这两个星期都在调试stm32f4的硬件i2c,在这过程中遇到了各种蛋疼的问题,经过参考大量的例程和资料,今天终于把硬件的I2C调通了,我使用定时器3开10ms的中断,然后再10ms的中断里读取GY86的MPU6050和HMC5883L的数据,再经经过4元数法算出3个角。有人说stm32的I2C用起来很难,但其实也不是很难的,我就是直接用官方的库函数实现的。下面来直入主题。0 m+ _5 T$ v1 v5 C! C$ n$ Y 硬件平台: UNCLEO-F401RE( b. V0 m0 u2 O% l" K5 c% R9 R9 L( ? & K! e/ Q B; v) _ 首先是I2C的IO和I2C的配置的配置,这个至关重要,一旦初始化不正确,I2C就会出现各种状况。4 K4 z& D$ @. o9 E* L1 G 下面贴上代码:. f6 S" G' Y3 P- X2 H2 d) v. Y; L void I2C_Congiguration(void)* F' O5 u* R, d! S" {$ R% f% g8 K {% H( P* \- C5 N/ U9 V /****IO口的配置*******/ GPIO_InitTypeDef GPIO_InitStructure; I2C_InitTypeDef I2C_InitStructure; ' Y" n6 M6 \; @. P& G& e6 I4 L) i RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB | RCC_AHB1Periph_GPIOB,ENABLE); RCC_APB1PeriphClockCmd(RCC_APB1Periph_I2C1,ENABLE); ) z S" [3 Y6 E5 V8 h GPIO_PinAFConfig(GPIOB, GPIO_PinSource7, GPIO_AF_I2C1); GPIO_PinAFConfig(GPIOB, GPIO_PinSource6, GPIO_AF_I2C1);" ~/ ~5 E" ~: ?1 }: Y* A' C: L GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7; //GPIO_Pin_6 | GPIO_Pin_7 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF; 3 h4 Z z) E) v6 e GPIO_InitStructure.GPIO_OType = GPIO_OType_OD;+ [! q; B; P2 m P8 g GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;6 ^" o. U/ P o8 l: g GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL; 8 b# @' o3 O# s) W* X6 p GPIO_Init(GPIOB, &GPIO_InitStructure); 6 W; R6 d2 X9 ]9 I: b7 c/ v- J /* I2C1 的配置 */ I2C_DeInit(I2C1); I2C_InitStructure.I2C_Mode = I2C_Mode_I2C; // I2C_InitStructure.I2C_DutyCycle = I2C_DutyCycle_2; // I2C_InitStructure.I2C_OwnAddress1 = 0xd0; I2C_InitStructure.I2C_Ack = I2C_Ack_Enable; I2C_InitStructure.I2C_AcknowledgedAddress = I2C_AcknowledgedAddress_7bit; I2C_InitStructure.I2C_ClockSpeed = I2C_Speed; ) n# e7 T5 z; F) N: x0 w- g /*使能 I2C1 */ I2C_Cmd(I2C1, ENABLE);: m. W6 m1 h# k% g* w 9 u) v& [6 b1 q( V1 [# G /* I2C1 初始化*/ I2C_Init(I2C1, &I2C_InitStructure); 允许1字节1应答模式*/) G& o& B" x# q% O1 R! r8 h% I I2C_AcknowledgeConfig(I2C1, ENABLE); - X: E+ v# }) n% C2 l% G } }( k4 k0 L6 o" B3 g6 P ) p1 c7 f* }+ D) p$ {6 g 在用stm32F4的库函数前,我要补充一下stm32F1与stm32F4的区别。 第一个,在F 1 里边你可以使用这样的方式配置时钟复用 R C C _ A P B 2 P e r i p h C l o c k C m d ( R C C _ A P B 2 P e r i p h _ G P I O A | R C C _ A P B 2 P e r i p h _ G P I O B | R C C _ A P B 2 P e r i p h _ A F I O | R C C _ A P B 2 P e r i p h _ U S A R T 1 , E N A B L E ) ; / /! Y& j5 U5 b6 B, j' I* N 打开复用时0 ~2 j: U5 P" X. X$ U; S& p5 \" q 但是。。。在F 4 里边这个就不管用了。因为F 4 的变了,以前的那些变量不再爱你了。