stm32读写cpld,读写失败,其中为啥fsmc_clk没有时钟?
纳兹咩 提问时间:2014-6-19 15:19 /
 部分程序如下:
void RCC_Configuration(void)
  /* RCC复位*/
  RCC_DeInit();
  /* 使能外部高速晶振 */
  RCC_HSEConfig(RCC_HSE_ON);
  /* 等待晶振稳定 */
  HSEStartUpStatus = RCC_WaitForHSEStartUp();
  if(HSEStartUpStatus == SUCCESS)
        /* HCLK = SYSCLK 设置高速总线时钟=系统时钟*/
    RCC_HCLKConfig(RCC_SYSCLK_Div1);
    /* PCLK2 = HCLK 设置低速总线2时钟=高速总线时钟*/
    RCC_PCLK2Config(RCC_HCLK_Div1);
    /* PCLK1 = HCLK/2 设置低速总线1的时钟=高速时钟的二分频*/
    RCC_PCLK1Config(RCC_HCLK_Div2);
    /* PLLCLK = 8MHz * 9 = 72 MHz */
    RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
    /* Enable PLL 使能锁相环,在使能之前设置好参数*/
    RCC_PLLCmd(ENABLE);
    /* Wait till PLL is ready 等待锁相环输出稳定*/
    while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
    /* Select PLL as system clock source 将锁相环输出设置为系统时钟*/
    RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
    /* Wait till PLL is used as system clock source 等待校验成功*/
    while(RCC_GetSYSCLKSource() != 0x08)
void FSMC_Configuration(void)
//        RCC_AHBPeriphClockCmd(RCC_AHBPeriph_FSMC, ENABLE);//使能FSMC时钟
        FSMC_NORSRAMInitTypeDef  FSMC_NORSRAMInitStructure;
        FSMC_NORSRAMTimingInitTypeDef  p;
        /*FSMC总线使用的GPIO组时钟使能*/
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD | RCC_APB2Periph_GPIOE |
                           RCC_APB2Periph_GPIOF | RCC_APB2Periph_GPIOG | RCC_APB2Periph_GPIOB | RCC_APB2Periph_AFIO, ENABLE);
    /*FSMC数据线FSMC_D[0:15]初始化,推挽复用输出*/
          GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_8 | GPIO_Pin_9 |
                                  GPIO_Pin_10 | GPIO_Pin_14 | GPIO_Pin_15;
          GPIO_Init(GPIOD, &GPIO_InitStructure);
          GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 |
                                  GPIO_Pin_11 | GPIO_Pin_12 | GPIO_Pin_13 | GPIO_Pin_14 |
                                  GPIO_Pin_15;
          GPIO_Init(GPIOE, &GPIO_InitStructure);
    /*FSMC地址线FSMC_A[0:15]初始化,推挽复用输出*/
          GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_3 |
                                  GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_12 | GPIO_Pin_13 |
          GPIO_Init(GPIOF, &GPIO_InitStructure);
                                  GPIO_Pin_4 | GPIO_Pin_5;
          GPIO_Init(GPIOG, &GPIO_InitStructure);
//以下引脚未使用:
//          GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11 | GPIO_Pin_12 | GPIO_Pin_13;
//          GPIO_Init(GPIOD, &GPIO_InitStructure);
          /*FSMC CLK!!!,NOE和NWE初试化,推挽复用输出*/
          GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3 | GPIO_Pin_4 |GPIO_Pin_5;
//        /*MPU_CLK 初试化,推挽复用输出-PA8*/
//          GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
//          GPIO_Init(GPIOA, &GPIO_InitStructure);
          /*FSMC NE1初始化,推挽复用输出*/
          GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;
///*FSMC_NADV-PB7*/
//   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;
//   GPIO_Init(GPIOB, &GPIO_InitStructure);
//   GPIO_PinRemapConfig(GPIO_Remap_FSMC_NADV, DISABLE);
/*!< NWAIT configuration !!!!!!*/
   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
/*FSMC NBL0和NBL1初始化,进行高低字节使能,对于CPLD不需要,推挽复用输出*/
//          GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1;
//          GPIO_Init(GPIOE, &GPIO_InitStructure);
          p.FSMC_AddressSetupTime = 0x01;           //地址建立时间
          p.FSMC_AddressHoldTime = 0x00;            //地址保持时间
          p.FSMC_DataSetupTime = 0x05;             //数据建立时间
          p.FSMC_BusTurnAroundDuration = 0x02;      //总线恢复时间
          p.FSMC_CLKDivision = 0x1;                //时钟分频因子
          p.FSMC_DataLatency = 0x01;                      //数据产生时间,访问SRAM,这个参数不起作用。
          p.FSMC_AccessMode =  FSMC_AccessMode_A; //FSMC NOR控制器时序
          FSMC_NORSRAMInitStructure.FSMC_Bank = FSMC_Bank1_NORSRAM1;                  //使用了FSMC的BANK1的子板块1!!!!!!
