STM8L TIMER4 定时中断时间不能调整
dsoyy 提问时间:2014-7-25 11:49 /
 在官网下载了最新的库文件,在 stm8l15x_tim4.c文件中看到如下描述:
              TIM4 Driver: how to use it in Timing(Time base) Mode
       To use the Timer in Timing(Time base) mode, the following steps are mandatory:
       1. Enable TIM4 clock using CLK_PeripheralClockConfig(CLK_Peripheral_TIM4, ENABLE) function.
       2. Call TIM4_TimeBaseInit() to configure the Time Base unit with the
          corresponding configuration.
       3. Enable global interrupts if you need to generate the update interrupt.
       4. Enable the corresponding interrupt using the function TIM4_ITConfig(TIM4_IT_Update)
       5. Call the TIM4_Cmd(ENABLE) function to enable the TIM4 counter.
因此,我写了一个定时的timer:
main.c函数:
  Clk_AutoSwitch(CLK_SYSCLKSource_LSI);
  CLK_RTCCLKSwitchOnLSEFailureEnable();
  CLK_LSEClockSecuritySystemEnable();
  /* Enable TIM4 CLK */
   CLK_PeripheralClockConfig(CLK_Peripheral_TIM4, ENABLE);
  /* TIM4 configuration:
    - TIM4CLK is set to 32 K Hz, the TIM4 Prescaler is equal to 128 so the TIM1 counter
    clock used is 32 KHz / 128 = 250 Hz
   - With 250 Hz we can generate time base:
       max time base is 1.024 s if TIM4_PERIOD = 255 --> (255 + 1) / 250 = 1.024s
       min time base is 8 ms if TIM4_PERIOD = 1   --> (  1 + 1) / 125000 = 8 ms
   - In this examle we need to generate a time base equal to 1 ms
    so TIM4_PERIOD = (0.001 * 125000 - 1) = 124 */
   /* Time base configuration */
   TIM4_TimeBaseInit(TIM4_Prescaler_128, 250);    //调整参数,可以改变定时时间?
      /* enable interrupts */
   enableInterrupts();
   /* Enable update interrupt */
   TIM4_ITConfig(TIM4_IT_Update, ENABLE);
   /* Clear TIM4 update flag */
  TIM4_ClearFlag(TIM4_FLAG_Update);
   /* Enable TIM4 */
   TIM4_Cmd(ENABLE);
中断函数:
INTERRUPT_HANDLER(TIM4_UPD_OVF_TRG_IRQHandler, 25)
  /* In order to detect unexpected events during development,
     it is recommended to set a breakpoint on the following instruction.
    GPIO_ToggleBits(LED_BL_PORT,LED_BL_PIN);
    TIM4_ClearITPendingBit(TIM4_IT_Update);
结果,中断可以进入,但是中断时间不可以调整。
按照我的理解,   TIM4_TimeBaseInit(TIM4_Prescaler_128, 250);调整参数会改变触发中断的时间,结果没有任何作用。
实际我的需求是,调整定时时间。这个定时Base怎么理解?
请帮帮指点.
赞 收藏 1 评论6 发布时间:2014-7-25 11:49
6个回答
dsoyy 回答时间:2014-7-25 11:57:32
RE:STM8L TIMER4 定时中断时间不能调整
秒表测试了一下,定时的时间也不是我计算的1S
dsoyy 回答时间:2014-7-25 14:57:45
问题解决。
上述代码没有问题。
micheal7500 回答时间:2015-2-6 22:32:52
问题怎么解决的?能共享下吗?
阿里巴巴 回答时间:2015-2-7 00:30:17
天好蓝 回答时间:2015-2-7 10:46:35
foxglove 回答时间:2015-2-7 23:17:23
怎么解决的