库里边根本就没有了这个变量R C C _ A P B 2 P e r i p h _ A F I O1 W2 F: j& I& l; Q 第二,G P I O 的输入输出模式也变了。这样的用法:G P I O _ I n i t S t r u c t u r e . G P I O _ M o d e = G P I O _ M o d e _ I N _ F L O A T I N G ; 。已经不行了。原因同上,& w' |- u4 j/ B3 I G P I O _ M o d e _ I N _ F L O A T I N G 这种模式已经不存在了。/ X7 z, M+ b) R4 | 在F 4 的库里边只有这个模式:G P I O _ M o d e _ A F 。所有使用复用功能的引脚都应设置成这种模式。 这样比F 1 方便多了。你不用考虑这个引脚应该设置成浮空输入还是推挽输出. . . . 因为引脚设置错误基本可以消失。6 w! W( ^4 _6 h1 B }! X t1 W0 c: L 引脚的复用功能要用GPIO_PinAFConfig();这个函数了。配置完这些后,就是I2C的协议程序了。代码我就不贴上了,大家就下载附件来看吧。 然后就是定时器的配置;代码如下:4 a6 \2 e* S, O5 V% |$ _- | void TIM_Init()7 M5 a0 {- ?0 z! i! q* _ { : u" p! L! n2 U TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure; //Tim_Nvic_Init(); RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE); // TIM3 clock enable TIM_TimeBaseStructure.TIM_Period = 99;' @) @6 d R) a. Q! e TIM_TimeBaseStructure.TIM_Prescaler = 7199;, s$ H8 g1 a, m1 O TIM_TimeBaseStructure.TIM_ClockDivision = 0;$ U% d4 J+ A* y TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; ! `$ F' Z$ n( C( [0 x9 z* \: m TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure); 1 Z/ ?0 M! w9 B( ?7 o' a2 k$ F$ A 7 ]2 ^# q) ?* t2 D% I7 e9 @ TIM_ITConfig(TIM3,TIM_IT_Update, ENABLE); * G8 u K0 Q3 V# h* p; M, t /* TIM3 enable counter */ TIM_Cmd(TIM3, ENABLE); , Z4 x& X2 ]2 T% a$ U* Z, [ TIM_ClearFlag(TIM3,TIM_FLAG_Update); ( O" C& G# T' e } $ ^* s: |6 v0 A G5 |9 y0 t 我这个板子使用外部晶振的,我用的是12M,经过PLL后得出72M的时钟频率。6 Q7 k+ Q, S5 z, q4 s: G1 } void Sysclock_Init()4 d5 g% M$ V& ]; u N5 m; M { 3 |* v/ L* y' p+ L* R- m4 H RCC->CR |= ((uint32_t)RCC_CR_HSEON); /* 使能HSE */- D! v$ ~. Y! j r while ((RCC->CR & RCC_CR_HSERDY) == 0); /* 等待HSE */+ D9 v& |6 F7 [- A . x: A. f! t0 x( x# |% t5 B0 D0 u RCC->CFGR = RCC_CFGR_SW_HSE; 3 Q/ ?, p2 _" t( u' c/ ] while ((RCC->CFGR & RCC_CFGR_SWS) != RCC_CFGR_SWS_HSE);5 ]# T( A; Z$ S. x: {. ~' ` 4 J# W, R1 r6 G FLASH->ACR = FLASH_ACR_PRFTEN; /* Enable Prefetch Buffer */) t1 T3 B, o0 O! B, Y7 a+ S3 z' S FLASH->ACR |= FLASH_ACR_ICEN; /* Instruction cache enable */ FLASH->ACR |= FLASH_ACR_DCEN; /* Data cache enable */ FLASH->ACR |= FLASH_ACR_LATENCY_5WS; + L. e9 _* d9 J }! Q4 `+ \ * ]* O+ f" O0 j; f1 v. F RCC->CFGR |= RCC_CFGR_HPRE_DIV1; /* HCLK = SYSCLK */2 c; ?& W' @# z) A7 l2 h+ Q7 p& U RCC->CFGR |= RCC_CFGR_PPRE1_DIV1; /* APB1 = HCLK */" `+ q8 f- F0 F. m9 C2 t RCC->CFGR |= RCC_CFGR_PPRE2_DIV1; 3 S# T1 j* t. A/ N RCC->CR &= ~RCC_CR_PLLON; RCC-> LLCFGR = ( 20ul | /* PLL_M = 20 */- |. X! n; `' P9 B/ C; C6 _(240ul CFGR |= RCC_CFGR_SW_PLL;! E& x( I; m; e! H- S" z' h& s while ((RCC->CFGR & RCC_CFGR_SWS) != RCC_CFGR_SWS_PLL); ( E* k+ Q6 W3 n% l0 { % P% X3 d' X0 p) o2 | }0 @% s: ?7 D$ S$ q0 v , K& @- l3 L# }& y* K* S j6 w: @ 关于系统时钟的设置可以参考stm32f401参考手册第99页。" w: w* Z% t' T+ M) i 计算的公式是 : SystemCoreClock = (HSx*(PLL_N/PLL_M))/PLL_P; 如下图:! x. d( r5 [4 j, o/ S
