stm32f030f4的hsi时钟作为pll时钟源时,芯片不能跑起
phil198926 提问时间:2014-8-18 17:17 /
如题,下面贴上我的时钟设置代码:
#define PLL_SOURCE_HSI        // HSI (~8MHz) used to clock the PLL, and the PLL is used as system clock source
static void SetSysClock(void)
  __IO uint32_t StartUpCounter = 0, HSEStatus = 0;
  /* SYSCLK, HCLK, PCLK configuration ----------------------------------------*/
#if defined (PLL_SOURCE_HSI)
  /* At this stage the HSI is already enabled */
  /* Enable Prefetch Buffer and set Flash Latency */
  FLASH->ACR = FLASH_ACR_PRFTBE | FLASH_ACR_LATENCY;
  /* HCLK = SYSCLK */
  RCC->CFGR |= (uint32_t)RCC_CFGR_HPRE_DIV1;
  /* PCLK = HCLK */
  RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE_DIV1;
  /* PLL configuration = (HSI/2) * 12 = ~48 MHz */
  RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_PLLSRC | RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLMULL));
  RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_HSI_Div2 | RCC_CFGR_PLLXTPRE_PREDIV1 | RCC_CFGR_PLLMULL12);
  /* Enable PLL */
  RCC->CR |= RCC_CR_PLLON;
  /* Wait till PLL is ready */
  while((RCC->CR & RCC_CR_PLLRDY) == 0)
  /* Select PLL as system clock source */
  RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_SW));
  RCC->CFGR |= (uint32_t)RCC_CFGR_SW_PLL;
  /* Wait till PLL is used as system clock source */
  while ((RCC->CFGR & (uint32_t)RCC_CFGR_SWS) != (uint32_t)RCC_CFGR_SWS_PLL)
#else
 #if defined (PLL_SOURCE_HSE)
  /* Enable HSE */
  RCC->CR |= ((uint32_t)RCC_CR_HSEON);
 #elif defined (PLL_SOURCE_HSE_BYPASS)
  /* HSE oscillator bypassed with external clock */
  RCC->CR |= (uint32_t)(RCC_CR_HSEON | RCC_CR_HSEBYP);
 #endif /* PLL_SOURCE_HSE */
  /* Wait till HSE is ready and if Time out is reached exit */
  do
    HSEStatus = RCC->CR & RCC_CR_HSERDY;
    StartUpCounter++;
  } while((HSEStatus == 0) && (StartUpCounter != HSE_STARTUP_TIMEOUT));
  if ((RCC->CR & RCC_CR_HSERDY) != RESET)
    HSEStatus = (uint32_t)0x01;
  else
    HSEStatus = (uint32_t)0x00;
  if (HSEStatus == (uint32_t)0x01)
    /* HCLK = SYSCLK */
    /* PCLK = HCLK */
    /* PLL configuration = HSE * 6 = 48 MHz */
    RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_PREDIV1 | RCC_CFGR_PLLXTPRE_PREDIV1 | RCC_CFGR_PLLMULL6);
    /* Enable PLL */
  else
  { /* If HSE fails to start-up, the application will have wrong clock
         configuration. User can add here some code to deal with this error */
#endif /* PLL_SOURCE_HSI */
当我调试到
RCC->CR |= RCC_CR_PLLON;这条语句的时候,仿真器就不能调试了
不知是怎么回事?
赞 收藏 评论4 发布时间:2014-8-18 17:17
4个回答
phil198926 回答时间:2014-8-19 11:52:46
回复:stm32f030f4的hsi时钟作为pll时钟源时,芯片不能跑起
今天搞定这个问题了,原因是我的VDDA没有上电
feel-376797 回答时间:2014-8-19 13:51:56
RE:stm32f030f4的hsi时钟作为pll时钟源时,芯片不能跑起
很好的问答。。。
落月枫情 回答时间:2015-12-28 22:36:27
刚才试了下内部时钟,发现死在了
跟楼主情况差不多,不知什么原因
爱的ee 回答时间:2017-6-7 09:32:20
请问楼主,VDDA没有上电  的意思是硬件有问题吗?还是代码没有讲VDDA打开?
