求助各位高手,STM32F107RC的CAN不能发送数据
sansan-2053108 提问时间:2013-10-31 15:32 /
求助各位高手,STM32F107RC的CAN不能发送数据,我用的振晶是8M的,CAN1发送是第A端口11脚,接收是A端口12脚,现在我没有发现错误,就是不能发送回来,求求各看看是什么原因,
  * @file    CAN/DualCAN/main.c
  * @author  MCD Application Team
  * @version V3.5.0
  * @date    08-April-2011
  * @brief   Main program body
  * @attention
  * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
  * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
  * TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
  * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
  * FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
  * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
  * © COPYRIGHT 2011 STMicroelectronics
/* Includes ------------------------------------------------------------------*/
#include"sys_cfg.h"
#include "stm32f10x.h"
//nclude "platform_config.h"
#define Key_Pressed   0x01
#define Key_NoPressed 0x00
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
CAN_InitTypeDef        CAN_InitStructure;
CAN_FilterInitTypeDef  CAN_FilterInitStructure;
RCC_ClocksTypeDef  RCC_Clocks;
CanTxMsg TxMessage;
uint8_t Key_Pressed_Number = 0x0;
/* Private function prototypes -----------------------------------------------*/
void RCC_Configuration(void);
void GPIO_Configuration(void);
void NVIC_Configuration(void);
void CAN_Config(void);
void LED_Display(uint8_t Ledstatus);
void Init_RxMes(CanRxMsg *RxMessage);
void Delay(void);
/* Private functions ---------------------------------------------------------*/
  * @brief  Main program.
  * @param  None
  * @retval None
int main(void)
  /* Setup STM32 system (clock, PLL and Flash configuration) */
  SystemInit();
  /* System clocks configuration ---------------------------------------------*/
  RCC_Configuration();
  /* GPIO configuration ------------------------------------------------------*/
  GPIO_Configuration();
  /* NVIC configuration ------------------------------------------------------*/
  NVIC_Configuration();
  RCC_GetClocksFreq(&RCC_Clocks);
  /* CAN configuration */
  CAN_Config();
  CAN_ITConfig(CAN1, CAN_IT_FMP0, ENABLE);
  /* Infinite loop */
  while(1)
        TxMessage.Data[0] =0;
        CAN_Transmit(CAN1, &TxMessage);
  * @brief  Configures the different system clocks.
  * @param  None
  * @retval None
  /* GPIO clock enable */
  //RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO | RCC_APB2Periph_GPIOD | RCC_APB2Periph_GPIOB, ENABLE);
// RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO |RCC_APB1Periph_CAN1, ENABLE);
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_CAN1 | RCC_APB1Periph_CAN2, ENABLE);
  /* CAN1 Periph clock enable */
  GPIO_PinRemapConfig(GPIO_Remap2_CAN1 , ENABLE);
  GPIO_PinRemapConfig(GPIO_Remap_CAN2, ENABLE);
  * @brief  Configures the GPIO.
  * @param  None
  * @retval None
  GPIO_InitTypeDef  GPIO_InitStructure;
  /* Configure CAN pin: RX */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;
  /* Configure CAN pin: TX */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13;
  //GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
// GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  * @brief  Configures the NVIC for CAN.
  * @param  None
  * @retval None
  NVIC_InitTypeDef  NVIC_InitStructure;
  NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
  NVIC_InitStructure.NVIC_IRQChannel =CAN1_RX0_IRQn;  //中断函数
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x00;
  NVIC_InitStructure.NVIC_IRQChannel =CAN2_RX0_IRQn;  //发送中断函数
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
// NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  * @brief  Configures the CAN.
  * @param  None
  * @retval None
  /* CAN register init */
  CAN_DeInit(CAN1);
  CAN_StructInit(&CAN_InitStructure);
  /* CAN cell init */
  CAN_InitStructure.CAN_TTCM = DISABLE;
  CAN_InitStructure.CAN_ABOM = DISABLE;
  CAN_InitStructure.CAN_AWUM = DISABLE;
  CAN_InitStructure.CAN_NART = DISABLE;
  CAN_InitStructure.CAN_RFLM = DISABLE;
  CAN_InitStructure.CAN_TXFP = DISABLE;
  CAN_InitStructure.CAN_Mode = CAN_Mode_Normal;
  //CAN_InitStructure.CAN_Mode = CAN_Mode_LoopBack;
  CAN_InitStructure.CAN_SJW = CAN_SJW_1tq;
  CAN_InitStructure.CAN_BS1 = CAN_BS1_3tq;
  CAN_InitStructure.CAN_BS2 = CAN_BS2_5tq;
  CAN_InitStructure.CAN_Prescaler = 4;//2
  CAN_Init(CAN1, &CAN_InitStructure);
/* CAN filter init */
  CAN_FilterInitStructure.CAN_FilterNumber=14;
  CAN_FilterInitStructure.CAN_FilterMode=CAN_FilterMode_IdMask;
  CAN_FilterInitStructure.CAN_FilterScale=CAN_FilterScale_32bit;
  CAN_FilterInitStructure.CAN_FilterIdHigh=0x0000;
  CAN_FilterInitStructure.CAN_FilterIdLow=0x0000;
  CAN_FilterInitStructure.CAN_FilterMaskIdHigh=0x0000;
  CAN_FilterInitStructure.CAN_FilterMaskIdLow=0x0000;
  CAN_FilterInitStructure.CAN_FilterFIFOAssignment=0;
  CAN_FilterInitStructure.CAN_FilterActivation=ENABLE;
  CAN_FilterInit(&CAN_FilterInitStructure);
   /* transmit */
  TxMessage.StdId = 0x321;
  TxMessage.ExtId = 0x01;
  TxMessage.RTR = CAN_RTR_DATA;
  TxMessage.IDE = CAN_ID_STD;
  TxMessage.DLC = 1;
  * @brief  Delay
  * @param  None
  * @retval None
void Delay()
  uint16_t nTime = 0x0000;
    for(nTime =0; nTime StdId = 0x00;
  RxMessage->ExtId = 0x00;
  RxMessage->IDE = CAN_ID_STD;
  RxMessage->DLC = 0;
  RxMessage->FMI = 0;
  for (i = 0;i < 8;i++)
    RxMessage->Data = 0x00;
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *   where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t* file, uint32_t line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* Infinite loop */
  while (1)
#endif
/******************* (C) COPYRIGHT 2009 STMicroelectronics *****END OF FILE****/
赞 收藏 评论4 发布时间:2013-10-31 15:32
4个回答
sansan-2053108 回答时间:2013-10-31 15:34:28
回复:求助各位高手,STM32F107RC的CAN不能发送数据
现在我没有发现错误,就是不能发送数据,求求各看看是什么原因,
sansan-2053108 回答时间:2013-10-31 15:40:53
各位看看是什么原因啊,每次都是这些问题,真不知道怎样查啊,
Hiker天下 回答时间:2013-11-2 13:46:14
RE:求助各位高手,STM32F107RC的CAN不能发送数据
请检查频率设置的是否匹配。
狼 回答时间:2013-11-2 18:02:10
那肯定是配置的问题。