0 u* r r6 W* i* o0 G% e! c HSx可以选择外部高速晶振HSE和内部高速震荡器HSI,注意内部的高速震荡器是16M的,这个是经过本人用定时器开PWM算出来是正确的,注意系统时钟不能设得太高,否则就会起不了振的。" f4 r$ D. t2 H9 V. T" H. r, n0 q4 I 顺便说一下PLL_Q是用来给USB等外设的。% _$ X$ \! a$ N4 p* s" y 这一PLL_N和PLL_M,PLL_Q是有范围的,如手册就表明了范围了。
如果你没有外部晶振,就把上面的HSE全都替换成HSI ,这是你就要注意是按16M来算的了。如果你用多少M的外部晶振,要修改头文件里的HSE_VALUE的数值,头文件是默认25M的,我外部是12M的,所以就改成#define HSE_VALUE ((uint32_t)12000000);
% N, ~8 k5 L( u# C& i( O 说了这么多,现在说回时钟的配置吧。: F: U; X5 ^; m; f- R. Z' S 设置完时钟后,就要设置中断的优先级了。 void Tim_Nvic_Init(void)9 m6 B4 G+ j1 {# t: j1 T { 4 z( W3 ~, E4 K/ E5 ] NVIC_InitTypeDef NVIC_InitStructure; ~# L# o( V0 h! g NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);# r, A3 ?" w, I+ K /* Enable the TIM3 gloabal Interrupt */$ D% C- J' ]: X2 f- @3 Q3 q a NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn;- L2 E) T! H; b2 C NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;) u5 v/ e# K% Y6 X& ~& i% B NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;6 d! c5 \* x. u6 O/ ` NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; {- y4 s6 g# B8 X0 e NVIC_Init(&NVIC_InitStructure); }, T l9 j1 I. @! ? 当中断多的时候,这里就有很大的学问了,想了解的可以上去百度或google一下。我这里就不多说了。7 y6 t2 O- T5 [2 d1 e) T 中断的里的程序: void TIM3_IRQHandler(void) { if(TIM_GetITStatus(TIM3,TIM_IT_Update) != RESET) { TIM_ClearITPendingBit(TIM3,TIM_IT_Update);( _% J; _) ^4 `& u3 V Read_Filter_MPU6050(); //Read_HMC5883L(); Get_Attitude(); //ACC_ANGLE(); }' i; P+ Z2 M4 z9 K. G# I }: ]2 p& K. q3 J P 关键的主程序部分了 int main()3 p" G+ x9 q7 `2 }3 e3 _/ b {5 J# \9 ?% m, V2 Q3 Y% K ; C) Q6 w4 [/ ^( M0 l ' y2 L$ r) I! p& A uint8_t counter; short value; 0 K ?: A1 e5 |! ?& H Sysclock_Init(); Tim_Nvic_Init(); delay_init(72); I2C_Congiguration(); MPU6050_Init();' e' p: \+ Q w) S HMC5883L_Init(); TIM_Init();, A2 N$ q: v# F: ^! h3 r while (1) { }; |+ y! }2 I6 u% M& J7 A, P } 注意时钟的配置要放到最后,否则会影响I2C会卡死的! Y& `0 Z6 Y" v& G' H3 v 现在已经运行了3个小时一起良好:2 w, l" L0 t5 G 这是我用示波器下看的I2C时序4 G6 m! } h. T p" ]
转载请注!! 强仔00001 2014-7-21写
TIM.zip
(342.99 KB, 下载次数: 452)
RE: STM32f401的硬件I2C
RE: STM32f401的硬件I2C
回复: STM32f401的硬件I2C
这明明是分享帖嘛,怎么放在求助帖里呢?不过感觉挺好的,学习了
& f @- @3 t% ]0 ~$ J
是的看完之后楼主自己解决的问题,是分享帖
RE: STM32f401的硬件I2C
