stm32f207vc spi1时钟无法输出
tianjianlv-1178 提问时间:2013-12-21 15:36 /
控制stm32F207vc开发板中的spi1(master),无法输出clock,请教大侠们!
#ifdef OpenSPI1
        #define Open207V_SPIx                           SPI1
        #define Open207V_SPIx_CLK                       RCC_APB2Periph_SPI1
        #define Open207V_SPIx_IRQn                      SPI1_IRQn
        #define Open207V_SPIx_IRQHANDLER                SPI1_IRQHandler
        #define Open207V_SPIx_SCK_PIN                   GPIO_Pin_5
        #define Open207V_SPIx_SCK_GPIO_PORT             GPIOA
        #define Open207V_SPIx_SCK_GPIO_CLK              RCC_AHB1Periph_GPIOA
        #define Open207V_SPIx_SCK_SOURCE                GPIO_PinSource5
        #define Open207V_SPIx_SCK_AF                    GPIO_AF_SPI1
        #define Open207V_SPIx_MISO_PIN                  GPIO_Pin_6
        #define Open207V_SPIx_MISO_GPIO_PORT            GPIOA
        #define Open207V_SPIx_MISO_GPIO_CLK             RCC_AHB1Periph_GPIOA
        #define Open207V_SPIx_MISO_SOURCE               GPIO_PinSource6
        #define Open207V_SPIx_MISO_AF                   GPIO_AF_SPI1
        #define Open207V_SPIx_MOSI_PIN                  GPIO_Pin_5
        #define Open207V_SPIx_MOSI_GPIO_PORT            GPIOB
        #define Open207V_SPIx_MOSI_GPIO_CLK             RCC_AHB1Periph_GPIOB
        #define Open207V_SPIx_MOSI_SOURCE               GPIO_PinSource5
        #define Open207V_SPIx_MOSI_AF                   GPIO_AF_SPI1
#endif
初始化函数如下:
SPI_InitTypeDef SPI_InitStruct;
        RCC_AHB1PeriphClockCmd(Open207V_SPIx_SCK_GPIO_CLK | Open207V_SPIx_MISO_GPIO_CLK | Open207V_SPIx_MOSI_GPIO_CLK,ENABLE);
        #ifdef OpenSPI1
                RCC_APB2PeriphClockCmd(Open207V_SPIx_CLK,ENABLE);
        #else
                RCC_APB1PeriphClockCmd(Open207V_SPIx_CLK,ENABLE);
        #endif
        GPIO_PinAFConfig(Open207V_SPIx_SCK_GPIO_PORT, Open207V_SPIx_SCK_SOURCE,  Open207V_SPIx_SCK_AF);
        GPIO_PinAFConfig(Open207V_SPIx_MISO_GPIO_PORT, Open207V_SPIx_MISO_SOURCE, Open207V_SPIx_MISO_AF);
        GPIO_PinAFConfig(Open207V_SPIx_MOSI_GPIO_PORT, Open207V_SPIx_MOSI_SOURCE, Open207V_SPIx_MOSI_AF);
        GPIO_InitStructure.GPIO_Pin = Open207V_SPIx_SCK_PIN;
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;
        GPIO_InitStructure.GPIO_PuPd  = GPIO_PuPd_DOWN;
        GPIO_Init(Open207V_SPIx_SCK_GPIO_PORT, &GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pin = Open207V_SPIx_MISO_PIN;
        GPIO_Init(Open207V_SPIx_MISO_GPIO_PORT, &GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pin = Open207V_SPIx_MOSI_PIN;
        GPIO_Init(Open207V_SPIx_MOSI_GPIO_PORT, &GPIO_InitStructure);
        SPI_I2S_DeInit(Open207V_SPIx);
        SPI_InitStruct.SPI_Direction= SPI_Direction_2Lines_FullDuplex;
        SPI_InitStruct.SPI_DataSize = SPI_DataSize_8b;
        SPI_InitStruct.SPI_Mode = SPI_Mode_Master;
        SPI_InitStruct.SPI_CPOL = SPI_CPOL_Low ;
        SPI_InitStruct.SPI_CPHA = SPI_CPHA_1Edge;
        SPI_InitStruct.SPI_NSS = SPI_NSS_Soft ;
        SPI_InitStruct.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_128;
        SPI_InitStruct.SPI_FirstBit = SPI_FirstBit_MSB;
        SPI_InitStruct.SPI_CRCPolynomial = 7;
        SPI_Init(Open207V_SPIx, &SPI_InitStruct);
        SPI_Cmd(Open207V_SPIx, ENABLE);
如果我将SPI1_SCK引脚换成PB3的功能引脚,则有clock输出,很奇怪为什么PA5这个引脚无法输出clock,已经确定该引脚没有复用,看了下手册该引脚IO结构是TTa的,不知道是啥意思?
赞 收藏 评论5 发布时间:2013-12-21 15:36
5个回答
dzc2001 回答时间:2013-12-24 20:06:04
RE:stm32f207vc spi1时钟无法输出
会不会是你的那个引脚坏了,没有换一片试试?
勒布朗 回答时间:2013-12-24 20:39:39
单步仿真,用示波器观察,不然就是硬件的问题
Hiker天下 回答时间:2013-12-25 00:12:54
只有时钟放慢点用示波器看下就知道了。
fengye5340 回答时间:2013-12-25 09:23:05
回复:stm32f207vc spi1时钟无法输出
STM32有的引脚是可以承受5V的电压的,这个引脚就用FT来标示,如果是正常的引脚,仅能承受最高的3.6V,一般用TT来标示。
一般用SPI接口的时候,SCK引脚线最好用电阻上拉一下,如果你确定你的引脚没有损坏的话,再上面加个10K的上拉再测试一下。
有缘于你 回答时间:2013-12-25 18:46:13
很可能硬件坏了,先单步调试看看波形吧
