吐槽一下库文件system_stm32f4xx.c
qianfan 发布时间:2014-12-21 16:01
在库文件中,system_stm32f4xx.c文件里面有这么的代码:
. k2 h, W5 j& w1 X0 T#ifdef DATA_IN_ExtSDRAM9 u3 ?: A4 b. @
/**& L$ P7 W: X* M
  * @brief  Setup the external memory controller.
! b2 `0 F: f1 o( m: B; o( m  B  *         Called in startup_stm32f4xx.s before jump to main.' ^# ?6 l1 n. q  V0 w
  *         This function configures the external SDRAM mounted on STM324x9I_EVAL board
- X) [% C& B: t3 Q; A6 t' H' ?6 I9 S2 u  *         This SDRAM will be used as program data memory (including heap and stack).
2 I6 T5 D& ]$ j: j" a/ @" I( E- p2 s  * @param  None1 C; v0 Z. U1 z: @/ u
  * @retval None
( m. K7 D8 F1 q, w7 Z  */& z4 P0 T; s, S, ^5 b4 m! y
void SystemInit_ExtMemCtl(void)) |1 |2 \+ W! |& U
{6 z# B6 P# ^0 p7 ?  p
  register uint32_t tmpreg = 0, timeout = 0xFFFF;; m4 ~# i; ?4 C7 d  H7 {  v
  register uint32_t index;
4 [6 V2 ~% G) u$ y; r5 m
8 ]% J0 h8 B" |8 w% P7 P! R! ?  /* Enable GPIOC, GPIOD, GPIOE, GPIOF, GPIOG, GPIOH and GPIOI interface
  S7 O! |2 u5 T% q9 j. J      clock */: v/ K' K6 l( c) ^; z! [
  RCC->AHB1ENR |= 0x000001FC;1 Y* N0 x3 ^3 a7 d5 R' _
" Y0 V: i* E; _& B5 z8 R% ]
  /* Connect PCx pins to FMC Alternate function */% B4 F$ p2 \8 ?# F
  GPIOC->AFR[0]  = 0x0000000c;
/ W- m4 l& P* d( ^* u* l. }  GPIOC->AFR[1]  = 0x00007700;
) Q0 o- _7 h  ]# \  /* Configure PCx pins in Alternate function mode */
& k* {' f/ @9 K  O0 y$ f& F  GPIOC->MODER   = 0x00a00002;$ s% Q. v- Q; D' Q3 d# T; e
  /* Configure PCx pins speed to 50 MHz */  # E, K, Z. U: z: k4 {5 |! L% I3 o$ }
  GPIOC->OSPEEDR = 0x00a00002;  l( \- o* e& Y" J/ A
  /* Configure PCx pins Output type to push-pull */
# F3 O" x' i0 N0 |2 R% h  GPIOC->OTYPER  = 0x00000000;
3 j" [3 N% o+ b8 W8 x- p) I  /* No pull-up, pull-down for PCx pins */   w6 H& y# s7 U3 B- N9 h( V  T
  GPIOC->PUPDR   = 0x00500000;# F# G5 I/ u" u$ ]
/ H( E2 S' D- U  /* Connect PDx pins to FMC Alternate function */
- C& h) [+ E) u  `  GPIOD->AFR[0]  = 0x000000CC;. y) s' D6 c1 B! c/ y  p+ s* ~4 _+ s* c
  GPIOD->AFR[1]  = 0xCC000CCC;& i0 P9 }6 V, b1 U% l  |0 `
  /* Configure PDx pins in Alternate function mode */
6 O; F% e$ }8 d  GPIOD->MODER   = 0xA02A000A;8 v9 J3 P$ i' H
  /* Configure PDx pins speed to 50 MHz */  / X; ^( S, v% R$ M( F
  GPIOD->OSPEEDR = 0xA02A000A;
& M! A# \' _& _, K0 T( F  /* Configure PDx pins Output type to push-pull */  , C3 k7 u/ W; H6 q. E
  GPIOD->OTYPER  = 0x00000000;* _% {0 s4 e+ m1 n& y
