x20); LCD_Write_DATA(0x00,0x00); // GRAM horizontal Address LCD_Write_COM(0x00,0x21); LCD_Write_DATA(0x00,0x00); // GRAM Vertical Address // ----------- Adjust the Gamma Curve ----------// LCD_Write_COM(0x00,0x30); LCD_Write_DATA(0x00,0x00); LCD_Write_COM(0x00,0x31); LCD_Write_DATA(0x07,0x07); LCD_Write_COM(0x00,0x32); LCD_Write_DATA(0x03,0x07); LCD_Write_COM(0x00,0x35); LCD_Write_DATA(0x02,0x00); LCD_Write_COM(0x00,0x36); LCD_Write_DATA(0x00,0x08);//0207 LCD_Write_COM(0x00,0x37); LCD_Write_DATA(0x00,0x04);//0306 LCD_Write_COM(0x00,0x38); LCD_Write_DATA(0x00,0x00);//0102 LCD_Write_COM(0x00,0x39); LCD_Write_DATA(0x07,0x07);//0707 LCD_Write_COM(0x00,0x3C); LCD_Write_DATA(0x00,0x02);//0702 LCD_Write_COM(0x00,0x3D); LCD_Write_DATA(0x1D,0x04);//1604 //------------------ Set GRAM area ---------------// LCD_Write_COM(0x00,0x50); LCD_Write_DATA(0x00,0x00); // Horizontal GRAM Start Address LCD_Write_COM(0x00,0x51); LCD_Write_DATA(0x00,0xEF); // Horizontal GRAM End Address LCD_Write_COM(0x00,0x52); LCD_Write_DATA(0x00,0x00); // Vertical GRAM Start Address LCD_Write_COM(0x00,0x53); LCD_Write_DATA(0x01,0x3F); // Vertical GRAM Start Address LCD_Write_COM(0x00,0x60); LCD_Write_DATA(0xA7,0x00); // Gate Scan Line LCD_Write_COM(0x00,0x61); LCD_Write_DATA(0x00,0x01); // NDL,VLE, REV LCD_Write_COM(0x00,0x6A); LCD_Write_DATA(0x00,0x00); // set scrolling line //-------------- Partial Display Control ---------// LCD_Write_COM(0x00,0x80); LCD_Write_DATA(0x00,0x00); LCD_Write_COM(0x00,0x81); LCD_Write_DATA(0x00,0x00); LCD_Write_COM(0x00,0x82); LCD_Write_DATA(0x00,0x00); LCD_Write_COM(0x00,0x83); LCD_Write_DATA(0x00,0x00); LCD_Write_COM(0x00,0x84); LCD_Write_DATA(0x00,0x00); LCD_Write_COM(0x00,0x85); LCD_Write_DATA(0x00,0x00); //-------------- Panel Control -------------------// LCD_Write_COM(0x00,0x90); LCD_Write_DATA(0x00,0x10); LCD_Write_COM(0x00,0x92); LCD_Write_DATA(0x06,0x00); LCD_Write_COM(0x00,0x07); LCD_Write_DATA(0x01,0x33); // 262K color and display ON LCD_CS1; //?????? } 刷屏使用的函数 void Pant(char VH,char VL) { int i,j; LCD_CS0; //?????? Address_set(0,0,240,320); <span style="color: rgb(34, 34, 34); font-family: sans-serif; font-size: 14px; line-height: 21px; background-color: rgb(238, 238, 238); "> for(i=0;i |
RE:stm32f3的TFT的汉字
