B/C: When B/C = 0, frame inversion of the LCD driving signal is enabled. When B/C = 1, a N-line inversion waveform is generated and alternates in each N lines specified by bits EOR and NW7-0. EOR: When B/C = 1 and EOR = 1, the odd/even frame-select signals and the N-line inversion signals are EORed for alternating drive. EOR is used when the LCD is not alternated by combining the set values of the lines of the LCD driven and the N-lines. 这几句话大概说的什么意思,专业术语,不太明白,求解惑 |
RE:SSD1289数据手册R02寄存器求解惑
线反转(line inversion)
线对反转(line-paired inversion)
点反转(dot inversion)
有了这些关键词,再看应该不难了吧?
回复:SSD1289数据手册R02寄存器求解惑
参考资料:
