使用系统滴答作按键扫描的问题
wamcncn 提问时间:2015-1-22 21:24 /
使用系统滴答定时中断,基于按键的状态机怎么只能1个1个+,不能连+
#define KEY1_USER                        GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_13)
unsigned char Key_Scan(void)
  static unsigned int KeyStateTemp = 0, KeyTime=0;  //按键状态及按键时间
  static unsigned char num=0;            //  按键次数
switch(KeyStateTemp)
  case StateInit:
   if(!KEY1_USER)
    KeyStateTemp = StateAffirm;
   break;
  case StateAffirm:
   if(!KEY1_USER)
    KeyTime = 0;
    KeyStateTemp = StateSingle;
   else KeyStateTemp = StateInit;
   break;
  case StateSingle:
   if(KEY1_USER )
    num++;
    if(125== num)  num = 0;
   else if(++KeyTime > 1000)  //按键时间1000*1MS
    KeyStateTemp = StateRepeat;
     KeyTime = 0;
   break;
  case StateRepeat:
   if(KEY1_USER )
   else
    if(++KeyTime > 200)   //按键时间
     KeyTime = 0;
     num++;
    break;
   break;
        default: KeyStateTemp = KeyStateTemp = StateInit; break;
  return num;
收藏 评论0 发布时间:2015-1-22 21:24
