最新版MDK5.11a软件下载
yongjun 发布时间:2014-6-17 11:19
Microcontroller Development Kit - Version 5.11a( P$ F9 |. Z% J0 A/ A
( ]. N0 G8 Y. ?* T9 N7 b
This MDK release includes the Software Packs CMSIS Version 4.1 and MDK-Middleware Version 6.0 that are incompatible with the current STM32 Device Family Packs. The application note 266Using Keil MDK v5.11 with STM32 devices describes the reasons and the resolution.
/ P# q$ H/ ]- d* I
        This MDK release includes the following fixes over MDK Version 5.11:
    + |" I% W7 B8 X. Y: u& ~" l
    - a) B6 ~9 J8 ]4 E. f) Z
      u' M  u2 q! t( b2 r
              - v# {, y  C; h. k
    • Updated µVision (V5.11.1.0):        ' V9 n4 s$ k, s7 A- j) s1 j
                      E& f6 B" e0 X; u# Q
      • gpdsc file reload problem fixed (Infineon DAVE3)            : o9 e, @0 l+ o4 Y# V
      • Select Software Packs dialog control via keyboard fixed        ; B7 C9 l  T) v( |  N6 k
              # f: p& h* \0 l' |2 l6 {% ~
    • Updated SystemViewer.dll (V2.28.0):        - K6 g6 U" k3 N- K: ^; m7 {1 o: }
                    # P4 G! F/ M7 t- z: |. N6 p4 V3 P7 T
      • Periodic window update for child elements fixed
        ; b" T7 M0 n; I( z1 R
      • Abort on Display of LPC4300 GPIO registers fixed
        8 K4 }9 @* u/ g2 j3 U' {
      * R! n- a7 H. e+ `3 F
    3 z$ B3 o* _$ v; d2 [; |% g
8 q% O* K) \  k! x, t$ g2 H
    " n4 Q2 g$ p( u
  •     This MDK release includes the following Software Packs:
    / A4 s3 _+ r3 j% q3 h4 ?, d0 e- h* X
    * a+ \; o: h. c/ k* @
              $ s+ W8 G0 x* l, U1 a, {+ K, e# v
    • CMSIS V4.1.0 with new CMSIS-Driver API.        / g. E) T; q. s+ n1 f$ i* M
    • MDK-Middleware V6.0.0 that uses the new CMSIS-Driver API.    ) x' M0 r9 V: m' v; \* S
        These Software Packs are compatible with the new DFP Version 2.0.x or higher for Infineon and NXP. All future DFP's will rely on the above Software Packs.: M  q: T6 o" j% p/ t. t
        , _* X+ `5 ~3 E
        NOTE: For using middleware with EnergyMicro and ST devices that are based on DFP Version 1.x select CMSIS V3.2.x and MDK-Middleware V5.1.x as described under Select Software Packs.    4 U2 D, U! W% B% J% S: ~+ i; V
  •     This MDK release contains the following new components:6 n: e$ g9 U& I! O3 N
    ' d3 G+ q  E4 s& F5 Z/ J
    * A. ]8 G8 H7 e9 t4 b    9 z# I7 e% C% D7 }2 y3 Y
  •     ARM Compiler$ r" }1 n) R" W4 d6 u; V! g) q" E. B
    , L, t3 v- K% D4 {5 T" H    7 {' y6 g% P/ l  b5 M5 {
              7 L& b. V% `8 T3 v% q8 }. |
    • The absacc.h header file has been removed from the ARMCC/include folder. Use the _attribute_ syntax instead of the macro __at.    % b' E0 B' p6 W+ U' w8 H
        & z) Q( K7 `) q$ s1 R$ I8 }
  •     Target debugging2 B/ y, t' {" I' z7 s& E$ @
    1 [- W7 n4 l6 q% Q4 k5 V+ D- g    3 z1 q" m4 e" C
      " `4 D' ]3 g; g+ Z7 {9 ]
    • Updated: STMicroelectronics ST-Link driver for STMicroelectronics devices to version 2.0.6.0 to support STM32L0 devices.
      3 n/ T4 d, o) W' k
    • Updated: NuLink software to version 6.2.11      d; f! \1 E+ z* e- ?
    % h! I0 S8 Y' |* t
下载地址.txt
31 Bytes, 下载次数: 310
赞 收藏 1 评论39 发布时间:2014-6-17 11:19
39个回答
wjandsq 回答时间:2014-12-21 22:45:04
现在都MDK-ARM 5.13版本了,可以去下载最新的。
zbber 回答时间:2016-10-19 16:11:36
看看  谢谢啊啊啊
wamcncn 回答时间:2014-12-21 14:50:09
现在出了5.13了
沐紫 回答时间:2014-6-17 13:46:05
RE:最新版MDK5.11软件下载
多谢楼主分享最新信息!
e1997 回答时间:2014-6-17 22:11:16
回复:最新版MDK5.11软件下载
好东西呀,谢谢共享!
tylcareer 回答时间:2014-6-17 23:51:11
RE:最新版MDK5.11软件下载
多谢分享,下来看看
Simon_Linux 回答时间:2014-6-18 10:50:43
回复:最新版MDK5.11软件下载
下载看,试试,一直用 5.10
feel-376797 回答时间:2014-6-18 12:49:49
RE:最新版MDK5.11软件下载
谢谢楼主分享
限量_个性。 回答时间:2014-6-18 14:10:56
RE:最新版MDK5.11软件下载
看看  谢谢啊啊啊
lnasdxx-79844 回答时间:2014-6-18 16:03:56
回复:最新版MDK5.11软件下载
好东西呀,谢谢共享!
jlian168 回答时间:2014-6-19 22:57:19
回复:最新版MDK5.11软件下载
学习了,好资料分享!
hawgr 回答时间:2014-6-20 09:44:42
回复:最新版MDK5.11软件下载
谢谢分享!!!
hongtaolaok 回答时间:2014-6-20 14:36:32
RE:最新版MDK5.11软件下载
看看,在用mdk4.2
770781327 回答时间:2014-6-20 15:01:04
回复:最新版MDK5.11软件下载
 多谢分享
thrawsnow-19383 回答时间:2014-6-20 15:23:06
回复:最新版MDK5.11软件下载
多谢楼主分享最新信息!
cangbai 回答时间:2014-6-21 00:14:39
RE:最新版MDK5.11软件下载
这里有这款芯片的datasheet下载
a9527308 回答时间:2014-6-21 16:52:32
RE:最新版MDK5.11软件下载
多谢分享
123下一页