  /* No pull-up, pull-down for PDx pins */
  n  R& `) @5 b5 A- R' M  GPIOD->PUPDR   = 0x00000000;
9 e' p) V2 t2 @( W7 W
6 C2 T3 L( B! A1 h  /* Connect PEx pins to FMC Alternate function */( k7 S0 k! S( @, O
  GPIOE->AFR[0]  = 0xC00000CC;7 b1 q, q, n! k1 y9 G4 W. Z
  GPIOE->AFR[1]  = 0xCCCCCCCC;
, I: O2 t( p. m: V+ q1 H( t1 H  /* Configure PEx pins in Alternate function mode */
" }. X( G- H/ F& F' \  GPIOE->MODER   = 0xAAAA800A;
! H2 f" j! R8 R  /* Configure PEx pins speed to 50 MHz */ 8 |% H' D+ m3 D
  GPIOE->OSPEEDR = 0xAAAA800A;
! x4 y1 U( }4 d4 ]  /* Configure PEx pins Output type to push-pull */  8 L9 }) }- E9 S' s) i
  GPIOE->OTYPER  = 0x00000000;
1 w& w: H0 i( s/ @2 C5 G  /* No pull-up, pull-down for PEx pins */ # k4 s  N, I  w$ ]0 R* @8 a
  GPIOE->PUPDR   = 0x00000000;
2 O6 g: w# v6 w3 F: Y
2 c- e: A8 c% Q1 e% o/ B  /* Connect PFx pins to FMC Alternate function */. ?, |3 i  ~8 S8 i+ @
  GPIOF->AFR[0]  = 0xcccccccc;
+ \9 A" p6 ?- u, k  GPIOF->AFR[1]  = 0xcccccccc;
7 U& i* l& E) E9 S  /* Configure PFx pins in Alternate function mode */
' a0 W/ }" x/ V1 j2 h4 D  GPIOF->MODER   = 0xAA800AAA;1 p8 I6 }. H4 ~0 s2 s5 Y5 ?# h
  /* Configure PFx pins speed to 50 MHz */ " v1 g9 Z6 K, ?) N! {9 d# C
  GPIOF->OSPEEDR = 0xAA800AAA;
8 `; I" Z5 z5 w! }4 G2 k  /* Configure PFx pins Output type to push-pull */
/ S2 n/ P( _4 T* p, }# r$ `, G  GPIOF->OTYPER  = 0x00000000;
+ m0 d* c$ p$ @2 g0 @  /* No pull-up, pull-down for PFx pins */
% d7 r  Z7 `  _( E  GPIOF->PUPDR   = 0x00000000;
" B' z1 B9 u9 N, M4 }  i8 G6 Q$ B3 p* Q: p
  /* Connect PGx pins to FMC Alternate function */- ~. A$ k4 o( n' k! P) q
  GPIOG->AFR[0]  = 0xcccccccc;
2 S$ D% b/ n% g3 F  GPIOG->AFR[1]  = 0xcccccccc;& c. S* D$ B2 A! N* R1 {: L6 Q5 |
  /* Configure PGx pins in Alternate function mode */
" \, P. L: f* i; q3 W  GPIOG->MODER   = 0xaaaaaaaa;
, `# n/ W3 b- d% M( o  [  /* Configure PGx pins speed to 50 MHz */
  t1 {8 ^3 @8 h3 m  GPIOG->OSPEEDR = 0xaaaaaaaa;
  R  M9 o. D( }" k& n& r0 p  /* Configure PGx pins Output type to push-pull */  7 G/ Z4 E0 I9 W! R% h- T
  GPIOG->OTYPER  = 0x00000000;
6 m4 J. `- `, N) n, x  /* No pull-up, pull-down for PGx pins */
; i) t3 k/ R! `+ J+ }5 O9 @  GPIOG->PUPDR   = 0x00000000;
6 ^/ i; k1 D- d/ P. m& }) z; x9 g1 H% n& O+ N
  /* Connect PHx pins to FMC Alternate function */
& x$ G- N1 T( b2 j" j+ X8 w  GPIOH->AFR[0]  = 0x00C0CC00;
; {( d0 ]/ s$ {) l$ C; Z  GPIOH->AFR[1]  = 0xCCCCCCCC;, i/ C& {1 g6 E' [
