/********************************************************************************** ( A9 `1 {) x$ q5 o * stm32F103VET6 红外驱动【遥控器解码实验程序】 0 a! j! `+ D5 q3 C% i3 [# r* Q * 4 J* p6 ~ N/ m9 [4 N * 遥控器 :42位编码 $ p2 z' D. \9 G5 z0 J W$ c * ***********************************************************************************/ #include "stm32f10x.h" #include "exti.h" #include "beep.h" % O- m& F T: K( P- x6 g1 J1 D# D% { #include "SysTick.h" #define LED1_0 GPIOD->BRR = 0x00000100 //LED低电平 #define LED2_0 GPIOD->BRR = 0x00000200 #define LED3_0 GPIOD->BRR = 0x00000400 5 h" p. T# O2 p0 B2 Y, v #define LED4_0 GPIOD->BRR = 0x00000800 #define LED1_1 GPIOD->BSRR = 0x00000100 //LED高电平 #define LED2_1 GPIOD->BSRR = 0x00000200 #define LED3_1 GPIOD->BSRR = 0x00000400 0 d% _& J3 T8 ~ L #define LED4_1 GPIOD->BSRR = 0x00000800 #define IR_Hongwai_0 GPIOE->BRR = 0x00000004 //红外数据低电平 #define IR_Hongwai_1 GPIOE->BSRR = 0x00000004 //红外数据高电平 , t3 T4 R% T- _8 c/ d6 b# s #define IR_Hongwai_x GPIO_ReadInputDataBit(GPIOE, GPIO_Pin_2) //读取红外电平状态 . R5 s- w& D2 b" f( L' \ 8 l: i$ O/ M. {) M unsigned char TimeByte; unsigned int IR_Tireafg[4]; ) S. X. x! h/ ?. ]- B unsigned int IR_xidwrit[8] = {0, 0, 0, 0, 0, 0 ,0, 0}; " z3 g% y4 a3 P8 h /* % m5 l y. o/ ?" y& V * GPIO端口配置子函数 */ void GPIO_InitStructReadtempCmd(void) % @& I1 H1 N+ |8 F* Y) f { 6 v7 r0 i8 S6 e1 A6 f GPIO_InitTypeDef GPIO_InitStruct; GPIO_InitStruct.GPIO_Pin = GPIO_Pin_2; //配置GPIO管脚 GPIO_InitStruct.GPIO_Mode = GPIO_Mode_IPU; //配置管脚为输入上拉 5 M& i1 g# |! t8 t- y* H GPIO_InitStruct.GPIO_Speed = GPIO_Speed_50MHz; //配置管脚速率50MHZ 4 I' S# c1 U$ I' |5 e; g GPIO_Init(GPIOE, &GPIO_InitStruct); //初始化指定端口 - q+ Z7 `3 A+ o& U7 }' n GPIO_InitStruct.GPIO_Pin = GPIO_Pin_5; ; L! F# v4 |9 `. ^( c) d& d. ^ GPIO_InitStruct.GPIO_Mode = GPIO_Mode_Out_PP; //配置管脚陪推挽式输出 ! ^* T' _/ |3 w6 v3 J& Y GPIO_InitStruct.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOB, &GPIO_InitStruct); , v0 C" j( a, f: D2 }5 s8 m GPIO_InitStruct.GPIO_Pin = GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 | GPIO_Pin_11; / w% Q3 l9 A; Z: r+ n% u& u GPIO_InitStruct.GPIO_Mode = GPIO_Mode_Out_PP; 0 o; Z4 k v# ^ GPIO_InitStruct.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOD, &GPIO_InitStruct); } /* 7 U4 M2 `6 n& q: L$ | * 配置外设时钟子函数 ' ^- k- c P, r# R8 w1 L% W2 m7 Q */ H1 E( ^. E5 k% u void RCC_APB2PeriphReadtempyCmd(void) { RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE); //打开GPIOB外设时钟 6 O1 M9 S& w7 P! X RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOE, ENABLE); //打开GPIOE外设时钟 RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD, ENABLE); //打开GPIOD外设时钟 RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO , ENABLE); //打开AFIO复用功能外设时钟 RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2 , ENABLE); } 6 z" \5 u# C- A6 h /* * 计算低脉宽持续时间Count1 * 10us 2 M) Y9 ?) ^! O9 C8 B */ 0 j; ~- G! m, D1 k unsigned int IR_HongwaiRead_LSB_Cmd() 5 D+ g: |7 u* X* b9 ? { unsigned int Count1 = 0; //定义时间变量 IR_Hongwai_0; //红外数据低电平 + ^* J* W9 m5 I* q7 F& F; x# e do //进入循环体 * L+ W* z* G0 k, {0 R { 0 x+ `2 ^" `1 { t# e Count1++; //时间变量加1 / m. z- Q% ]2 v. g Delay_10us(1); //延时10us } while(IR_Hongwai_x == 0); //判断条件如果读出来的红外数据为高电平跳出循环体 . G8 N, b2 W& s2 E) R8 G0 ~ return(Count1); //返回时间变量积数 } /* 2 k. \) A) K5 b( \' ~ * 计算高脉宽持续时间Count2 * 10us */ # j& a! m6 d5 y! U9 Q( G& g unsigned int IR_HongwaiRead_MSB_Cmd() { unsigned int Count2 = 0; //定义时间变量 IR_Hongwai_1; //红外数据高电平 6 }" `; i# C% E2 f do //进入循环体 P9 Z1 [. c, D1 R+ C { Count2++; //时间变量加1 . w1 {5 k- {3 ~- o! s" H0 @- f Delay_10us(1); //延时10us } while(IR_Hongwai_x == 1); //判断条件如果读出来的红外数据为低电平跳出循环体 ( D- v9 ~$ k( H4 `8 ~& v+ J, ] return(Count2); } " y7 H' V' i$ Q2 b% X7 O; k8 d ) Q$ j3 P0 P- x) M/ e3 I$ H /* * 函数主体 5 l- P5 [, Z0 G */ int main(void) { SystemInit(); //初始化系统时钟进入72M主频 SYSTICK_InitStructReadTCmd(); //初始化SysTick配置器寄存器 RCC_APB2PeriphReadtempyCmd(); //初始化外设时钟配置寄存器 ; e$ H* z+ O! y" a+ j GPIO_InitStructReadtempCmd(); //初始化GPIO端口配置寄存器 & E& d/ ?( d' } EXTI_InitStructReadtempCmd(); //初始化EXTI外部线路寄存器 ) Z- }5 D$ X8 w NVIC_InitStructReadtempCmd(); //初始化NVIC中断配置寄存器 # V9 P0 o' b8 q d( l while(1) { 6 D( e* M; ^7 N0 D; s# t( L6 z# z } 7 B8 l9 S2 K4 g8 b } /* * EXTI外部中断线服务程序 */ ' f/ ]: Y2 L& Q, L# K* y void EXTI2_IRQHandler(void) , \& ~" m b5 H' C& K { $ }, g0 _( B% T6 b% L/ |+ _ unsigned char i = 0; 8 o" V2 t$ h' `: u% w unsigned char flag = 1; 1 K, s+ E$ a4 P' G. Y // unsigned char flag1 = 1; unsigned int Countline2 = 0; IR_Hongwai_1; Countline2 = IR_HongwaiRead_LSB_Cmd(); //低电平引导码 9ms判断 & k, Z" r( ?7 ^% t. i if((Countline2 < 850) || (Countline2 > 950)) //小于8694us 大于9272us 一直循环否则跳出 ! T5 c7 \: `) \# U1 z+ r { return; 9 g7 I# Y2 p+ O( G# i } 2 X7 Z, f$ Z: @! n( o3 Y Countline2 = IR_HongwaiRead_MSB_Cmd(); //高电平引导码 4.5ms判断 if((Countline2 < 400) || (Countline2 > 450)) //小于4195us 大于4712us 一直循环否则跳出 { ' G. ~' f+ S3 t6 I return; } $ |" K4 ^, V& w% N* ?7 R Q- l8 m TimeByte = 0; for(i = 1; i < 14; i++) 0 h: p5 A- l5 S, r) y { TimeByte = TimeByte >> 1; T( E# x' N1 \ Countline2 = IR_HongwaiRead_LSB_Cmd(); //低电平延时0.56 判断 " ]6 v3 L: n1 o if((Countline2 < 40) || (Countline2 > 85))//小于425us 大于851us 一直循环否则跳出 { return; } + |/ }6 d0 C7 C: z! f5 g. U4 r Countline2 = IR_HongwaiRead_MSB_Cmd(); //高电平延时0.56判断 ; a+ p+ R+ y S if((Countline2 < 40) || (Countline2 > 