stm8编译错误,看不懂,求解释
themyth 提问时间:2014-11-7 15:47 /
clnk -m Debug\project_1.map -l"D:\STM8 C\Lib"  -o Debug\project_1.sm8 Debug\project_1.lkf
#error clnk Debug\project_1.lkf:69 Debug\stm8_interrupt_vector.o: symbol f_NonHandledInterrupt multiply defined (Debug\stm8s_it.o)
The command: "clnk -m Debug\project_1.map -l"D:\STM8 C\Lib"  -o Debug\project_1.sm8 Debug\project_1.lkf " has failed, the returned value is: 1
exit code=1.
project_1.elf - 3 error(s), 0 warning(s)
赞 收藏 评论4 发布时间:2014-11-7 15:47
4个回答
arm8686 回答时间:2014-11-7 16:27:51
符号 f_NonHandledInterrupt 被重定义(多次定义)。
themyth 回答时间:2014-11-7 17:21:32
无意间解决了!!!!!!
tmcsb 回答时间:2014-11-27 14:05:54
怎么解决的?
aoxiangwode2008 回答时间:2014-11-28 22:03:39
中断向量重复定义了吧。