  /* Configure PHx pins in Alternate function mode */
: p' `" V" j- ]  i0 ]  GPIOH->MODER   = 0xAAAA08A0;
) G  [  C7 Y- H/ D+ M  /* Configure PHx pins speed to 50 MHz */ ) B' ?1 I7 E1 l2 V* d2 e+ V
  GPIOH->OSPEEDR = 0xAAAA08A0;; B  v; ?, G+ [
  /* Configure PHx pins Output type to push-pull */
7 W* M! z" N5 Z! u  GPIOH->OTYPER  = 0x00000000;: P! ?7 b& B: s8 ]
  /* No pull-up, pull-down for PHx pins */
( n4 g9 n0 d8 z* a3 }4 n  G  GPIOH->PUPDR   = 0x00000000;
7 h/ U2 k' v# O4 O; v) c8 Y2 k/ |/ V1 h
  /* Connect PIx pins to FMC Alternate function */
& ?% O1 c0 m4 c1 o  GPIOI->AFR[0]  = 0xCCCCCCCC;
: s1 k* @. A9 E7 ]. }: m+ \* x  GPIOI->AFR[1]  = 0x00000CC0;- f; m6 Z3 p+ k# a6 V; s- a
  /* Configure PIx pins in Alternate function mode */ * k' O$ H  P/ K" j
  GPIOI->MODER   = 0x0028AAAA;
8 A: h0 i8 G$ O1 G2 d  /* Configure PIx pins speed to 50 MHz */ 1 }/ C5 \& @  N( F0 F* a
  GPIOI->OSPEEDR = 0x0028AAAA;9 t- i6 `6 h3 p1 o& t% ~/ m
  /* Configure PIx pins Output type to push-pull */  9 M! i6 \+ Y" y2 Z" B6 q, f; U" v
  GPIOI->OTYPER  = 0x00000000;
# }# k' K) [9 i  /* No pull-up, pull-down for PIx pins */
4 L5 \" g2 \( Y% |. g  GPIOI->PUPDR   = 0x00000000;
* y! R0 [& k) w8 P0 g5 w7 p: a; B- R' v+ L
/*-- FMC Configuration ------------------------------------------------------*/  A+ Y1 L: c* |
  /* Enable the FMC interface clock */
/ K' }  G) t7 N5 H  RCC->AHB3ENR |= 0x00000001;  s. r1 b6 {: Y& N1 q, ?+ C9 _
" `# c4 q( g% b2 z. c  /* Configure and enable SDRAM bank1 */4 N1 t' D; O0 W6 M: x
  FMC_Bank5_6->SDCR[0] = 0x000039D0;
. ^8 r, z! _$ {- Z  FMC_Bank5_6->SDTR[0] = 0x01115351;      , j4 ?7 B- v2 Z2 R6 \
7 z0 B. A/ L* u  H  /* SDRAM initialization sequence */
) e9 ^% m) y8 w6 D* s  /* Clock enable command */
( o2 F' I& v- t/ n. h) I9 P  FMC_Bank5_6->SDCMR = 0x00000011; 8 |: {6 A* T) u$ i* G8 A  G* d
  tmpreg = FMC_Bank5_6->SDSR & 0x00000020; 0 D6 G5 I0 T( `2 q  X* f
  while((tmpreg != 0) & (timeout-- > 0)): H# M: j& i1 w+ A
& E$ ?# Z6 ?0 U" p  @  C* e  g$ I    tmpreg = FMC_Bank5_6->SDSR & 0x00000020;
5 x  _7 F2 U3 Y0 D2 w: r4 _& h  }
0 m/ D) N9 E: Y6 ?1 P( j, e/ ^8 v* l) a
  /* Delay */: K# t, d, l  L' a, ]  X
  for (index = 0; index<1000; index++);
0 k0 p- o/ U+ \  X$ w2 e1 Y4 I
" `, E# w/ y5 ^. W! v  /* PALL command */' J9 _; s* P2 b
  FMC_Bank5_6->SDCMR = 0x00000012;
, M9 g# Q% W5 {* n, m9 I  timeout = 0xFFFF;" s- N9 z2 M' Y- h
# U/ F2 `) c, |/ x% L  {
( I' ?; z; J- ?9 e# a( s1 V  tmpreg = FMC_Bank5_6->SDSR & 0x00000020;
