STM32MED1开发板例程解析(一):多个定时器链接
Cody-2045860 发布时间:2013-10-14 15:59
本例程出自STM32MED1开发板附带光盘,其工程目录路径为:\Code Package\Peripheral Devices\06 TIM\0602_Chaining。
+ ~. T+ r1 _# C) n. ]
- p- T  K5 ?& q0 g本例程是使用TIM3作为TIM4的预分频器。下面代码出自timer.c文件。
$ c! E' g! I: C/ ]1 R1 v' L ) N9 b7 Z# k# O( ^
void TIM3_4_ChainConfig(u16 Period1, u16 Period2)8 P& \6 J. z) q1 p0 @
# n$ ^6 p6 U: V5 P# T  TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;7 y& o  S/ L" t( f
  NVIC_InitTypeDef NVIC_InitStructure;# k- |, g; z9 [& _+ S' T# H
 ( r* J7 L1 P* B; z
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3|
( [; I/ P" N& i2 y% [
1 ~! y6 X: G0 r                                   RCC_APB1Periph_TIM4, ENABLE);   // 1)
- Z& P/ s5 `0 p1 M7 I
3 H3 u, T2 Z' B: B9 O: X5 {" ?  |3 w  TIM_TimeBaseStructure.TIM_Period = Period1;    // 2)
5 n# M" i+ a6 f+ A  TIM_TimeBaseStructure.TIM_Prescaler = (u16)(SystemCoreClock / 1000) - 1;    // 3)
) S) W& u6 m) C- M  TIM_TimeBaseStructure.TIM_ClockDivision = 0;0 Q3 s; X: q% F- v* B* q! A3 m
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;   // 4)8 N2 b1 @# ]4 R. A' l) p5 ~' X# ?
  TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);0 C- O- p. ?' F! p, G- ^% l
" Q' L' W3 n( Y6 g  TIM_TimeBaseStructure.TIM_Period = Period2;    // 5); r) y: J1 ~: i
  TIM_TimeBaseStructure.TIM_Prescaler = 0;4 P0 s0 `9 B5 Q, r9 Q
  TIM_TimeBaseInit(TIM4, &TIM_TimeBaseStructure);
. E' e* M5 a1 O2 s3 P
  P4 g/ a8 |  W  z7 \# p% l  TIM_SelectOutputTrigger(TIM3, TIM_TRGOSource_Update);   // 6)+ D2 X, d4 i* f- c, ?! J/ H
/ a; L9 B( {1 x3 T' s  TIM_SelectSlaveMode(TIM4, TIM_SlaveMode_External1);    // 7)
& T' D& U* q, t5 h  TIM_SelectInputTrigger(TIM4, TIM_TS_ITR2);    // 8)
4 p+ b; l! C3 q* u/ Z4 A
: v* Q- c. G3 B) L; t. b  TIM_ITConfig(TIM4, TIM_IT_Trigger | TIM_IT_Update, ENABLE);    // 9)
0 A, J4 V& p- o  E$ S! K! N  TIM_UpdateRequestConfig(TIM4, TIM_UpdateSource_Global);     // 10)2 y7 s; T: k# u; J
0 a# }; }8 z- ^1 j4 n- {( ]4 g  // (113 e9 j& N- ]" v; J0 S! D/ ?5 F8 E
  NVIC_InitStructure.NVIC_IRQChannel = TIM4_IRQn;# B! x1 u" L9 a
7 c3 ~$ h, c2 l  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 2;4 z! m6 w& [6 H3 k$ |2 r% I! t
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;9 ^! K' ]4 Q0 n; _- Y
  NVIC_Init(&NVIC_InitStructure);/ q$ ?$ n0 o  d
  // 11)
6 q4 H; Y7 q) {" A" X
3 K0 ~' ^2 D9 O. D  TIM_Cmd(TIM4, ENABLE);     // 12)
& U, Y! A* B- `! L) N  TIM_Cmd(TIM3, ENABLE);     // 13)
9 V4 S/ k, _& V7 \2 L; n; ^' X}
3 T4 q2 r0 P% [3 s8 b
$ m1 @3 A7 P! x3 b: Z; X在对定时器的寄存器进行配置前先应通过调用函数RCC_APB1PeriphClockCmd()使能相应定时器的时钟,如代码行1)。代码行2)是设置TIM3的周期,即设置寄存器TIM3_ARR的值。代码行3)是设置TIM3的预分频器值。由于TIM3的从模式控制器被禁止,TIM3预分频器的时钟由内部时钟CK_INT提供。全局变量SystemCoreClock定义于system_stm32f10x.c,如下代码所示:
