关于stm32f407 I2s DMA的主发送问题
YLee 提问时间:2013-6-28 15:24 /
 最近用stm32f407做一个sd卡mp3解码后,音频传输的项目,声卡芯片用的VM8978,采取的是SPI3的i2s,用的DMA是DMA1的stream5通道0.用的是主发送模式
在dma中断中我用一个led反转看是否进入中断,结果是,中断进入,但i2s 引脚为何没有输出,按道理说应该是有波形输出的啊 BCLk脚怎么一直是低电平了?
新手,求各位大侠赐教!!
程序如下:
DMA_InitTypeDef DMA_InitStructure;
u32 AudioTotalSize = 0xffff;
u32 AudioRemSize = 0;
u16 *CurrentPos;
extern void AUDIO_TransferComplete(u32 pBuffer, uint32_t Size);
void AUDIO_Init(u32 AudioFreq)
        Audio_I2S_Init(AudioFreq);
        I2S_GPIO_Init();
        Audio_DMA_Init();
void I2s_GPIO_DEinit(void)
          RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB, ENABLE);
          RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE);
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN;
    GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
    /* I2S3S_WS */
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_15;
    /* I2S3_CK, I2S3_SD, I2S3ext_SD */
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_5;
void I2S_GPIO_Init(void)
                I2s_GPIO_DEinit();
    /* Connect pins to I2S peripheral  */
    GPIO_PinAFConfig(GPIOA, GPIO_PinSource15, GPIO_AF_SPI3);
    GPIO_PinAFConfig(GPIOB, GPIO_PinSource3, GPIO_AF_SPI3);
    GPIO_PinAFConfig(GPIOB, GPIO_PinSource4, GPIO_AF_I2S3ext);
    GPIO_PinAFConfig(GPIOB, GPIO_PinSource5, GPIO_AF_SPI3);
    /* I2S3S_WS */
void Audio_I2S_Init(uint32_t AudioFreq)
          I2S_InitTypeDef I2S_InitStructure;
                SPI_I2S_DeInit(SPI3);
          RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI3, ENABLE);
          I2S_InitStructure.I2S_AudioFreq = AudioFreq;
          I2S_InitStructure.I2S_Standard = I2S_Standard_Phillips;
          I2S_InitStructure.I2S_DataFormat = I2S_DataFormat_16b;
          I2S_InitStructure.I2S_CPOL = I2S_CPOL_Low;
          I2S_InitStructure.I2S_Mode = I2S_Mode_MasterTx;
          I2S_InitStructure.I2S_MCLKOutput = I2S_MCLKOutput_Disable;
          I2S_Init(SPI3, &I2S_InitStructure);
//DMA传送配置
void Audio_DMA_Init(void)
          RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA1, ENABLE);
          DMA_Cmd(DMA1_Stream5, DISABLE);
          DMA_DeInit(DMA1_Stream5);
          DMA_InitStructure.DMA_Channel = DMA_Channel_0;
          DMA_InitStructure.DMA_PeripheralBaseAddr = 0x4000380C;
          DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)0;//该项将在播放函数中进行配置
          DMA_InitStructure.DMA_DIR = DMA_DIR_MemoryToPeripheral;
          DMA_InitStructure.DMA_BufferSize = (uint32_t)0xFFFE;//该项将在播放函数中进行配置
          DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
          DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
          DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
          DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
          DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;
          DMA_InitStructure.DMA_Priority = DMA_Priority_High;
          DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;
          DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_1QuarterFull;
          DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
          DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
          DMA_Init(DMA1_Stream5, &DMA_InitStructure);
          DMA_ITConfig(DMA1_Stream5, DMA_IT_TC, ENABLE);//使能所选DMA的中断
          //I2S DMA中断通道配置
          NVIC_InitStructure.NVIC_IRQChannel = DMA1_Stream5_IRQn;
          NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;//抢占优先级(0 最高)
          NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;//子优先级(0 最高)
          SPI_I2S_DMACmd(SPI3, SPI_I2S_DMAReq_Tx, ENABLE);//中断请求使能
//开始从特定大小(Size)的缓冲区(pBuffer)中播放音频流
uint32_t AUDIO_Play(u16* pBuffer, u32 Size)
          AudioTotalSize=Size;
          Audio_MAL_Play((u32)pBuffer,(u32)(DMA_MAX(Size/4)));//更新媒体层数据并播放
          AudioRemSize=(Size/2)-DMA_MAX(AudioTotalSize);//更新剩余数据量
          CurrentPos=pBuffer+DMA_MAX(AudioTotalSize);//更新当新数据指针
          return 0;
//开始播放媒体中的音频流
void Audio_MAL_Play(u32 Addr, u32 Size)
          DMA_InitStructure.DMA_Memory0BaseAddr=(uint32_t)Addr;//配置缓冲区地址和大小
          DMA_InitStructure.DMA_BufferSize=(uint32_t)Size/2;
          DMA_Init(DMA1_Stream5,&DMA_InitStructure);
          DMA_Cmd(DMA1_Stream5,ENABLE);//I2S DMA使能
          if ((SPI3->I2SCFGR & I2S_ENABLE_MASK)==0)I2S_Cmd(SPI3,ENABLE);//若I2S接口未使能,则使能
//I2S中断处理
void SPI3_IRQHandler(void)
          if (SPI_I2S_GetFlagStatus(SPI3,SPI_I2S_FLAG_TXE)!=RESET)
            SPI_I2S_SendData(SPI3, 0);//发送空字节到I2S
                        SPI_I2S_ClearFlag(SPI3,SPI_I2S_FLAG_TXE);
//DMA中断处理函数
void DMA1_Stream5_IRQHandler(void)
          //传送完成中断
          if (DMA_GetFlagStatus(DMA1_Stream5, DMA_FLAG_TCIF5)!=RESET)
                        if (AudioRemSize>0)//查看是否到达文件尾
                        printf("DMA1\r\n");
                      while (DMA_GetCmdStatus(DMA1_Stream5) != DISABLE) IWDG_ReloadCounter();//等待DMA disabled
                      DMA_ClearFlag(DMA1_Stream5, DMA_FLAG_TCIF5);//清传送完成中断标志
                      DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t) CurrentPos;//重新配置缓冲区地址和大小
                      DMA_InitStructure.DMA_BufferSize = (uint32_t) (DMA_MAX(AudioRemSize));
                      DMA_Cmd(DMA1_Stream5, ENABLE);
                      CurrentPos += DMA_MAX(AudioRemSize);//更新数据指针
                      AudioRemSize -= DMA_MAX(AudioRemSize);//更新剩余数据
            else//已到达文件尾
                      AUDIO_TransferComplete((uint32_t)CurrentPos, 0);
                        STM_EVAL_LEDToggle(2);                                    //led反转 ,显示状态
//                         printf("DMA2\r\n");
        //                                        printf("DMA3\r\n");
收藏 评论1 发布时间:2013-6-28 15:24
shiyang1212 回答时间:2014-3-26 14:58:58
回复:关于stm32f407 I2s DMA的主发送问题
你的程序调试出来了吧??????  我看你的外设地址用的是SPI2的地址啊
意法半导体边缘AI套件
ST - 理想汽车豪华SUV案例
ST意法半导体智能家居案例
STM32 ARM Cortex 32位微控制器
