) p- G/ v) u! \5 e) P5 c X/ W
" a/ f( M) f; A+ G5 g/ `/************************************************************************************************/
2 i9 g' y& K6 z' Y! D3 e最近一段时间在学习contiki系统,STM32在无线应用上前景更为广阔。
% K% q( T: D7 w0 u% {1 W5 f/************************************************************************************************/
e- c, o9 b2 z: K' b& F平台配置-- platform-conf.h
7 L, z& y) N: x6 u& }5 G
8 G$ b( L+ g0 `) o# @, p- /*
7 ]2 v2 t }% x( P( a; o2 Y - * \file
) U0 F9 ?* F6 {- U - * platform-conf.h8 s( d! d4 b; V2 B! D( D
- * \author' @3 o$ z8 [, x0 M, q/ \1 B
- * Marcus Lunden <marcus@thingsquare.com>>/ o& G1 H5 F! l L
- * \desc4 a* j: X0 Y; ?! U6 b/ F: ?
- * platform dependent configurations" u# C4 X! `; d; w
0 i. X3 N6 l+ \: u# _4 V& a
* r; a4 A& r6 |# A6 D* i4 \8 Y- #ifndef __PLATFORM_CONF_H__
1 N; ?7 F& b) G$ p1 g9 t$ Q$ B) W - #define __PLATFORM_CONF_H__
5 v6 i# P* _& \$ v& _8 |% N; ]) p - /*--------------------------------------------------------------------*/
9 B& d4 V# H J& n - #include <inttypes.h>& E j/ [( c! l
- #include <string.h>& i3 G3 E7 `: J/ G+ b
; C2 l& W+ c4 B* Z) | - //系统时钟: ~# O+ e+ j/ b8 a
- #define F_CPU 168000000ul& q6 N+ z. {- d( S
- //LED
0 o0 X9 s! V$ {! \ - #define LEDS_CONF_LED1 1 /* green */3 {5 i* m; B; n0 V N. K- C7 K3 A/ ~
- #define LEDS_CONF_LED2 2 /* orange */
7 u6 Z1 R4 Y: o' I - #define LEDS_CONF_LED3 4 /* red */
' p2 j7 P- p+ B( b - #define LEDS_CONF_LED4 8 /* blue */
+ X; j$ C, ]: I% g5 Z _ s+ g - #define LEDS_CONF_LED5 5 /* yellow */
) t) W' ?; K) [% t8 b" w- I
9 @1 d, E1 _) H8 g0 c- #define LEDS_CONF_RED (1<<LEDS_CONF_LED3)' J* ^! D& a) O; _" e
- #define LEDS_CONF_GREEN (1<<LEDS_CONF_LED1)7 W7 [/ [& B/ ~' f' O8 Q+ W7 P
- #define LEDS_CONF_BLUE (1<<LEDS_CONF_LED4)
1 R: h1 S7 T* p
6 l0 i& y/ V' G( w9 C% J7 N a- //#define FIXED_NET_ADDRESS 1$ F6 Q( E) d2 h" \1 H' D! [
- //#define NET_ADDR_A 0x2001
& A3 r3 L9 B& \2 s( J3 ]5 ? - //#define NET_ADDR_B 0xdb8
8 J4 Z. H. F0 ~. D1 E - //#define NET_ADDR_C 0xbbbb
% ?# P2 E9 X, p - //#define NET_ADDR_D 0xabcd
% O6 x* `8 E1 I. B, O - 7 o3 W3 _0 n4 H7 H3 B
- #define UART1_CONF_TX_WITH_INTERRUPT 1 //07 L# j: X+ w+ g$ r/ i
- #define WITH_SERIAL_LINE_INPUT 1 //串口" d- x6 j) ~0 N3 N# u8 R
- #define ENERGEST_CONF_ON 0 //能量估计,失效8 g* r" h( q$ X3 k ?2 E2 A% H
- #define TELNETD_CONF_NUMLINES 6 //telnet服务7 K. S; q8 B( t$ N
- //射频RADIO 驱动
3 S2 a z: ^8 k1 o1 `' w - #define NETSTACK_CONF_RADIO spirit_radio_driver1 }! r" H- d) A* G2 A
- //射频RADIO 最大负载$ n2 U6 U/ A! \$ k6 Q* K
- #define NETSTACK_RADIO_MAX_PAYLOAD_LEN 96 /* spirit1-config.h */
& K' w8 r) X" f; B6 u: u0 J3 r - /*---------------------------------------------------------------------*/
/ m9 H# c2 m! ^* r) h - /* define ticks/second for slow and fast clocks. Notice that these should be a3 y- R, }; a w
- power of two, eg 64,128,256,512 etc, for efficiency as POT's can be optimized
+ U' T5 `5 J( H) n! P - well. */- A+ p$ e& _2 o; v0 f& [4 C8 N; P( Q
- #define CLOCK_CONF_SECOND 2048' {+ K; Z+ D6 T& F; k% |- ?
- // One tick: 85.33 us
* {) G' N. q6 e - #define RTIMER_ARCH_SECOND 168000/*32768*/, c, z) b5 [4 }7 C
- 3 }) {# O( N5 h0 \$ C
- /*--------------------------------------------------------------------*/( i1 Y0 Q' F% Z6 j5 f+ z, G
- #define RTIMER_CLOCK_LT(a,b) ((signed short)((a)-(b)) < 0)
: Z$ }6 h! J5 l; i - 6 b- i% u3 ^- Y8 R+ }
- typedef unsigned long clock_time_t;/ ?8 u; E9 P: B/ G$ J1 w9 F
- typedef unsigned long long rtimer_clock_t;% L; H' @3 Q9 W: \, C) n, p
% M9 p+ H+ }5 p1 Q. r7 z- #define CC_CONF_REGISTER_ARGS 09 b J; B7 A. v+ x3 ^
- #define CC_CONF_FUNCTION_POINTER_ARGS 1- T& B" I% V* y+ \3 A) E
- #define CC_CONF_FASTCALL, _+ K+ N& u/ `9 K0 x
- #define CC_CONF_VA_ARGS 1: u0 F; y2 v, @' B5 J, c7 H+ Y
- #define CC_CONF_INLINE inline# i, d3 A% D' m8 O0 l7 s3 }; H: |! d
- ) b# v1 a3 l" h1 X) L) k' @1 ^
- #define CCIF+ C6 F' Y' W. E, Q* g6 j; V
- #define CLIF6 x& |' B8 L$ ?0 ^( _* z
- : S4 z) y4 }% N8 a) B* ?0 o
- typedef uint8_t u8_t;% L, L0 W) a! l/ Q2 L3 U( P' Y
- typedef uint16_t u16_t;
: Y1 Z& e8 p; P9 {) V& U - typedef uint32_t u32_t;
# f3 U4 y9 N% c: b* s - typedef int32_t s32_t;; z/ s' N" P" F8 v. G6 w
- typedef unsigned short uip_stats_t;
4 P+ f$ C8 C2 A" ], [ - /*--------------------------------------------------------------------*/
7 b6 X! ~1 @1 k+ `% ]0 |
" _2 v4 S4 x" Z$ Q& p) T- #endif /* __PLATFORM_CONF_H__ */
复制代码 $ Q1 y- ~) @. _ g, l6 D! U
4 {9 Q# `% X1 O9 S+ O* g |
8 }" p" Z/ D6 m
contiki-conf配置
$ R% q. r* x1 q, E
