今天测试液晶屏附带的AT24C02,都说STM32的I2C是个鸡肋,但是之前用103的I2C、030的I2C 都能驱动,不过大数据操作不知道效果,没有试过,但是STM8的I2C到目前为止,真心没有跑过去,今天再测下072的I2C吧。 直接跑之前030操作256K的EPROM,发现数据异常,查看手册发现02的内存地址只需要1个字节,改了之后,发现还是有异常,前几个字节是正常的(联系写50字节),后面的全都是0xFF,但是单个字节的写50次都没有问题,然后又对照数据手册看,发现02的连续写最大只支持8字节(256K的支持128字节,也就是page的size定义不同),8字节的连续写感觉和单字节的写 没有啥区别就没在继续测试了,这里贴出读写的核心代码,供大家参考下 0 Z! O8 D5 F# E初始化: void I2C_uConfiguration(void)& i# c: o6 w4 X0 r5 ^ { I2C_InitTypeDef I2C_uInitStructure;% a- R1 r/ _; q# T) M" |. c U GPIO_InitTypeDef GPIO_uInitStructure; . t# h% D. k; a7 T& M RCC_I2CCLKConfig(RCC_I2C1CLK_SYSCLK); ; y) `* Y. z+ ? RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOB,ENABLE); RCC_APB1PeriphClockCmd(RCC_APB1Periph_I2C1,ENABLE);7 B, l$ J7 Z+ K7 {: \ // I2C1_SCL -> PB8 # E4 m+ D' U, r. G // I2C1_SDA -> PB90! q- X" n7 u2 ~$ \( |) ^9 ]* v3 Y# Y GPIO_PinAFConfig(GPIOB,GPIO_PinSource8,GPIO_AF_1);9 c* `4 r5 u2 @# O6 K+ W% y1 B% D. v GPIO_PinAFConfig(GPIOB,GPIO_PinSource9,GPIO_AF_1); 3 L7 `: y, g/ Z S, V/ r6 I: B9 ^ GPIO_uInitStructure.GPIO_Pin = GPIO_Pin_8 | GPIO_Pin_9; GPIO_uInitStructure.GPIO_Mode = GPIO_Mode_AF; GPIO_uInitStructure.GPIO_OType = GPIO_OType_PP; GPIO_uInitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;/ j) J2 i( ?7 P, h* q/ ^+ k$ Z GPIO_uInitStructure.GPIO_Speed = GPIO_Speed_Level_3; // 10M+ T0 ? s$ W) S6 J GPIO_Init(GPIOB,&GPIO_uInitStructure);- ?3 [4 k9 k. \/ d0 Q% V1 q I2C_uInitStructure.I2C_Mode = I2C_Mode_I2C; I2C_uInitStructure.I2C_Ack = I2C_Ack_Enable; I2C_uInitStructure.I2C_AnalogFilter = I2C_AnalogFilter_Enable;6 z" p, `& n, C, F; x$ H" a I2C_uInitStructure.I2C_DigitalFilter = 0; I2C_uInitStructure.I2C_Timing = 0x40B22536;" f2 b4 m, ?" O6 U6 ?' r* } I2C_uInitStructure.I2C_OwnAddress1 = 0;3 v1 z4 H1 b |7 T) \5 Z I2C_uInitStructure.I2C_AcknowledgedAddress = I2C_AcknowledgedAddress_7bit; I2C_Init(I2C1,&I2C_uInitStructure);0 s, m! V3 P1 O" S5 M! S I2C_Cmd(I2C1,ENABLE);% W/ p6 {* K3 [* f( d } 7 _ b( r$ ^+ K- q/ y4 m / ?, h" ~5 M. C5 \5 o$ t: q4 H 连续读: void I2C_uReadData(INT8U SlaveAddr,INT8U ReadAddr,INT8U ReadLen,INT8U *ReadBuf) {5 m4 ^* l- H8 \* O, T- m INT8U i;/ n8 o& D' j+ |( _$ ]! C b% L( C8 e while(I2C_GetFlagStatus(I2C1,I2C_FLAG_BUSY)); I2C_TransferHandling(I2C1,SlaveAddr,1,I2C_SoftEnd_Mode,I2C_Generate_Start_Write);+ V. _- e6 y) Y while(I2C_GetFlagStatus(I2C1,I2C_FLAG_TXIS) == RESET);# O2 |8 J9 x# z1 t" A I2C_SendData(I2C1,ReadAddr);! q9 R. [% U$ j while(I2C_GetFlagStatus(I2C1,I2C_FLAG_TC) == RESET);7 k: t* R8 W% L I2C_TransferHandling(I2C1,SlaveAddr,ReadLen,I2C_AutoEnd_Mode,I2C_Generate_Start_Read); for(i=0;i<ReadLen;i++) {, K( I$ ]7 l3 t' E; h: ^ while(I2C_GetFlagStatus(I2C1,I2C_FLAG_RXNE) == RESET);. F/ l5 j% K# g# ~% m( U ReadBuf[i] = I2C_ReceiveData(I2C1);* N ]" T9 t+ T( V. k }* E8 ^( d7 l) |7 P while(I2C_GetFlagStatus(I2C1,I2C_FLAG_STOPF) == RESET); } [( S- E( y' ] x1 ] 9 b5 s7 [* w8 q1 i% d9 f 字节写:6 h0 p6 Y' A" L0 O! E! ?" w8 n& H void I2C_uWriteByte(INT8U SlaveAddr,INT8U WriteAddr,INT8U Data) { INT8U i;& [% J0 Q* f9 B ^$ }; X; p# V7 O while(I2C_GetFlagStatus(I2C1,I2C_FLAG_BUSY)); I2C_TransferHandling(I2C1,SlaveAddr,1,I2C_Reload_Mode,I2C_Generate_Start_Write);( O: l: M3 h) S: V5 p6 k% ?) l2 p while(I2C_GetFlagStatus(I2C1,I2C_FLAG_TXIS) == RESET);* C# a" R9 Y! Z I2C_SendData(I2C1,WriteAddr); while(I2C_GetFlagStatus(I2C1,I2C_FLAG_TCR) == RESET);* {" q* c* R) B7 G/ s0 \7 M; V) J5 K) z I2C_TransferHandling(I2C1,SlaveAddr,1,I2C_AutoEnd_Mode,I2C_No_StartStop); while(I2C_GetFlagStatus(I2C1,I2C_FLAG_TXIS) == RESET);/ P0 V+ h6 L+ ~- W) a! G I2C_SendData(I2C1, Data);- [1 t3 l- J g" Z" ^( S8 V ~ while(I2C_GetFlagStatus(I2C1,I2C_FLAG_STOPF) == RESET);( X7 @% Q: m8 o" x0 f I2C_ClearFlag(I2C1, I2C_ICR_STOPCF);. a7 G Z* M1 H6 |4 n8 t7 T Delay_ms(5);+ K/ D$ E# h0 @' n+ u; K }2 u& N6 N) @; h1 X% B* O6 U4 c : Z4 N% Z* X) N* K I! E3 |0 k. }+ r' N& {+ p ( {( [' p9 j2 W7 O0 L2 S* h. P 1 |. L% I, Z- L% E# p" H5 r |
稳定性是没有测试过,不过有产品偶尔死机,现在想是不是I2C导致的看门狗复位呢 还没有来得及验证……
见该贴 :https://www.stmcu.org.cn/module/forum/thread-598677-1-1.html
STM8的 我也是一直用的模拟 一直搞不通 呵呵
共同学习!
正在更新中 嘿嘿
