外部中断只能响应一次,求大神指点!
eason1931 提问时间:2014-11-25 10:48 /
使用PB12,PB13,PE14,PE15作为外部中断,PE14,PE15响应正常,但PB12,PB13无法正常进入中断,代码如下,求指点。。
void EXTI15_10_IRQHandler(void)
        //KEY_OK
        if(EXTI_GetITStatus(EXTI_Line14)==SET)
                        IO_OutputData(0x00);
                        delay_us(10);
                        EXTI_ClearITPendingBit(EXTI_Line14);
        //KEY_UP
        if(EXTI_GetITStatus(EXTI_Line15)==SET)
                        IO_OutputData(0xff);
                        delay_us(10);
                        EXTI_ClearITPendingBit(EXTI_Line15);
        //KEY_DOWN
        if(EXTI_GetITStatus(EXTI_Line12)==SET)
                        delay_us(10);
                        EXTI_ClearITPendingBit(EXTI_Line12);
        //KEY_CANCEL
        if(EXTI_GetITStatus(EXTI_Line13)==SET)
                        delay_us(10);
                        EXTI_ClearITPendingBit(EXTI_Line13);
void NVIC_Configuration(void)
        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
        NVIC_InitStructure.NVIC_IRQChannel = USART2_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
        NVIC_InitStructure.NVIC_IRQChannel = EXTI15_10_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 2;
void KEY_config(void)
        GPIO_InitTypeDef        GPIO_InitStructure;
        EXTI_InitTypeDef        EXTI_InitStructure;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOE, ENABLE);
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
        //GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
        GPIO_InitStructure.GPIO_Pin = KEY_OK        |        KEY_UP;
        GPIO_Init(GPIOE, &GPIO_InitStructure);
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
        GPIO_InitStructure.GPIO_Pin = KEY_DOWN        |        KEY_CANCEL;
        GPIO_EXTILineConfig(GPIO_PortSourceGPIOE, GPIO_PinSource14);
        EXTI_InitStructure.EXTI_Line = EXTI_Line14 ;
        EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
        EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling;
        EXTI_InitStructure.EXTI_LineCmd = ENABLE;
        EXTI_Init(&EXTI_InitStructure);
        GPIO_EXTILineConfig(GPIO_PortSourceGPIOE, GPIO_PinSource15);
        EXTI_InitStructure.EXTI_Line = EXTI_Line15 ;
        GPIO_EXTILineConfig(GPIO_PortSourceGPIOB, GPIO_PinSource12);
        EXTI_InitStructure.EXTI_Line = EXTI_Line12 ;
        GPIO_EXTILineConfig(GPIO_PortSourceGPIOB, GPIO_PinSource13);
        EXTI_InitStructure.EXTI_Line = EXTI_Line13;
赞 收藏 评论7 发布时间:2014-11-25 10:48
7个回答
巅峰残狼 回答时间:2014-11-25 11:33:03
在EXTI_ClearITPendingBit(EXTI_Line12);之前加一句EXTI_ClearFlag(EXTI_Line12);试试
eason1931 回答时间:2014-11-25 13:05:47
试了,没能解决问题,这两个函数是一样的吧
bbstr 回答时间:2014-11-26 08:04:01
如果12,13可以进入一次的话,可能配置没啥问题,将你的IO_OutputData贴出来看看,是不是在里面修改了12,13管脚的属性了
eason1931 回答时间:2014-11-26 08:47:37
bbstr 发表于 2014-11-26 08:04
如果12,13可以进入一次的话,可能配置没啥问题,将你的IO_OutputData贴出来看看,是不是在里面修改了12,1 ...
void IO_OutputData(u8 DATA)
        u8 IO_E,IO_B_L,IO_B_H;
        IO_E                =        ((DATA&0x01)<<1)|((DATA&0x02)>>1);
        IO_B_H        =        ((DATA&0x04)>>1)|((DATA&0x08)>>3);
        IO_B_L        =        ((DATA&0x10)<<2)|((DATA&0x40)>>2)|(DATA&0x20)|((DATA&0x80)>>4);
        GPIOE->BSRR = (IO_E & 0xff) | (~IO_E & 0xff)<<16;
        GPIOB->BSRR = (IO_B_L & 0xff)        |        (IO_B_H & 0xff)<<8        |        (~IO_B_L & 0xff)<<16        |        (~IO_B_H & 0xff)<<24;
求大神指点
kingchou2 回答时间:2014-11-26 09:33:09
是不是不能在中断中有延时?为什么在中断中延时delay_us(10)?
eason1931 回答时间:2014-11-26 09:41:46
已解决,果然是 IO_OutputData的问题
        GPIOB->BSRR = (IO_B_L & 0xff)        |        (~IO_B_L & 0xff)<<16        |        (IO_B_H & 0x03)<<8        |        (~IO_B_H & 0x03)<<24;
bbstr 回答时间:2015-2-17 16:29:26
兄弟,如果解决了问题,把我的回复设为最佳答案啊,这样咱俩都有金币得了