200))//小于425us 大于1793us 一直循环否则跳出 { 3 G2 W, D0 w9 N$ C5 G! Q return; } 4 G2 P5 z4 R$ R3 S if( Countline2 > 130) //高电平延时大于1300us写1否则写0 { TimeByte |= 0x80; //写1 ' _* T* }5 k4 `7 W( P7 G6 U } & V4 c O) ?: {9 {( O } IR_Tireafg[0] = TimeByte; / W6 l9 E9 }. t; b- Q$ H0 G. M TimeByte = 0; . Y0 P8 o, I& S+ i for(i = 14; i < 27; i++) { TimeByte = TimeByte >> 1; ( ]9 n& N- d9 E3 {; B: z Countline2 = IR_HongwaiRead_LSB_Cmd(); if((Countline2 < 40) || (Countline2 > 85)) + f- B8 N/ @3 d, `4 z: \ { return; 9 z/ y% D; @: o. C' M2 Q } Countline2 = IR_HongwaiRead_MSB_Cmd(); if((Countline2 < 40) || (Countline2 > 200)) { return; - F9 L" Y* ~6 h) S# u6 p0 q7 N" t+ Q } if( Countline2 > 130) { G" u8 X! g. R8 x i& n TimeByte |= 0x80; } } 5 q, r2 y$ C! F2 M6 d# z3 D8 ? IR_Tireafg[1] = TimeByte; , c% W% h5 N8 K5 l TimeByte = 0; 3 p- |' `: j4 U- s3 k) N for(i = 27; i < 35; i++) { TimeByte = TimeByte >> 1; Countline2 = IR_HongwaiRead_LSB_Cmd(); & i/ `& J |% w0 ^- W# P3 Z if((Countline2 < 40) || (Countline2 > 85)) { ! O* l+ t: [" x ` return; ' v' S: }3 l* I: y1 I } ' U( z4 z/ |4 Y6 G3 u d& X; N) G1 L6 x/ k0 ?" B Countline2 = IR_HongwaiRead_MSB_Cmd(); # n, X: F) C6 m7 P& ]6 Q if((Countline2 < 40) && (Countline2 > 200)) { ( ]7 F" ]% M3 f* v return; ! I. c7 Y; E, f" _5 E% @ } if( Countline2 > 130) . ^+ u! j, v3 M7 L+ M6 R" s { TimeByte |= 0x80; } } IR_Tireafg[2] = TimeByte; TimeByte = 0; ; O& | F( ?# d/ F# U) Q 4 _7 v8 H5 }; l/ I for(i = 35; i < 43; i++) { TimeByte = TimeByte >> 1; Countline2 = IR_HongwaiRead_LSB_Cmd(); - e9 l8 V+ B: A) Y" f while((Countline2 < 40) || (Countline2 > 85)) { $ H; S) H% q, E) n3 [ return; 5 w& Q- K+ O% i } Countline2 = IR_HongwaiRead_MSB_Cmd(); 3 U/ u6 L7 u" i. F while((Countline2 < 40) || (Countline2 > 200)) : D' v. S. m4 T6 w. h { " z* u7 f' |/ k i return; } 8 g# R5 ~( C2 q) K$ v' h3 a' v if( Countline2 > 130) { # v) M+ [7 j: Q! n3 ? TimeByte |= 0x80; N# M1 r2 z: A! K/ l: G( b } } IR_Tireafg[3] = TimeByte; " o' H! x( q( A/ [! s5 P //************************判断用户正码和反码***************************************// % O: p5 [' m! A, O7 @/ h. B do { ( H# F- B% s2 p' D, F/ l+ v if(IR_Tireafg[0] == 0x08 & IR_Tireafg[1] == 0xF7 ) { flag = 0; : H8 x! t8 F) Z3 M. F1 p7 ^ } } while(flag == 1); : |; A, U" r1 i* G3 ?0 O3 ]! R //************************判断按键正码和反码***************************************// /* do ( t, `7 [+ Q0 y/ p% ^ { if(IR_Tireafg[2] == ~IR_Tireafg[3]) $ o! Q7 q, H: Q% x5 D { flag1 = 0; } 3 z& _2 i# e; J2 ~. k9 E } while(flag1 == 0); */ 2 D' e- A" ?