加220时两路电流采样数据完全不对 但母线电压很准 单15v电源供电时加电位器采样很准 不知道是怎么回事 求各位大神帮帮忙!! #include #include "stm32f4_discovery.h" /* ADC_DMA2 Macro */ #define ADC1_DR_ADDRESS ((uint32_t)0x4001204C) #define ADC2_DR_ADDRESS ((uint32_t)0x4001214C) /*** Private Structures define ***/ #include ADC_InitTypeDef ADC_InitStructure; ADC_CommonInitTypeDef ADC_CommonInitStructure; DMA_InitTypeDef DMA_InitStructure; /* Private variables */ extern uint16_t ADC1ConvertedValue[4]; extern uint16_t ADC2ConvertedValue[4]; /* ADCs configuration: triple interleaved with 5cycles delay to reach 6Msps */ void ADC_Common_Configuration(void) { /************************ ADC Common configuration **************************/ ADC_CommonInitStructure.ADC_Mode = ADC_Mode_Independent; ADC_CommonInitStructure.ADC_TwoSamplingDelay = ADC_TwoSamplingDelay_5Cycles; ADC_CommonInitStructure.ADC_DMAAccessMode = ADC_DMAAccessMode_2; ADC_CommonInitStructure.ADC_Prescaler = ADC_Prescaler_Div2; ADC_CommonInit(&ADC_CommonInitStructure); } /*****************ADC1 Configuration****************/ /* Use The Channel 0,3,6,8,9,10,12,13 To Convert */ void ADC1_Configuration(void) { /* ENABLE The ADC Clock */ RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2, ENABLE); // RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE); ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b; ADC_InitStructure.ADC_ScanConvMode = ENABLE; ADC_InitStructure.ADC_ContinuousConvMode = ENABLE; ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None; ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_T1_CC1; ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right; ADC_InitStructure.ADC_NbrOfConversion = 3;// ADC_Init(ADC1, &ADC_InitStructure); /**************以上是ADC_Init函数,还要指定通道转换顺序,采样时间等************/ /* ADC1 规则通道12(Channel 12)配置 */ ADC_RegularChannelConfig(ADC1, ADC_Channel_12, 1, ADC_SampleTime_3Cycles);// ADC_RegularChannelConfig(ADC1, ADC_Channel_13, 2, ADC_SampleTime_3Cycles);// ADC_RegularChannelConfig(ADC1, ADC_Channel_10, 3, ADC_SampleTime_3Cycles);// // ADC_RegularChannelConfig(ADC1, ADC_Channel_8, 4, ADC_SampleTime_3Cycles);// ADC_DMARequestAfterLastTransferCmd(ADC1, ENABLE); /* Enable ADC1 DMA */ ADC_DMACmd(ADC1, ENABLE); /* Enable ADC1 */ ADC_Cmd(ADC1, ENABLE); /* Start ADC1 Software Conversion */ ADC_SoftwareStartConv(ADC1); //ADC_ITConfig(ADC1, ADC_IT_AWD, ENABLE); //ADC_ClearFlag(ADC1, ADC_FLAG_JEOC); //ADC_SoftwareStartInjectedConv(ADC1); } /* DMA2_Stream0 Configuration */ void DMA2_Configuration(void) { /* ENABLE The DMA Clock */ RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2, ENABLE); //打开DMA2时钟 DMA_DeInit(DMA2_Stream0); /* DMA2 Stream 0 channel 0 configuration */ DMA_InitStructure.DMA_Channel = DMA_Channel_0; DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)ADC1_DR_ADDRESS; DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)&ADC1ConvertedValue; DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory; DMA_InitStructure.DMA_BufferSize = 3; DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable; DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable; DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord; DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord; DMA_InitStructure.DMA_Mode = DMA_Mode_Circular; DMA_InitStructure.DMA_Priority = DMA_Priority_High; DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable; DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull; DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single; DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single; DMA_Init(DMA2_Stream0, &DMA_InitStructure); /* DMA2_Stream0 enable */ DMA_Cmd(DMA2_Stream0, ENABLE); } |
RE:stm32f407 上电后电流采不准 母线电压采样很准
