关于SI4432双工通信收发冲突
ST游徒 提问时间:2014-8-27 14:16 /
在使用si4432时,单工可以很好实现,一个收另一个发,没有问题。现在要做双工通信,默认情况为接收状态,接收结果显示在串;串口触发SI4432发送。但是现在出现一个问题是:当发送的时候,在发送方串口会同时显示上次接受的数据的第一个数据并和上次接收数据个数一样。我一步一步调试发现两个中断位都响应了,但是我在发送后的中断函数最后默认了接收模式啊。。。。。。。。请大神给点指示,如何调试
赞 收藏 评论5 发布时间:2014-8-27 14:16
5个回答
霹雳之火 回答时间:2014-8-27 14:50:23
RE:关于SI4432双工通信收发冲突
SI4432是款射频芯片吧,没用过,楼主最好把代码贴出来,让大神来看看
ST游徒 回答时间:2014-8-27 15:08:46
回复:关于SI4432双工通信收发冲突
回复第 2 楼 于2014-08-27 14:50:23发表:
void Si4432_ISR(void)
        uint8_t status1 = 0;
        uint8_t status2 = 0;
        uint8_t SI4432_RxLenth = 0;
        statebuf[2] = SPI_Read(0x02);
        delay_ms(1);
        status1 = SPI_Read(0x03);                //read the Interrupt Status1 register
        status2 = SPI_Read(0x04);                //read the Interrupt Status2 register, just for clear the pending bits?
  statebuf[3] = SPI_Read(0x02);
        if(status1==0x26)
          if(rx_flag ==1)
                  status1 =0x24;
                        rx_flag ^=1;
         if ( (status1 & 0x02) == 0x02 ) /*Valid Packet Received*/
                rx_flag |= 2;
                SI4432_RxLenth = SPI_Read(0x4B);
                for (SI4432_RxCount=0;SI4432_RxCount < SI4432_RxLenth;SI4432_RxCount++)
                                SI4432_RxBUFF[SI4432_RxCount] = SPI_Read(0x7F);
//                SPI_RW_Reg(0x08, 0x02);
//                SPI_RW_Reg(0x08, 0x00);
//                SPI_RW_Reg(0x07, 0x05); //enble rx
                        statebuf[4] = SPI_Read(0x02);
        if(  (status1 & 0x04) == 0x04 ) /* packet sent interrupt*/
                tx_ok = 1;
                statebuf[5] = SPI_Read(0x02);
        statebuf[6] = SPI_Read(0x02);
        SPI_RW_Reg(0x08, 0x03);
        SPI_RW_Reg(0x07,0x01);
        delay_ms(10);
        SPI_RW_Reg(0x05, 0x03); /* enable rx interrupt*/
        SPI_RW_Reg(0x06, 0x00);
  statebuf[7] = SPI_Read(0x02);
void Si4432Send(uint8_t* buf, uint8_t len)
        if(tx_ok)
        SI4432_RxBUFF[rx_count++] = SPI_Read(0x5);
        SI4432_RxBUFF[rx_count++] = SPI_Read(0x6);
        SI4432_RxBUFF[rx_count++] = SPI_Read(0x7);
        SI4432_RxBUFF[rx_count++] = SPI_Read(0x8);
                SPI_RW_Reg(0x07, 0x01);        //ready mode
                delay_ms(10);                // delay for stable
                SPI_RW_Reg(0x3e, len);  // SET transimit length
                while(len--)
                SPI_RW_Reg(0x7F, *buf++);
                statebuf[9] = SPI_Read(0x02);
                SPI_RW_Reg(0x05, 0x04);        //enable trasimition complete interrupt
                SPI_Read(0x03);                        //clear interrupt flags
                SPI_Read(0x04);
                SPI_RW_Reg(0x07, 0x09);        // transmition enable
    statebuf[10] = SPI_Read(0x02);
                tx_ok = 0;
int main(void)
        RCC_Configuration();
        GPIO_Configuration();
        NVIC_Configuration();
        USART2_Configuration();
        JrInit();
//        printf("wholly shit");
        uprintf("si4432 poc");
        /*software reset*/
        SPI_RW_Reg(0x07, 0x80);
        delay_ms(100);
//        while(GPIO_ReadInputDataBit(TIP_JR_IRQ_PORT,TIP_JR_IRQ_PIN) == SET);
        SI4432_RxBUFF[rx_count++] = SPI_Read(0x3);
        SI4432_RxBUFF[rx_count++] = SPI_Read(0x4);
        delay_ms(100);
        SPI_RW_Reg(0x75, 0x53);
        SPI_RW_Reg(0x76, 0x64);  //
        SPI_RW_Reg(0x77, 0x00);
        SI4432_RxBUFF[rx_count++] = SPI_Read(0x75);
        SI4432_RxBUFF[rx_count++] = SPI_Read(0x76);
        SI4432_RxBUFF[rx_count++] = SPI_Read(0x77);
        SPI_RW_Reg(0x2a, 0x14);
        SPI_RW_Reg(0x6e, 0x09);
        SPI_RW_Reg(0x6f, 0xd5);
        SPI_RW_Reg(0x70, 0x2c);
//SpiWriteRegister(0x72, 0x48);        //(9.6kbps)
