STM8L10x 中断库函数FunctionalState NewState的问题
cjunrong 提问时间:2013-8-20 20:00 /
 使用STM8L101F3P芯片,用iar库函数,想实现最简单的按键中断,在库里有一函数
void EXTI_SetHalfPortSelection(EXTI_HalfPort_TypeDef EXTI_HalfPort,
                               FunctionalState NewState)
如图所示,
在使用这个函数的时候,EXTI_HalfPort_TypeDef EXTI_HalfPort可以使用上面提供的组合,
例如EXTI_HalfPort_B_LSB
可是FunctionalState NewState这个应该填什么进去呢,说明没有提供,直接填上十六进制数上去也不行,请教大家一下,谢谢...!
下面贴上直接在库里复制出的原函数
  * @brief  Configure the half port interrupt selection.
  * @note   This function must be called once the port sensitivity is configured,
  *          otherwise this function call won't have any effect on the port external interrupt.
  * @param  EXTI_HalfPort The port part  to access (MSB or LSB).
  *          This parameter can be any combination of the following values:
  *            @arg EXTI_HalfPort_B_LSB:     Interrupt selector PB(3:0)
  *            @arg EXTI_HalfPort_B_MSB:     Interrupt selector PB(7:4)
  *            @arg EXTI_HalfPort_D_LSB:     Interrupt selector PE(3:0)
  *            @arg EXTI_HalfPort_D_MSB:     Interrupt selector PE(7:4)
  * @param  NewState  The external interrupt new state.
  * @retval None
  /* Check function parameters */
  assert_param(IS_EXTI_HALFPORT(EXTI_HalfPort));
  assert_param(IS_FUNCTIONAL_STATE(NewState));
  if (NewState != DISABLE)
    EXTI->CONF |= (uint8_t)EXTI_HalfPort; /* Enable port interrupt selector */
  else /*NewState == DISABLE */
    EXTI->CONF &= (uint8_t)(~(uint8_t)EXTI_HalfPort); /* Disable port interrupt selector */
赞 收藏 评论0 发布时间:2013-8-20 20:00
