两个ADC不能同时用,请高手赐教!
AnnaLi 提问时间:2015-1-9 13:21 /
2 ADC conflict in SMT32F429-iDisco
我需要用两ADC,第一ADC我用
SMT32F429-iDisco 中的 ADC3 in STM32F429I-Discovery_FW_V1.0.1。 这个能用。第二个ADC2在这个的基础上改了一下,当我只用ADC3时,正常。但同时用两个, 就两个都不读不了数据。
我哪里做错了?
ADC3:
  #define ADC3_DR_ADDRESS     ((uint32_t)0x4001224C)
static void ADC3_CH13_DMA_Config(void)
  ADC_InitTypeDef       ADC_InitStructure;
  ADC_CommonInitTypeDef ADC_CommonInitStructure;
  DMA_InitTypeDef       DMA_InitStructure;
  GPIO_InitTypeDef      GPIO_InitStructure;
  /* Enable ADC3, DMA2 and GPIO clocks ****************************************/
  RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2 | RCC_AHB1Periph_GPIOC, ENABLE);
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC3, ENABLE);
  /* DMA2 Stream0 channel2 configuration **************************************/
  DMA_InitStructure.DMA_Channel = DMA_Channel_2;
  DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)ADC3_DR_ADDRESS;
  DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)&uhADC3ConvertedValue;
  DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory;
  DMA_InitStructure.DMA_BufferSize = 1;
  DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Disable;
  DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
  DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
  DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
  DMA_InitStructure.DMA_Priority = DMA_Priority_High;
  DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;
  DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull;
  DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
  DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
  DMA_Init(DMA2_Stream0, &DMA_InitStructure);
  DMA_Cmd(DMA2_Stream0, ENABLE);
  /* Configure ADC3 Channel13 pin as analog input ******************************/
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN;
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL ;
  GPIO_Init(GPIOC, &GPIO_InitStructure);
  /* ADC Common Init **********************************************************/
  ADC_CommonInitStructure.ADC_Mode = ADC_Mode_Independent;
  ADC_CommonInitStructure.ADC_Prescaler = ADC_Prescaler_Div2;
  ADC_CommonInitStructure.ADC_DMAAccessMode = ADC_DMAAccessMode_Disabled;
  ADC_CommonInitStructure.ADC_TwoSamplingDelay = ADC_TwoSamplingDelay_5Cycles;
  ADC_CommonInit(&ADC_CommonInitStructure);
  /* ADC3 Init ****************************************************************/
  ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;
  ADC_InitStructure.ADC_ScanConvMode = DISABLE;
  ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
  ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None;
  ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_T1_CC1;
  ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
  ADC_InitStructure.ADC_NbrOfConversion = 1;
  ADC_Init(ADC3, &ADC_InitStructure);
  /* ADC3 regular channel13 configuration *************************************/
  ADC_RegularChannelConfig(ADC3, ADC_Channel_13, 1, ADC_SampleTime_480Cycles);
/* Enable DMA request after last transfer (Single-ADC mode) */
  ADC_DMARequestAfterLastTransferCmd(ADC3, ENABLE);
  /* Enable ADC3 DMA */
  ADC_DMACmd(ADC3, ENABLE);
  /* Enable ADC3 */
  ADC_Cmd(ADC3, ENABLE);
ADC2:
  #define ADC2_DR_ADDRESS     ((uint32_t)0x4001225C)
static void ADC2_CH12_DMA_Config(void)
  /* Enable ADC2, DMA2 and GPIO clocks ****************************************/
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC2, ENABLE);
  DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)ADC2_DR_ADDRESS;
  DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)&uhADC2ConvertedValueC;
  /* Configure ADC2 Channel12 pin as analog input ******************************/
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
  /* ADC2 Init ****************************************************************/
  ADC_Init(ADC2, &ADC_InitStructure);
  /* ADC2 regular channel13 configuration *************************************/
  ADC_RegularChannelConfig(ADC2, ADC_Channel_12, 1, ADC_SampleTime_480Cycles);
  ADC_DMARequestAfterLastTransferCmd(ADC2, ENABLE);
  /* Enable ADC2 DMA */
  ADC_DMACmd(ADC2, ENABLE);
  /* Enable ADC2 */
  ADC_Cmd(ADC2, ENABLE);
谢谢
赞 收藏 评论4 发布时间:2015-1-9 13:21
4个回答
fengye5340 回答时间:2015-1-9 13:37:14
In multi ADC mode, the start of conversion is triggered alternately or simultaneously by the
ADC1 master to the ADC2 and ADC3 slaves, depending on the mode selected by the
MULTI[4:0] bits in the ADC_CCR register.
楼主,研究一下这句话,你就明白了,在429中要2个ADC或3个ADC同时用的话,必须用到ADC1做为主,ADC2或者ADC3作为从,ADC1可以选择性1个或2个从设备进行触发,你这里只用ADC2和ADC3,是不能同时工作的。你换成ADC1和ADC2或者ADC1和ADC3就可以了
AndyYau-268557 回答时间:2015-1-9 13:46:27
楼上的正解。学习了。看来学好英语也很重要
AnnaLi 回答时间:2015-1-9 21:55:33
fengye5340,
您好。我把ADC2改为ADC1了。并把改成  DMA_InitStructure.DMA_Channel = DMA_Channel_0;
static void ADC1_CH12_DMA_Config(void)
  /* Enable ADC1, DMA2 and GPIO clocks ****************************************/
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);
  /* DMA2 Stream0 channel0 configuration **************************************/
  DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)ADC1_DR_ADDRESS;
  DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)&uhADC1ConvertedValueC;
  /* Configure ADC1 Channel12 pin as analog input ******************************/
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;
  /* ADC1 Init ****************************************************************/
  ADC_Init(ADC1, &ADC_InitStructure);
  /* ADC1 regular channel13 configuration *************************************/
  ADC_RegularChannelConfig(ADC1, ADC_Channel_12, 1, ADC_SampleTime_480Cycles);
  ADC_DMARequestAfterLastTransferCmd(ADC1, ENABLE);
  /* Enable ADC1 DMA */
  ADC_DMACmd(ADC1, ENABLE);
  /* Enable ADC1 */
  ADC_Cmd(ADC1, ENABLE);
问题还是存在。
五哥1 回答时间:2018-5-25 00:13:00
先单独测试ADC1,ADC3然后再合成测试,确保程序设置无误。
