各位大神: 小弟用的是STM32L152 RAT6的板子,主频是32Mhz,用下面的代码想控制蜂鸣器从灭到亮。。但不知道为什么蜂鸣器一点反应都没有。。。代码我是照着原子教你玩STM32 F系列改编过来的。。。他的板子主频是72MHz ...不过这应该不会影响蛮大。。下面是完整代码。请各位大神看看是哪里有错。。。控制的是TIM2的2通道。。gpio是PA1。。。蜂鸣器是好的。。请用过STM32 L152的大神来指导一下 代码如下: #include "stm32l1xx.h" #include "stm32l1xx_conf.h" typedef unsigned long u32; typedef unsigned short u16; typedef unsigned int u8; static __IO u32 TimingDelay; /* BUZZERÖ÷º¯Êý */ void beep_Init(void); void TIM3_PWM_Init(u16 arr,u16 psc); void SysTick_Init(void); void Delay_us(__IO u32 nTime); void TimingDelay_Decrement(void) ; int main(void) { u16 led0pwmval=0; u8 dir=1; SysTick_Init(); //NVIC_Configuration(); //ÉèÖÃNVICÖжϷÖ×é2:2λÇÀÕ¼ÓÅÏȼ¶£¬2λÏìÓ¦ÓÅÏȼ¶ //uart_init(9600); //´®¿Ú³õʼ»¯Îª9600 beep_Init(); // TIM3_PWM_Init(899,0); // while(1) { Delay_us(10); if(dir)led0pwmval++; else led0pwmval--; if(led0pwmval>300)dir=0; if(led0pwmval==0)dir=1; TIM_SetCompare2(TIM3,led0pwmval); } } void beep_Init(void) { GPIO_InitTypeDef GPIO_InitStructure; RCC_APB2PeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE); //ʹÄÜPA¶Ë¿ÚʱÖÓ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8; //beep0-->A.8 ¶Ë¿ÚÅäÖà GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT; GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; // ¸´ÓÃÍÆÍìÊä³ö GPIO_InitStructure.GPIO_Speed = GPIO_Speed_40MHz; GPIO_Init(GPIOA, &GPIO_InitStructure); //¸ù¾ÝÉ趨²ÎÊý³õʼ»¯GPIOA.1 // GPIO_SetBits(GPIOA,GPIO_Pin_1); //PA.1 Êä³ö¸ß GPIO_InitStructure.GPIO_Speed = GPIO_Speed_40MHz; GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF; GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; // ¸´ÓÃÍÆÍìÊä³ö GPIO_Init(GPIOA, &GPIO_InitStructure); //ÍÆÍìÊä³ö £¬IO¿ÚËÙ¶ÈΪ50MHz //GPIO_SetBits(GPIOB,GPIO_Pin_5); //PB.5 Êä³ö¸ß } //TIM3 PWM²¿·Ö³õʼ»¯ //PWMÊä³ö³õʼ»¯ //arr£º×Ô¶¯ÖØ×°Öµ //psc£ºÊ±ÖÓÔ¤·ÖƵÊý void TIM3_PWM_Init(u16 arr,u16 psc) { GPIO_InitTypeDef GPIO_InitStructure; TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure; TIM_OCInitTypeDef TIM_OCInitStructure; RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2,ENABLE); RCC_APB2PeriphClockCmd(RCC_AHBPeriph_GPIOA , ENABLE); GPIO_InitStructure.GPIO_Speed = GPIO_Speed_40MHz; GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF; GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; // ¸´ÓÃÍÆÍìÊä³ö GPIO_Init(GPIOA, &GPIO_InitStructure); ////³õʼ»¯TIM2 TIM_TimeBaseStructure.TIM_Prescaler = psc; TIM_TimeBaseStructure.TIM_ClockDivision = 0; TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; TIM_TimeBaseStructure.TIM_Period = arr; TIM_TimeBaseInit(TIM2,&TIM_TimeBaseStructure); //³õʼ»¯TIM2 Channel2 PWMģʽ TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2; TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High; TIM_OC2Init(TIM2, &TIM_OCInitStructure); TIM_OC2PreloadConfig(TIM2, TIM_OCPreload_Enable); TIM_Cmd(TIM2, ENABLE); } void SysTick_Init(void) { /* SystemFrequency / 1000 1ms???? * SystemFrequency / 100000 10us???? * SystemFrequency / 1000000 1us???? */ // if (SysTick_Config(SystemFrequency / 100000)) // ST3.0.0??? if (SysTick_Config(SystemCoreClock / 100000)) // ST3.5.0??? { /* Capture error */ while (1); } // ??????? SysTick->CTRL &= ~ SysTick_CTRL_ENABLE_Msk; } void Delay_us(__IO u32 nTime) { TimingDelay = nTime; // ??????? SysTick->CTRL |= SysTick_CTRL_ENABLE_Msk; while(TimingDelay != 0); } /* void SysTick_Handler(void) { TimingDelay_Decrement(); } */ /* * »ñÈ¡½ÚÅĺ¯Êý */ void TimingDelay_Decrement(void) { if (TimingDelay != 0x00) { TimingDelay--; } } |
回复:关于STM 32 PWM的输出脉冲的问题
你的蜂鸣器是怎么连接的呢?
蜂鸣器是一头连接正极,一头连接PA1
RE:关于STM 32 PWM的输出脉冲的问题
具体验证可以使用LED去验证,实现LED由亮到暗暂变的过程
关键是楼主的蜂鸣器硬件电路让人揪心了。
我们知道蜂鸣器的工作电流是30mA,而STM32普通IO最大电流25mA,整体不超过150mA,这样是无法驱动的。增加一个8550的三极管吧,串联一个1K的限流电阻,还要增加下拉电阻。
