本例程出自STM32MED1开发板附带光盘,其工程目录路径为:\Code Package\Peripheral Devices\06 TIM\0603_PWM_Output。. J. h) z4 H# D; x1 I* E 高级定时器TIM1的通道1位于GPIOA.8引脚,此管脚正好与开发板上LED1相连,这样就可以通过观察LED1亮度变化来判断TIM1的PWM输出波形变化情况。$ N7 k- C) _8 `, P- ]# v 通过调用函数TIM1_PWMOutputConfig()可对TIM1的PWM输出进行配置。其代码定义如下: void TIM1_PWMOutputConfig(u16 Period) {, m6 S2 V; L# W" v TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;2 Z4 S, q5 g) |. D1 G' x GPIO_InitTypeDef GPIO_InitStructure; TIM_OCInitTypeDef TIM_OCInitStructure; NVIC_InitTypeDef NVIC_InitStructure; + i$ C# L1 [, ?# y6 f" { RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_TIM1, ENABLE); // 1) ^9 S0 X, Z, o& I. G) f & g+ L0 [% Y5 t8 m- V- d // (2 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;/ m- }& C: _* q' ^( Z GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;% H* a1 O) l1 G3 c7 L: g GPIO_Init(GPIOA, &GPIO_InitStructure);' b; i, `5 A( F _# O9 u3 W0 X // 2) // (3/ k) ?# n' l. B A9 `% Z- b TIM_TimeBaseStructure.TIM_Period = Period; TIM_TimeBaseStructure.TIM_Prescaler = (u16)(SystemCoreClock / 100000) - 1; TIM_TimeBaseStructure.TIM_ClockDivision = 0;$ O4 z" W; G+ C* |9 o* Q4 c TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;" ]( d2 l. a* J: O/ }8 z0 w TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;) ^9 u2 `6 t& o TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure);( n1 K- C( ?" l2 k4 J* _ // 3)8 v4 v) ~3 K$ |; e% [ // (43 A9 e" L5 Y6 M; ~0 b7 n TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;8 p7 J5 s3 q2 I" K7 C: N TIM_OCInitStructure.TIM_Pulse = 0; l' k: N/ S& o/ I8 n TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;: j1 k3 F$ r9 `+ T0 | TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Disable; TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High; g2 |8 ?: |* @+ P; g TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_High; 4 H; ~- c1 {1 a TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Reset; TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCNIdleState_Reset; TIM_OC1Init(TIM1, &TIM_OCInitStructure); // 4)" T: z( m5 _* a& b/ K | 2 }) Z+ ? O% x6 V5 ` TIM_OC1PreloadConfig(TIM1, TIM_OCPreload_Disable); // 5) 2 i [* Q: t) I# t$ t. \ TIM_ClearFlag(TIM1, TIM_FLAG_Update); // 6)' c; B: ~/ [: C0 e TIM_ITConfig(TIM1, TIM_IT_Update, ENABLE); // 7)6 e0 _9 h5 H$ _$ s+ O$ E8 v# E TIM_UpdateRequestConfig(TIM1, TIM_UpdateSource_Global); // 8) + `3 B" L; r1 s# R+ A l // (9 NVIC_InitStructure.NVIC_IRQChannel = TIM1_UP_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;2 I3 A9 u- t0 a NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); // 9)1 [4 j$ f5 r5 i; F: S4 O) Q# A 7 C j) J- ~5 P7 W0 B TIM_CtrlPWMOutputs(TIM1, ENABLE); // 10)# r! @4 [2 D6 U6 ]7 e) v ! {/ g! ` H$ Q: @ TIM_Cmd(TIM1, ENABLE); // 11) } 代码行1)开启GPIOA及TIM1外设的时钟。代码段2)将PA.8管脚配置为复用推挽输出,因此TIM1产生的PWM信号能输出到PA.8管脚。代码段3)是对TIM1的时间基配置。代码段4)配置TIM1的输出比较通道1,将其配置为PWM模式2;起始寄存器TIM1_CCR1的值设为0;开启OC1的输出状态,关闭OC1的互补输出状态。代码行5)关闭OC1通道的预装载功能,使得每次向捕获/比较寄存器中写入的数据立即生效。代码行6)是清除TIM1的更新标志位。代码行7)是开启TIM1的更新中断,代码行8)将更新事件源限制为计时器的上溢或下溢。代码行9)是对TIM1的中断通道进行初始化。代码行10)是开启TIM1的PWM输出。代码行11)是使能TIM1外设。 当TIM1计数器的值达到最大时就会产生更新中断,其中断处理函数定义如下: void TIM1_UP_IRQHandler(void) {/ f3 m7 u, e! S4 v6 B! S& S if (TIM_GetITStatus(TIM1, TIM_IT_Update) != RESET) { <span style="color: rgb(0, 0, 255);"> if ((CompareValue > PRELOAD_VALUE - INCREMENTS) || (CompareValue |
RE:STM32MED1开发板例程解析(二):定时器的PWM输出
