NUCLEO上手之——EXTI:M3和M0的EXTI配置差别
woshilee 提问时间:2014-12-10 11:30 /
#include "stm32f0xx.h"
unsigned char flag=0;
/* Private function prototypes -----------------------------------------------*/
/* Private functions ---------------------------------------------------------*/
  * @brief  Delay
  * @param  None
  * @retval None
void Delay(unsigned int ncount)
  while(ncount--);
  * @brief  GPIO Initial
  * @param  None
  * @retval None
void GPIO_Configuration(void)
  GPIO_InitTypeDef        GPIO_InitStructure;
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN;
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
  GPIO_Init(GPIOC, &GPIO_InitStructure);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
  * @brief  EXTI Initial
  * @param  None
  * @retval None
void EXTI_Configuration(void)
        EXTI_InitTypeDef        EXTI_InitStructure;
        EXTI_InitStructure.EXTI_Line=EXTI_Line13;
        EXTI_InitStructure.EXTI_LineCmd=ENABLE;
        EXTI_InitStructure.EXTI_Mode=EXTI_Mode_Interrupt;
        EXTI_InitStructure.EXTI_Trigger=EXTI_Trigger_Falling;
        EXTI_Init(&EXTI_InitStructure);
        SYSCFG_EXTILineConfig(EXTI_PortSourceGPIOC, EXTI_PinSource13);
  * @param  None
  * @retval None
void RCC_Configuration(void)
        RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOC|RCC_AHBPeriph_GPIOA, ENABLE);
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_SYSCFG, ENABLE);
  * @brief  NVIC Initial
  * @param  None
  * @retval None
void NVIC_Configuration(void)
        NVIC_InitTypeDef        NVIC_InitStructure;
        NVIC_InitStructure.NVIC_IRQChannel=EXTI4_15_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelCmd=ENABLE;
        NVIC_InitStructure.NVIC_IRQChannelPriority=1;
  * @brief  Main program.
  * @param  None
  * @retval None
int main(void)
                RCC_Configuration();
                GPIO_Configuration();
                NVIC_Configuration();
                EXTI_Configuration();
               while (1);
  * @brief  IRQ
  * @param  None
  * @retval None
void EXTI4_15_IRQHandler(void)
  if(EXTI_GetITStatus(EXTI_Line13)==1)
        Delay(0xff);
        if(GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_13)==0)
        while(GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_13)==0);
        GPIOA->ODR ^= GPIO_Pin_5;
  EXTI_ClearFlag(EXTI_Line13);
红色部分是M0和M3不同的部分:
M3中这样配置:GPIO_EXTILineConfig(GPIO_PortSourceGPIOA, GPIO_PinSource0|GPIO_PinSource1);
M0用到l了SYSCFG,就要开启它的时钟
赞 收藏 评论17 发布时间:2014-12-10 11:30
17个回答
谦 回答时间:2015-1-25 15:02:22
为什么F1里面的NVIC的优先级组配置在F0里面没有了呢???NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
难道F0里面不需要配置?
另外好像没有了次占优先级的设置,这个应该是最主要的区别吧
woshilee 回答时间:2014-12-10 14:05:03
巅峰残狼 发表于 2014-12-10 13:09
谢谢分享,确实是不同的地方
独乐乐不如众乐乐!
ataudio 回答时间:2015-1-31 21:32:47
M4也用到了这个,存在这个差别。用 | 同时配置两个中断管脚,不能正常。
巅峰残狼 回答时间:2014-12-10 13:09:00
谢谢分享,确实是不同的地方
谦 回答时间:2015-1-10 23:30:14
感谢~~~~~~~~~~~~~
万里-363223 回答时间:2015-1-11 08:49:35
M0和M3是有些不同的地方,但基本框架相同
我是酱油哥 回答时间:2015-1-11 08:59:14
感谢 分享 啊
kevin0129 回答时间:2015-1-11 10:04:25
M4中也采用了这种方式,这是ST改进的地方吧!
chendiand 回答时间:2015-1-31 19:06:11
谢谢分享
hanmcustm 回答时间:2015-1-31 23:57:53
貌似M0的优先级只有0~3
拼命三郎 回答时间:2015-2-1 00:06:51
拼命三郎 回答时间:2015-2-1 00:07:12
181wh 回答时间:2015-2-1 10:55:39
谢谢分享!
wamcncn 回答时间:2015-2-1 11:02:08
学习才能进步
12下一页