* D; L0 o$ Z" M4 v  }, d! d) r3 x3 W
# M0 Z% z! p6 T# H  /* Auto refresh command */9 v1 Y( d8 v% b+ ?( Y1 ?
  FMC_Bank5_6->SDCMR = 0x00000073;
, A( M: O. T) p$ Y; |2 Z' A  timeout = 0xFFFF;6 Y* v! l- a/ s+ B% I
  while((tmpreg != 0) & (timeout-- > 0))3 O+ c0 L* k# e8 P
  {$ P& h  R3 @1 l* H  U
  tmpreg = FMC_Bank5_6->SDSR & 0x00000020; 3 F6 B# U# h  ~6 P5 r
) U+ {2 h/ u1 E) V. k, p
: f) V5 x6 g: l  F  /* MRD register program */
) U' o/ w6 J  O" ~5 d  FMC_Bank5_6->SDCMR = 0x00046014;2 `. l1 Q* l$ G, ^, n2 V
  timeout = 0xFFFF;4 P1 t2 i4 _2 B! L4 i% Q
  while((tmpreg != 0) & (timeout-- > 0))& _1 A* g3 P! B' ~  B8 Z
  {. [" R4 a! x, B) a9 e. x4 f# N
  tmpreg = FMC_Bank5_6->SDSR & 0x00000020; - q3 W6 F9 U% O: K# o- g! }
  Z5 V- `8 v( ?9 F# a$ [! Y! ?# d, p
  /* Set refresh count */
6 K9 l, m/ A' x( Z) v! \- ~0 E) e  tmpreg = FMC_Bank5_6->SDRTR;2 I) t6 o  }/ q# W- U2 v
  FMC_Bank5_6->SDRTR = (tmpreg | (0x0000027C<<1));& o/ F* f9 I1 o' R, m5 ?* V5 }" i# @
/ ^! ]5 u# E0 v
  /* Disable write protection */0 ~4 ^* Q- f# E4 q" W9 ~- x
  tmpreg = FMC_Bank5_6->SDCR[0]; $ a/ M$ t0 V7 I, B' A
  FMC_Bank5_6->SDCR[0] = (tmpreg & 0xFFFFFDFF);5 I+ i* Z  s4 I3 i/ U6 S  N3 }) `5 q
! K8 A: g/ H4 i/*0 S1 H! _1 Z9 u  s
  Bank1_SDRAM is configured as follow:- J. J$ c4 b0 T, S. Z7 v
" R  N( |! u) v9 z, R! e  FMC_SDRAMTimingInitStructure.FMC_LoadToActiveDelay = 2;
% k' r1 u0 M, N  k  FMC_SDRAMTimingInitStructure.FMC_ExitSelfRefreshDelay = 6;    _& ^8 M: }: j% Z" I, l* |( e; E
  FMC_SDRAMTimingInitStructure.FMC_SelfRefreshTime = 4;
& ^3 r  S/ m# I# A  FMC_SDRAMTimingInitStructure.FMC_RowCycleDelay = 6;
; J, b9 ]8 i  ~' o+ G7 \- u  FMC_SDRAMTimingInitStructure.FMC_WriteRecoveryTime = 2;      9 `$ I9 f! P2 i: ~+ Z; v# w% {
  FMC_SDRAMTimingInitStructure.FMC_RPDelay = 2;                / b0 S4 T7 C) _+ B' y4 e
  FMC_SDRAMTimingInitStructure.FMC_RCDDelay = 2;
+ r2 b: Q9 {- V& M9 a5 A6 ^
+ b, @; o, e. d0 m- C' s  FMC_SDRAMInitStructure.FMC_Bank = SDRAM_BANK;
