请问大神,stm32f407vgt6 摄像头 ov7670
一飞比 提问时间:2014-7-15 10:10 /
代码如下,例程用到sccb,dcmi,dma ,现在的问题 是不知道怎么修改摄像头传给液晶屏的数据,比如我要把
void Cam_Init(void)
          DCMI_InitTypeDef DCMI_InitStructure;
          DMA_InitTypeDef  DMA_InitStructure;
          RCC_AHB2PeriphClockCmd(RCC_AHB2Periph_DCMI, ENABLE);//DCMI
          RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2, ENABLE);//DMA2
    RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA | RCC_AHB1Periph_GPIOB |
                           RCC_AHB1Periph_GPIOC | RCC_AHB1Periph_GPIOE, ENABLE);//ʹÄÜDCMIµÄGPIOʱÖÓ
          GPIO_PinAFConfig(GPIOA, GPIO_PinSource8, GPIO_AF_MCO);//MCO1A8
          GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
          GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;
          GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
    RCC_MCO2Config(RCC_MCO1Source_PLLCLK, RCC_MCO1Div_3);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5;//PE5WRDOWN
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
    GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP ;
    GPIO_Init(GPIOE, &GPIO_InitStructure);
          GPIO_ResetBits(GPIOE, GPIO_Pin_5);//power on
    GPIO_PinAFConfig(GPIOA, GPIO_PinSource4, GPIO_AF_DCMI);//DCMI_HSYNC
    GPIO_PinAFConfig(GPIOA, GPIO_PinSource6, GPIO_AF_DCMI);//DCMI_PIXCLK
    GPIO_PinAFConfig(GPIOB, GPIO_PinSource6, GPIO_AF_DCMI);//DCMI_D5
    GPIO_PinAFConfig(GPIOB, GPIO_PinSource7, GPIO_AF_DCMI);//DCMI_VSYNC
    GPIO_PinAFConfig(GPIOE, GPIO_PinSource5, GPIO_AF_DCMI);//DCMI_D6
    GPIO_PinAFConfig(GPIOE, GPIO_PinSource6, GPIO_AF_DCMI);//DCMI_D7
    GPIO_PinAFConfig(GPIOC, GPIO_PinSource6, GPIO_AF_DCMI);//DCMI_D0
    GPIO_PinAFConfig(GPIOC, GPIO_PinSource7, GPIO_AF_DCMI);//DCMI_D1
    GPIO_PinAFConfig(GPIOE, GPIO_PinSource0, GPIO_AF_DCMI);//DCMI_D2
    GPIO_PinAFConfig(GPIOE, GPIO_PinSource1, GPIO_AF_DCMI);//DCMI_D3
    GPIO_PinAFConfig(GPIOE, GPIO_PinSource4, GPIO_AF_DCMI);//DCMI_D4
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7;
    GPIO_Init(GPIOC, &GPIO_InitStructure);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_6;
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7 ;
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4 | GPIO_Pin_6;
    //DCMIÅäÖÃ
          DCMI_InitStructure.DCMI_CaptureMode = DCMI_CaptureMode_Continuous;
          DCMI_InitStructure.DCMI_SynchroMode = DCMI_SynchroMode_Hardware;
          DCMI_InitStructure.DCMI_PCKPolarity = DCMI_PCKPolarity_Falling;
          DCMI_InitStructure.DCMI_VSPolarity = DCMI_VSPolarity_High;
          DCMI_InitStructure.DCMI_HSPolarity = DCMI_HSPolarity_High;
          DCMI_InitStructure.DCMI_CaptureRate = DCMI_CaptureRate_All_Frame;
          DCMI_InitStructure.DCMI_ExtendedDataMode = DCMI_ExtendedDataMode_8b;
          DCMI_Init(&DCMI_InitStructure);
                //DMAÅäÖÃ
          DMA_DeInit(DMA2_Stream1);
          DMA_InitStructure.DMA_Channel = DMA_Channel_1;
          DMA_InitStructure.DMA_PeripheralBaseAddr = DCMI_DR_ADDRESS;
          DMA_InitStructure.DMA_Memory0BaseAddr = FSMC_LCD_ADDRESS;
          DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory;
          DMA_InitStructure.DMA_BufferSize = 1;
          DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
          DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Disable;
          DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Word;
          DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
          DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
          DMA_InitStructure.DMA_Priority = DMA_Priority_High;
          DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Enable;
          DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_Full;
          DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
          DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
          DMA_Init(DMA2_Stream1, &DMA_InitStructure);
u8 OV7670_Init(void)
  u8 i;
  Cam_Init();
        SCCB_Init();
        OV_Reset();
        delay_ms(5);
        LCD_String(20,50,"Camera ID:",RED);
        LCD_Num(180,50,OV_ReadID(),3,WHITE);//ov7670 IDΪ0x73
          for(i=0;i
赞 收藏 评论4 发布时间:2014-7-15 10:10
4个回答
有缘于你 回答时间:2014-7-15 19:46:19
RE:请问大神,stm32f407vgt6 摄像头 ov7670
参考下这个http://share.dzkf.cn/down/down.php?downid=29252&id=0
feixiang20 回答时间:2014-7-23 02:31:33
先找到传送的那个参数啊
aaa999kk 回答时间:2014-7-24 15:59:51
你分析过程序, 知道每段的作用了吗
霹雳之火 回答时间:2014-7-30 22:42:04
这个看的太麻烦了,你测试过了这驱动吗,例外液晶屏的参数呢。
