#include "stm32f30x.h" #include "stm32f3_discovery_lsm303dlhc.h" #define uchar unsigned char #define uint unsigned int uchar ge,shi,bai,qian,wan,shiwan; //???? unsigned char Buffer[6]; unsigned char XOffset; unsigned char YOffset; static void USART_Config(void) { USART_InitTypeDef USART_InitStructure; GPIO_InitTypeDef GPIO_InitStructure; /* Enable GPIOD clock */ RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOC|RCC_AHBPeriph_GPIOE , ENABLE); /* Enable USART1 APB clock */ RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE); /* Configure the HSI as USART clock */ RCC_USARTCLKConfig(RCC_USART1CLK_HSI); /* USART1 Pins configuration ***********************************************/ /* Connect pin to Periph */ GPIO_PinAFConfig(GPIOC, GPIO_PinSource4, GPIO_AF_7); GPIO_PinAFConfig(GPIOE, GPIO_PinSource1, GPIO_AF_7); /* Configure pins as AF pushpull */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL; GPIO_Init(GPIOC, &GPIO_InitStructure); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1; GPIO_Init(GPIOE, &GPIO_InitStructure); /* USARTx configured as follow: - BaudRate = 115200 baud - Word Length = 8 Bits - Stop Bit = 1 Stop Bit - Parity = No Parity - Hardware flow control disabled (RTS and CTS signals) - Receive and transmit enabled */ USART_DeInit(USART1); USART_InitStructure.USART_BaudRate = 115200; USART_InitStructure.USART_WordLength = USART_WordLength_8b; USART_InitStructure.USART_StopBits = USART_StopBits_1; USART_InitStructure.USART_Parity = USART_Parity_No; USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; USART_Init(USART1, &USART_InitStructure); /* Enable USART1 */ USART_Cmd(USART1, ENABLE); /* Before entering the USART in STOP mode the REACK flag must be checked to ensure the USART RX is ready */ while(USART_GetFlagStatus(USART1, USART_FLAG_REACK) == RESET) {} /* Enable USART STOP mode by setting the UESM bit in the CR1 register.*/ // USART_STOPModeCmd(USART1, ENABLE); /* Enable the wake up from stop Interrupt */ // USART_ITConfig(USART1, USART_IT_WU, ENABLE); /* Enter USART in STOP mode with regulator in low power mode */ // PWR_EnterSTOPMode(PWR_Regulator_LowPower, PWR_STOPEntry_WFI); } void conversion(long temp_data) { shiwan=temp_data/100000+0x30 ; temp_data=temp_data%100000; //???? wan=temp_data/10000+0x30 ; temp_data=temp_data%10000; //???? qian=temp_data/1000+0x30 ; temp_data=temp_data%1000; //???? bai=temp_data/100+0x30 ; temp_data=temp_data%100; //???? shi=temp_data/10+0x30 ; temp_data=temp_data%10; //???? ge=temp_data+0x30; } void Delayms(vu32 m) { u32 i; for(; m != 0; m--) for (i=0; i |
RE:STm32F3的MEMS的测试
