传说中的512版本出来了.哈哈 赶紧下载,和谐照旧.0 b; e0 J1 I1 R d http://www.keil.com/download/files/mdkcm512.exe $ Z8 r$ Y% y+ O4 y8 Z E 同学们赶紧下载体验.6 _, Q4 ^+ { a* a2 D 说说更新吧:+ }' ?/ A0 U( p9 W% h6 e- D4 k6 g 1, This MDK version introduces support for ARM Cortex-M7 processor based devices.4 P1 W2 X& i1 j" L- \* P$ ` 此版本引入了对最新的m7的支持.; f/ F2 A( g+ ]5 `7 D3 m . t3 l' V8 F) e 2This MDK release contains two ARM Compiler versions that can be selected in the dialog Project - Options for Target - Target (under Code Generation):0 H9 O+ M: S2 s- Z+ [ ARM Compiler 5.05 (build 41) (in directory ..\ARM\ARMCC\) with support for Cortex-M7 and other enhancements (see release notes).. t/ _3 ^9 J& `2 Q* J& j ARM Compiler 5.04u2 (build 82) (in directory ..\ARM\ARMCC_504u2\) for safety critical applications in combination with the ARM Compiler Qualification Kit (only available with a license for MDK-Professional). 此版本引入了2个arm编译器, 在项目配置中,可以通过下拉选择; 3 Enhanced performance in the Project View and new file, group, and component attributes. 工程显示 菜单,组件的更新.) ]% U( M# j. l: w" [) V 还有其他一些中间件软件的更新. |
RE:抢先体验 keil 512 支持st最新的M7
回复:抢先体验 keil 512 支持st最新的M7
听说MDK要收版权费了,我用开源免费的了
貌似一直收费的