- c //************************按下键码对应LED点亮**************************************// ) \3 z. t% Y+ q4 r- Z" J switch (IR_Tireafg[2]) { & g8 u! X( L% A( j, l0 s% X case 0x00: //按键 0 LED1_1; LED2_0; LED3_0; LED4_0; * N0 {5 q! A; y2 P- e break; 3 S8 b. u% k1 b) ~* ~, { case 0x01: //按键 1 " p* t1 Y) h& N0 b! [ LED1_0; LED2_1; LED3_0; LED4_0; break; : a' R5 l5 ~5 V case 0x02: //按键 2 # x9 Q) C4 i' ~3 ^ LED1_0; LED2_0; LED3_1; LED4_0; break; case 0x03: //按键 3 LED1_0; LED2_0; LED3_0; LED4_1; 4 }% g6 _' f% A. r break; case 0x04: //按键 4 LED1_0; LED2_0; LED3_1; LED4_0; break; case 0x05: //按键 5 LED1_0; LED2_1; LED3_0; LED4_0; break; 9 Y5 p: W, I4 I: j, l& |! D* v 7 e7 p5 v. N6 m. I& X case 0x06: //按键 6 ; I7 U1 W+ B3 [6 P LED1_1; LED2_0; LED3_0; LED4_0; break; case 0x07: //按键 7 LED1_1; LED2_0; LED3_1; LED4_0; break; case 0x08: //按键 8 ( ^; z& K. U* H# `# i LED1_0; LED2_0; LED3_0; LED4_0; break; , `/ \$ J) m# J+ w, h$ p case 0x09: //按键 9 LED1_0; LED2_1; LED3_0; LED4_1; break; $ P" W9 k9 h+ y# ~, [: M3 o case 0x15: //静音键 LED1_0; LED2_1; LED3_1; LED4_0; , B1 H+ Q% P: r$ r break; 3 w2 B0 H5 V! }) q6 ` case 0x1C: //开机键 LED1_1; LED2_0; LED3_0; LED4_1; % B9 f+ H' p* l, _( T break; / S' S( X- j6 A% {1 h% t$ P' q, q8 ~ case 0x14: //OSD键 LED1_1; LED2_1; LED3_0; LED4_0; 9 j) Y6 n( R5 H" |$ m break; case 0x0E: //RECALL键 LED1_0; LED2_0; LED3_1; LED4_1; break; $ X+ G* B* Q' K# W4 |" G case 0x19: //SLEEP键 LED1_1; LED2_1; LED3_1; LED4_0; % _2 V2 g* S- d7 ? break; 3 h9 F( v) S- E+ y5 d: q case 0x0A: //A/C键 . v1 s1 R7 S3 C9 c) [( d LED1_0; LED2_1; LED3_1; LED4_1; " H/ k" v. ?! o2 O6 P break; : W1 v1 h$ P# I6 g; ~ M+ F, Y2 ?5 A case 0x0F: //TV/AV键 " C+ y& d) I0 a5 N LED1_1; LED2_1; LED3_1; LED4_1; + l f4 a3 @1 N$ C3 q- z+ J break; case 0x13: //PP键 LED1_1; LED2_0; LED3_1; LED4_0; ( J \7 `5 ~) F0 N8 G break; case 0x0C: //GAME键 LED1_0; LED2_1; LED3_1; LED4_1; 1 _* x( b1 C5 s, W5 S' L* J+ J break; : {5 X- O n2 B2 r9 U1 c3 }8 D * ^6 }; Q: V6 a8 b v case 0x1E: //V-键 4 e. p( d) F* L+ r LED1_1; LED2_1; LED3_1; LED4_0; break; ; D9 n& t h# W' f8 N4 c ; `5 i3 M( I. L$ s6 C- o case 0x1F: //V+键 0 z% A! E% v. O; \: F LED1_0; LED2_0; LED3_1; LED4_0; break; # V7 R4 a8 o+ `3 M0 O; z case 0x1B: //P+键 LED1_0; LED2_0; LED3_0; LED4_1; break; . }4 f8 {" X: J case 0x1A: //P-键 LED1_1; LED2_0; LED3_0; LED4_0; break; / ?8 b* b9 q# y* @ case 0x10: //MENU键 8 r9 ?0 y, J `4 z. C% i' ^ LED1_0; LED2_1; LED3_0; LED4_0; break; , |8 g; i0 t1 s , m& T( O& ~1 K% N4 C4 U& N3 O default : break; + F0 Z5 v+ x( `- H' R, N; w+ z6 [ } * F8 q8 } q `0 u // Beep_lookCmd(); //蜂鸣器按键音 EXTI_ClearITPendingBit(EXTI_Line2); //清除EXTI2外部线路挂起位 & D$ _$ H, }+ m& j$ h" |3 S6 \9 C+ @ } ) A. S4 g" E% n) C( H `7 I /*******************************************END****************************************/ |
| 谢谢分享 |
