STM32F4中断进不去
shisixiong 提问时间:2014-3-13 15:42 /
 最近在学习STM32F4,碰到一个中断处理函数不能进入,其他中断函数都能进入,请大神指教。中断配置代码如下
void bsp_InitKeyEXTI(void)
        EXTI_InitTypeDef   EXTI_InitStructure;
        NVIC_InitTypeDef   NVIC_InitStructure;
        /* 使能SYSCFG时钟 */
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_SYSCFG, ENABLE);
        /* 连接 EXTI Line8 到 PI8 引脚 */
        SYSCFG_EXTILineConfig(EXTI_PortSourceGPIOI, EXTI_PinSource8);
        /* 连接 EXTI Line13 到 PC13 引脚 */
        SYSCFG_EXTILineConfig(EXTI_PortSourceGPIOC, EXTI_PinSource13);
        /* 连接 EXTI Line11 到 PI11 引脚 */
  SYSCFG_EXTILineConfig(EXTI_PortSourceGPIOI, EXTI_PinSource11);
        /* 连接 EXTI Line3 到 PH3 引脚 */
  SYSCFG_EXTILineConfig(EXTI_PortSourceGPIOH, EXTI_PinSource3);
        /* 连接 EXTI Line15 到 PH15 引脚 */
        SYSCFG_EXTILineConfig(EXTI_PortSourceGPIOH, EXTI_PinSource15);
        /* 连接 EXTI Line7 到 PG7 引脚 */
         SYSCFG_EXTILineConfig(EXTI_PortSourceGPIOG, EXTI_PinSource7);
        /* 连接 EXTI Line2 到 PH2 引脚 */
        SYSCFG_EXTILineConfig(EXTI_PortSourceGPIOH, EXTI_PinSource2);
        /* 连接 EXTI Line11 到 PF11 引脚 */
//        SYSCFG_EXTILineConfig(EXTI_PortSourceGPIOF, EXTI_PinSource11);
        /* 配置 EXTI LineXXX */
        EXTI_InitStructure.EXTI_Line = EXTI_Line2 | EXTI_Line3 | EXTI_Line7 | EXTI_Line8 \
                                      | EXTI_Line11 | EXTI_Line13| EXTI_Line15;
        //EXTI_InitStructure.EXTI_Line = EXTI_Line13 | EXTI_Line11 |  EXTI_Line8 | EXTI_Line7 ;
        EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
        EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling;
        EXTI_InitStructure.EXTI_LineCmd = ENABLE;
        EXTI_Init(&EXTI_InitStructure);
        /* 设置NVIC优先级分组为Group2:0-3抢占式优先级,0-3的响应式优先级 */
        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
        /* 中断优先级配置 最低优先级 这里一定要分开的设置中断,不能够合并到一个里面设置 */
        NVIC_InitStructure.NVIC_IRQChannel = EXTI2_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x00;
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x00;
        NVIC_InitStructure.NVIC_IRQChannel = EXTI3_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x01;
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x01;
        NVIC_InitStructure.NVIC_IRQChannel = EXTI9_5_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x02;
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x02;
        NVIC_InitStructure.NVIC_IRQChannel = EXTI15_10_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x03;
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x03;
当 EXTI15_10_IRQn和EXTI9_5_IRQn的抢占优先级设置为一样,即0x02或者0x03时都能进入。但是一个设置为0x02一个设置为0x03时,设置为0x03那个的中断函数就是进不去,不知道何原因。
赞 收藏 评论5 发布时间:2014-3-13 15:42
5个回答
废鱼 回答时间:2014-3-14 09:48:38
RE:STM32F4中断进不去
中断是同时产生的,还是单独产生的?
Daming 回答时间:2014-3-14 11:29:48
RE:STM32F4中断进不去
test
那片清茶 回答时间:2014-3-14 21:32:10
回复:STM32F4中断进不去
                                      | EXTI_Line11 | EXTI_Line13| EXTI_Line15;   分开设置试试、
shisixiong 回答时间:2014-3-16 22:00:53
回复:STM32F4中断进不去
回复第 2 楼 于2014-03-14 09:48:38发表:
中断是同时产生的,还是单独产生的?
单独产生的
shisixiong 回答时间:2014-3-16 22:01:42
回复:STM32F4中断进不去
回复第 4 楼 于2014-03-14 21:32:10发表:
试过了,单独写效果一样