    SPI_RW_Reg(0x72, 0x38);        // frequency bias (1.2kbps)
//(9.6 kbps, deviation: 45 kHz, channel filter BW: 102.2 kHz
        SPI_RW_Reg(0x1C, 0x1b);                                                        //write 0x1E to the IF Filter Bandwidth register
        SPI_RW_Reg(0x20, 0x83);                                                        //write 0xD0 to the Clock Recovery Oversampling Ratio register
        SPI_RW_Reg(0x21, 0xc0);                                                        //write 0x00 to the Clock Recovery Offset 2 register
        SPI_RW_Reg(0x22, 0x13);                                                        //write 0x9D to the Clock Recovery Offset 1 register
        SPI_RW_Reg(0x23, 0xa9);                                                        //write 0x49 to the Clock Recovery Offset 0 register
        SPI_RW_Reg(0x24, 0x00);                                                        //write 0x00 to the Clock Recovery Timing Loop Gain 1 register
        SPI_RW_Reg(0x25, 0x03);                                                        //write 0x24 to the Clock Recovery Timing Loop Gain 0 register
        SPI_RW_Reg(0x1D, 0x40);                                                        //write 0x40 to the AFC Loop Gearshift Override register
        SPI_RW_Reg(0x1E, 0x0A);                                                        //write 0x0A to the AFC Timing Control register
        SPI_RW_Reg(0x2A, 0x14);                                                        //write 0x20 to the AFC Limiter register
        /* preamble & synchronous words configuration*/
        SPI_RW_Reg(0x34, 0X0A);                                        //  5 bytes of preamble
        SPI_RW_Reg(0x35, 0x2A);                                        // preamble check enable
        SPI_RW_Reg(0x33, 0x02);                                        // Transmitted Synchronization Word 3 first, followed by sync word 2
        SPI_RW_Reg(0x36, 0x2d);                                        //Synchronization Word 0x2dd4
        SPI_RW_Reg(0x37, 0xd4);
        SPI_RW_Reg(0x30, 0x8D);                                        //enalbe PH+FIFO MODE, MSB, CCITT CRC
    SPI_RW_Reg(0x32, 0x00 );                                // disable frame header
        SPI_RW_Reg(0x71, 0x63);                                        // tranismit without CLK, FIFO, FSK MODE
        /*GPIO configuration*/
        SPI_RW_Reg(0x0b, 0x12); //
        SPI_RW_Reg(0x0c, 0x15); //
        /* others configuration */
        SPI_RW_Reg(0x09, 0xD7);  // loading capacity
        SPI_RW_Reg(0x69, 0x60);  //AGC overload
        /* tx power*/
        SPI_RW_Reg(0x6d, 0x1e);
        /* enable rx manually*/
        /* clear interrupt*/
        SI4432_RxBUFF[rx_count++] = SPI_Read(0x03);
        SI4432_RxBUFF[rx_count++] = SPI_Read(0x04);
        statebuf[0] = SPI_Read(0x02);
        for(;;)
                if(rx_flag & 1)
                        //rx_flag ^= 1;
                        delay_ms(2);
                        Si4432Send(uart_rx_buf, uart_rx_count);
                        uart_rx_count = 0;
                 statebuf[14] = SPI_Read(0x02);
                if(rx_flag & 2)
                        rx_flag ^= 2;
                        delay_ms(2);
                        unprint((char*)SI4432_RxBUFF, SI4432_RxCount);
                        SI4432_RxCount=0;
                        statebuf[15] = SPI_Read(0x02);
                delay_ms(5);
Ko-beki 回答时间:2014-8-27 16:21:00
RE:关于SI4432双工通信收发冲突
SPI_RW_Reg,SPI_Read时序没有控制好,你用的是单数据线还是双数据线?
ST游徒 回答时间:2014-8-27 19:16:04
回复:关于SI4432双工通信收发冲突
回复第 4 楼 于2014-08-27 16:21:00发表:
双数据线,stm32硬件SPI接口。你讲时序没有控制好,具体是哪里
硅传科技V 回答时间:2016-10-26 00:36:37
HW3000超低双向无线fsk模块完美替代CC1101、CC1120、A7139、A7108、si4432、si4438、si4463
