stm32f0编程,一打开ADC时钟,TIM3的中断就不起作用了
^ 等待 永恒...^ 提问时间:2013-4-7 19:51 /
下面是我的程序,请大神们帮忙看看,新手刚刚开始学。。
  * @brief  Configure the TIM3 IRQ Handler.
  * @param  None
  * @retval None
static __IO uint16_t PrescalerValue_TIM3=48;
void TIM3_Config(void)
  /* TIM3 clock enable */
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);
  /* Enable the TIM3 gloabal Interrupt */
  NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelPriority = 1;
        /* Configuration of TIM3 */
        TIM_InternalClockConfig(TIM3);      //use internal clock
        TIM_TimeBaseInit(TIM3,TIM_TimeBaseInitStruct);
        TIM_PrescalerConfig(TIM3,PrescalerValue_TIM3,0);
        TIM_CounterModeConfig(TIM3,TIM_CounterMode_Up);
        TIM_SetCounter(TIM3,0);
        TIM_SetAutoreload(TIM3,1000);
        TIM_ITConfig(TIM3,TIM_IT_Update,ENABLE);
  * @brief  Configure the ADC.
  * @param  None
  * @retval None
void ADC_Config(void)
        ADC_InitTypeDef ADC_InitStructure;
        /* ADC1 Periph clock enable */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);
        /* Configure the ADC1 in continous mode withe a resolutuion equal to 12 bits*/
  ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;
  ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
  ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None;
  ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
  ADC_InitStructure.ADC_ScanDirection = ADC_ScanDirection_Upward;
  ADC_Init(ADC1, &ADC_InitStructure);
  /* Convert the ADC1 Channel 11 with 239.5 Cycles as sampling time */
  ADC_ChannelConfig(ADC1, ADC_Channel_0 , ADC_SampleTime_239_5Cycles);
        ADC_ChannelConfig(ADC1, ADC_Channel_1 , ADC_SampleTime_239_5Cycles);
        /* ADC Calibration */
  ADC_GetCalibrationFactor(ADC1);
  /* Enable the auto delay feature */
  ADC_WaitModeCmd(ADC1, ENABLE);
  /* Enable the Auto power off mode */
  ADC_AutoPowerOffCmd(ADC1, ENABLE);
  /* Enable ADCperipheral[PerIdx] */
  ADC_Cmd(ADC1, ENABLE);
        /* Wait the ADCEN flag */
  while(!ADC_GetFlagStatus(ADC1, ADC_FLAG_ADEN));
        /* ADC1 regular Software Start Conversion */
  ADC_StartOfConversion(ADC1);
  * @brief  Main program
  * @param  None
  * @retval None
static __IO uint16_t ADC1ConvertedValue = 0;
static __IO float ADC1ConvertedVoltage = 0.0;
int main(void)
        /* Initialize Leds mounted on STM32F0-discovery */
        STM_EVAL_LEDInit(LED3);
  STM_EVAL_LEDInit(LED4);
        STM_EVAL_PWMInit(PWM1);
        STM_EVAL_ADInit(AD0);
        STM_EVAL_ADInit(AD1);
        /* Initialize User_Button on STM32F0-Discovery */
  STM_EVAL_PBInit(BUTTON_USER, BUTTON_MODE_GPIO);
        /* TIM Configuration */
        TIM2_Config();
  TIM3_Config();
        /* ADC Configuration */
        ADC_Config();
        /* Setup SysTick Timer for 1 msec interrupts */
        if(SysTick_Config(SystemCoreClock / 1000))
    while (1);
        /* Infinite loop */
        while(1)
                key_LED3();
                //if(sign_instant[5]==1)
                        //sign_instant[5]=0;
                        /* Get ADC1 converted data */
                        //ADC1ConvertedValue = ADC_GetConversionValue(ADC1);
                        /* Compute the voltage */
                        //ADC1ConvertedVoltage = (ADC1ConvertedValue*3.3)/0xFFF;
下面是我ADC的GPIO口初始化的程序
#define ADn                                                2
#define AD0_PIN                                        GPIO_Pin_0
#define AD0_GPIO_PORT                GPIOA
#define AD0_GPIO_CLK                    RCC_AHBPeriph_GPIOA
#define AD1_PIN                                        GPIO_Pin_1
#define AD1_GPIO_PORT                 GPIOA
#define AD1_GPIO_CLK                     RCC_AHBPeriph_GPIOA
GPIO_TypeDef* AD_PORT[ADn] = {AD0_GPIO_PORT, AD1_GPIO_PORT};
const uint16_t AD_PIN[ADn] = {AD0_PIN, AD1_PIN};
const uint32_t AD_CLK[ADn] = {AD0_GPIO_CLK, AD1_GPIO_CLK};
void STM_EVAL_ADInit(AD_TypeDef ad)
  /* GPIOA Clocks enable */
  RCC_AHBPeriphClockCmd(AD_CLK[ad], ENABLE);
  /* GPIOA Configuration: Channel 1 as alternate function push-pull */
  GPIO_InitStructure.GPIO_Pin = AD_PIN[ad];
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN;
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
  GPIO_Init(AD_PORT[ad], &GPIO_InitStructure);
赞 收藏 评论2 发布时间:2013-4-7 19:51
^ 等待 永恒...^ 回答时间:2013-4-7 19:55:20
RE:stm32f0编程,一打开ADC时钟,TIM3的中断就不起作用了
我现在就是把
这条指令双斜杠了,就TIM3的中断就正常了
^ 等待 永恒...^ 回答时间:2013-4-9 20:07:33
求解答。。。。。。