          FSMC_NORSRAMInitStructure.FSMC_DataAddressMux = FSMC_DataAddressMux_Disable;//禁止地址数据线复用
          FSMC_NORSRAMInitStructure.FSMC_MemoryType = FSMC_MemoryType_SRAM;           //存储器类型为SRAM!!!!!!(NOR)
          FSMC_NORSRAMInitStructure.FSMC_MemoryDataWidth = FSMC_MemoryDataWidth_16b;  //存储器数据宽度为16位!!!!!!
          FSMC_NORSRAMInitStructure.FSMC_BurstAccessMode = FSMC_BurstAccessMode_Enable; //关闭突发模式访问(Enable)
        FSMC_NORSRAMInitStructure.FSMC_AsynchronousWait = FSMC_AsynchronousWait_Disable;
        FSMC_NORSRAMInitStructure.FSMC_WaitSignalPolarity = FSMC_WaitSignalPolarity_Low;//等待信号优先级,只有在使能突发访问模式才有效
          FSMC_NORSRAMInitStructure.FSMC_WrapMode = FSMC_WrapMode_Disable;//关闭Wrapped burst access mode,只有在使能突发访问模式才有效
          FSMC_NORSRAMInitStructure.FSMC_WaitSignalActive = FSMC_WaitSignalActive_BeforeWaitState;//等待信号设置,只有在使能突发访问模式才有效
          FSMC_NORSRAMInitStructure.FSMC_WriteOperation = FSMC_WriteOperation_Enable;     //使能这个BANK的写操作
          FSMC_NORSRAMInitStructure.FSMC_WaitSignal = FSMC_WaitSignal_Enable;//使能/关闭等待信息设置,只在使能突发访问模式才有效(enable)
          FSMC_NORSRAMInitStructure.FSMC_ExtendedMode = FSMC_ExtendedMode_Disable; //关闭Extend Mode
          FSMC_NORSRAMInitStructure.FSMC_WriteBurst = FSMC_WriteBurst_Disable;     //关闭Write Burst Mode
          FSMC_NORSRAMInitStructure.FSMC_ReadWriteTimingStruct = &p;               //读操作时序参数
          FSMC_NORSRAMInitStructure.FSMC_WriteTimingStruct = &p;                   //写操作时序参数
          FSMC_NORSRAMInit(&FSMC_NORSRAMInitStructure);
          FSMC_NORSRAMCmd(FSMC_Bank1_NORSRAM1, ENABLE);//使能BANK1,SRAM1
int main(void)
        RCC_Configuration();
        FSMC_Configuration();
各位大神帮忙看看,rcc时钟和fsmc的配置是不是不对?
赞 收藏 评论13 发布时间:2014-6-19 15:19
13个回答
纳兹咩 回答时间:2014-6-19 21:00:55
回复:stm32读写cpld,读写失败,其中为啥fsmc_clk没有时钟?
是不是端口复用问题。。。
feel-376797 回答时间:2014-6-22 08:33:21
RE:stm32读写cpld,读写失败,其中为啥fsmc_clk没有时钟?