! t7 h' H$ R6 V  s1 G0 g6 V& {: E  FMC_SDRAMInitStructure.FMC_ColumnBitsNumber = FMC_ColumnBits_Number_8b;0 i% s5 \) @  E$ U
  FMC_SDRAMInitStructure.FMC_RowBitsNumber = FMC_RowBits_Number_11b;
" k' B) `& P1 I6 O. n. }  FMC_SDRAMInitStructure.FMC_SDMemoryDataWidth = FMC_SDMemory_Width_16b;' w. }( Z1 a# g! l6 T. D
  FMC_SDRAMInitStructure.FMC_InternalBankNumber = FMC_InternalBank_Number_4;
/ B0 e. W1 _/ H' ^4 ~  J8 K  FMC_SDRAMInitStructure.FMC_CASLatency = FMC_CAS_Latency_3;
: Q& D/ `9 h6 j. P  FMC_SDRAMInitStructure.FMC_WriteProtection = FMC_Write_Protection_Disable;3 H9 ~; j, L7 Q4 {3 O: r5 T  n* J
  FMC_SDRAMInitStructure.FMC_SDClockPeriod = FMC_SDClock_Period_2;
7 u, p+ V( `2 R& w  FMC_SDRAMInitStructure.FMC_ReadBurst = FMC_Read_Burst_disable;
; a7 d2 U- B. M: ]  FMC_SDRAMInitStructure.FMC_ReadPipeDelay = FMC_ReadPipe_Delay_1;
' }. _( q/ l8 ^' _8 [$ j  FMC_SDRAMInitStructure.FMC_SDRAMTimingStruct = &FMC_SDRAMTimingInitStructure;
, k$ ^! x6 O& r# p% p- @' a*/2 z. u# _* {; L8 A# s" j- [6 f
% {+ Q* N; q( i0 `}
2 d6 Y5 M; P7 \; k4 z% s: j) j#endif /* DATA_IN_ExtSDRAM */
+ T+ V4 o2 R7 D- k6 @" z2 n* ~+ a+ h1 A+ B" F$ H3 N) c) `6 U% w
1 J7 s; V' _9 C% d( P
很简单,说的就是如果你定义了这个宏,那么就给你初始化一下FMC使用的引脚。
: l. Z, i" S- z$ J我使用了F429 Discovery,在用SDRAM的时候,直接把SDRAM_Init中初始化引脚的代码删了,定义了一个宏DATA_IN_ExtSDRAM来完成初始化引脚的代码。但是当实验的时候却发现不行。
& A* N- `, F" ^最后好好查看了下system_stm32f4xx.c中的代码,也就是上面的代码,发现竟然没有初始化PB5,PB6两个引脚,也正是SDCKE1,SDNE1两个引脚。加上这两个引脚的初始化代码之后程序正常。
8 N& P  r" i" \  V' }& h不知道为什么这里没有设置这两个引脚的模式。吐槽一下。希望用SDRAM的人不要挂在这个地方。+ e3 ]) A3 {0 O6 o
, ^( [% t6 @' t+ u! z; i1 T9 N5 M
赞 收藏 1 评论6 发布时间:2014-12-21 16:01
6个回答
小贾-370388 回答时间:2014-12-22 10:37:35
谢谢分享
wamcncn 回答时间:2014-12-22 12:57:12
帮你吐下
makc 回答时间:2014-12-27 10:25:40
官方库有时是有点锉,版本变动一下subroutine 也跟着变动,不同的库编译出来的结果完全不一样。看你需求了其实自己写底层封装也不会太难。
善良的女性 回答时间:2014-12-27 15:07:02
: Z" D1 G7 a' v
wu1169668869 回答时间:2015-7-28 13:49:13
楼主应该还在论坛
2 A( k5 e# j/ G; K/ v弱弱求个初始化代码,还有要怎么配置那个SDRAM作为数据内存?官方那个例程没跑通。。。
evil简爱 回答时间:2017-2-21 20:09:28
GPIOA GPIOB GPIOC 怎么加。。。我好像也遇到了这个问题