. @% i4 i- }5 P" v% J
0 E' A7 |$ q0 j2 p5 K8 b5 puint32_t SystemCoreClock = SYSCLK_FREQ_72MHz;
% K, b* S7 |$ m  d/ ]8 k & z7 m: ^4 ~+ [6 S% x* \% e
由此可见,代码行3)将预分频器值设为SystemCoreClock / 2000 – 1,则预分频器的输出时钟CK_CNT=1000Hz,也就是说TIM3的计数器每1ms计数一次。代码行4)将计数器模式设置为向上计数模式。也就是说定时器使能后,计数器将从0开始计数,每1ms计数一次,计数到TIM3_ARR中值时产生更新事件,计数器将重新从0开始计数。代码行5)是设置TIM4计数器的周期,也就是寄存器TIM4_ARR的值。TIM4的预分频器值设为0,计数模式同样是设为向上计数。代码行6)将TIM3的更新事件设为其触发输出源,代码行8)则将TIM3的触发输出选为TIM4的触发输入,即每当TIM3产生一个更新事件,TIM4就将收到一个触发信号。代码行7)是选择TIM4的从模式:外部时钟源模式1,即将TIM4的触发输入脉冲作为TIM4计数器的时钟。这样一来,TIM3将每Period1 ms产生一个更新事件,此时TIM4产生一个触发事件,TIM4的计数器将计数一次,经过(Period1*Period2) ms的时间后,TIM4将产生一个更新事件。代码行9)是开启TIM4的触发及更新中断。代码行10)是指仅当TIM4计数器上溢或下溢时更新事件。代码段11)是配置并开启TIM4的中断通道。代码行12)及代码行13)分别开启TIM4及TIM3。5 b+ n) r1 W. O- H" B
. P. T/ @6 J' S下面是文件stm32f10x_it.c中TIM4的中断处理代码:
! P7 g7 |" z$ h( e0 U0 B 5 ^2 o  ~. e) A$ z8 N2 ~3 Q
void TIM4_IRQHandler(void)
& x. P, Z' A! _* ]# b! `{' z, ~* x6 o4 k! H4 p
  if (TIM_GetITStatus(TIM4, TIM_IT_Trigger) != RESET)  // 1)4 c; P- s  Y8 K' l5 F
  {2 x6 c& K& \; o5 H4 v
    LED_Toggle(LED1);! f" d& B# I0 F; }, ^) t
 ' C0 D5 ?6 i" E
    TIM_ClearITPendingBit(TIM4, TIM_IT_Trigger); ) y2 c+ ^7 ~3 ?: A5 i7 N0 E+ H* k
, m1 K8 s* ^/ B' m; ]0 Y# ]: I
, x' L- U) |# J: W5 S. k  if (TIM_GetITStatus(TIM4, TIM_IT_Update) != RESET)   // 2)7 ~+ f1 ?3 k: H* M9 A# m5 k
/ j1 b. }  [! X# }    LED_Toggle(LED2);. J0 y. p2 p% J% t
# z# _' @6 Z! g, a1 `& @    TIM_ClearITPendingBit(TIM4, TIM_IT_Update);4 }; y& }/ l) w$ }. H
  }. \' I, P) n& N& d- y% P' A
}6 d/ {1 J% Y. r: V0 G& P5 j
 / a* h! w% o& f2 A5 F
代码行1)是判断TIM4是否产生触发中断,若产生了触发中断,则反转开发板上LED1的状态,而后清除该中断的挂起状态位。同理,代码行2)是判断TIM4是否产生更新中断,若是则反转LED2的状态,然后清除中断挂起位。
/ p- x: D* n( k; B& o1 K+ @ 0 T, g8 O8 t, ^" v, P
函数main()位于main.c文件中:
2 \, Q" h2 S7 J& T$ m: O4 E 2 S3 @  z& E( q: o. Z" Z
int main(void)
: C6 i  j& b8 @1 p9 ]  D% _1 e{, J- c% `* O( n1 |: |6 \
  /* Code here configures LEDs on board */+ W! \6 d3 g" Z, o! R  S
 ! Y; W0 q7 C5 J  x! R& V% l' H8 o
  TIM3_4_ChainConfig(1000, 3);          // 1). z9 [$ C8 Q" s" _( l% N. D3 j
& w& S& T2 K  d6 w: Q# O1 F  while (1)5 H8 ^% d/ B* Q" A  s
3 X( {+ t) J3 U  U0 J# }/ q    /* Waiting for interrupts */) j: N  y* W! r0 O/ Q6 c9 e2 N
  }7 G% b* i" b0 m
( m0 r4 k1 v* r 2 k5 F+ G9 t+ B3 d
代码行1)将TIM3的周期设为1000,也就是每秒TIM3将产生一个更新事件,同时TIM4产生一个触发事件,由于TIM4的触发中断已开启,其对应的中断处理代码将得以执行,即LED1的状态将翻转。TIM4的周期设为3,也就是说3秒后,TIM4将产生更新中断,LED2的状态将翻转。9 O  S7 F  ?% e: W
 3 \0 y: b5 q/ `, V3 ~# F
了解更多,请点击访问我们的首页
! j/ l& R. L* e/ h* ?6 c. }, |
4 a: P, ~+ d4 N3 w" Y" p% y, V
赞 收藏 评论0 发布时间:2013-10-14 15:59