blog.csdn.net/haozi_1989/article/details/6142344
http://blog.csdn.net/haozi_1989/article/details/6142344
有缘于你 回答时间:2014-6-22 09:17:32
没看到端口复用的语句
纳兹咩 回答时间:2014-6-22 09:49:22
回复第 3 楼 于2014-06-22 08:33:21发表:
时钟终于出来了,是因为存储器类型不对,改成PSRAM就好了。
但是又有新问题了。读写不对了:
#define Test_1             ((u16)0xFFFF)
#define Bank1_SRAM1_ADDR   ((u32)0x60000000)
#define TestRegister_ADDR                     (Bank1_SRAM1_ADDR + 0x0000000D)
void FSMC_CPLD_Write(u16 data, u32 WriteAddr)//¶ÔCPLD½øÐÐд²Ù×÷
    *(u16 *) (WriteAddr) = data;
u16 FSMC_CPLD_Read(u32 ReadAddr)//¶ÔCPLD½øÐжÁ²Ù×÷
    u16 pBuffer;
        pBuffer = *(__IO u16*) (ReadAddr);
        return pBuffer;
main函数里读写语句为:
FSMC_CPLD_Write(Test_1, TestRegister_ADDR);
FSMC_CPLD_Read(TestRegister_ADDR);
为什么不对了?严重怀疑写的FSMC_CPLD_Write()和FSMC_CPLD_Read()不正确!但却找不出原因……
纳兹咩 回答时间:2014-6-22 11:11:06
现在发现数据总线是正确的,地址总线不正确
纳兹咩 回答时间:2014-6-22 11:11:42
#define Bank1_SRAM1_ADDR   ((uint32_t)0x60000000)
#define CounterL_ADDR                         (uint32_t)(Bank1_SRAM1_ADDR + 0x00000000) //¼ÆÊýÆ÷µÍλ(16bit)
#define CounterH_ADDR                         (uint32_t)(Bank1_SRAM1_ADDR + 0x00000001) //¼ÆÊýÆ÷¸ßλ(16bit)
#define LatchOneL_ADDR                         (uint32_t)(Bank1_SRAM1_ADDR + 0x00000002) //µÚÒ»¼¶Ëø´æµÍλ(16bit)
#define LatchOneH_ADDR                         (uint32_t)(Bank1_SRAM1_ADDR + 0x00000003) //µÚÒ»¼¶Ëø´æ¸ßλ(16bit)
#define LatchTwoL_ADDR                         (uint32_t)(Bank1_SRAM1_ADDR + 0x00000004) //µÚ¶þ¼¶Ëø´æµÍλ(16bit)
#define LatchTwoH_ADDR                         (uint32_t)(Bank1_SRAM1_ADDR + 0x00000005) //µÚ¶þ¼¶Ëø´æ¸ßλ(16bit)
#define LatchThreeL_ADDR                     (uint32_t)(Bank1_SRAM1_ADDR + 0x00000006) //µÚÈý¼¶Ëø´æµÍλ(16bit)
#define LatchThreeH_ADDR                     (uint32_t)(Bank1_SRAM1_ADDR + 0x00000007) //µÚÈý¼¶Ëø´æ¸ßλ(16bit)
#define LatchFourL_ADDR                     (uint32_t)(Bank1_SRAM1_ADDR + 0x00000008) //µÚËļ¶Ëø´æµÍλ(16bit)
#define LatchFourH_ADDR                     (uint32_t)(Bank1_SRAM1_ADDR + 0x00000009) //µÚËļ¶Ëø´æ¸ßλ(16bit)
#define LatchFiveL_ADDR                     (uint32_t)(Bank1_SRAM1_ADDR + 0x0000000A) //µÚÎå¼¶Ëø´æµÍλ(16bit)
#define LatchFiveH_ADDR                     (uint32_t)(Bank1_SRAM1_ADDR + 0x0000000B) //µÚÎå¼¶Ëø´æ¸ßλ(16bit)
#define SimulationControl_ADDR                 (uint32_t)(Bank1_SRAM1_ADDR + 0x0000000C) //·ÂÕæÄ£Ê½¼Ä´æÆ÷(2bit)
#define TestRegister_ADDR                     (uint32_t)(Bank1_SRAM1_ADDR + 0x0000000D) //²âÊÔ¿ØÖƼĴæÆ÷(6bit)
#define IntRegister_ADDR                     (uint32_t)(Bank1_SRAM1_ADDR + 0x0000000E) //ÖжϿØÖƼĴæÆ÷(1bit)
#define RstRegister_ADDR                     (uint32_t)(Bank1_SRAM1_ADDR + 0x0000000F) //¸´Î»¿ØÖƼĴæÆ÷(16bit)
这种连续的地址允许吗???
狼 回答时间:2014-6-22 21:58:55
看着像是配置的问题
feiante-155820 回答时间:2014-6-23 10:33:12
地址是一方面,关键是你的fsmc_clk时钟没有,还是在看看FSMC的配置
深秋独影 回答时间:2014-6-23 12:51:36
应该还是FSMC的配置问题,没有配置对
dzc2001 回答时间:2014-6-23 13:49:55
感觉是你的电平不准,测一下高低电平达到要求了么
aaa999kk 回答时间:2014-6-23 17:17:01
检查下地址参数, 看看电平
vivy 回答时间:2014-6-24 16:13:51
http://yun.baidu.com/pcloud/album/info?uk=2853967793&album_id=5492137931588632574
看下这个,有专门讲FSMC
feixiang20 回答时间:2014-6-30 22:56:54
查端口的地址设置有问题吗
