手上是Nucleo板,发现无法连接上,无法识别该MCU是STM32。 Open On-Chip Debugger 0.8.0 (2014-04-28-08:42) Licensed under GNU GPL v2 For bug reports, read http://openocd.sourceforge.net/doc/doxygen/bugs.html Info : This adapter doesn't support configurable speed Info : STLINK v2 JTAG v21 API v2 SWIM v5 VID 0x0483 PID 0x374B Info : using stlink api v2 Info : Target voltage: 3.250693 Info : stm32f3x.cpu: hardware has 6 breakpoints, 4 watchpoints Info : accepting 'gdb' connection from 3333 Info : device id = 0x10016439 Warn : Cannot identify target as a STM32 family. Error: auto_probe failed Error: Connect failed. Consider setting up a gdb-attach event for the target to prepare target for GDB connect, or use 'gdb_memory_map disable'. Error: attempted 'gdb' connection rejected |
新手上路。请多多指教!
