TIM8捕获,TIM1pwm输出问题
shouliudan 提问时间:2015-1-24 13:30 /
  1. #include "stm32f10x.h"
  2. void RCC_Configuration(void);
  3. void GPIO_Configuration(void);
  4. void TIM8_Configuration(void);
  5. void TIM1_Configuration(void);
  6. int main(void)
  7. {
  8.           RCC_Configuration();
  9.           GPIO_Configuration();
  10.           TIM8_Configuration();
  11.     TIM1_Configuration();
  12.           while(1);
  13. }
  14. void GPIO_Configuration()
  15. {
  16.   GPIO_InitTypeDef GPIO_InitStructure;
  17.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8;
  18.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
  19.         GPIO_Init(GPIOC , &GPIO_InitStructure);
  20.         GPIO_InitStructure.GPIO_Pin =GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10;
  21.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  22.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  23.         GPIO_Init(GPIOA , &GPIO_InitStructure);
  24. }
  25. void RCC_Configuration(void)
  26. {
  27.         ErrorStatus HSEStartUpStatus;
  28.           RCC_DeInit();
  29.           RCC_HSEConfig(RCC_HSE_ON);
  30.           HSEStartUpStatus = RCC_WaitForHSEStartUp();
  31.           if(HSEStartUpStatus == SUCCESS)
  32.           {
  33.             RCC_HCLKConfig(RCC_SYSCLK_Div1);
  34.             RCC_PCLK2Config(RCC_HCLK_Div1);
  35.             RCC_PCLK1Config(RCC_HCLK_Div2);
  36.                         RCC_ADCCLKConfig(RCC_PCLK2_Div6);
  37.             FLASH_SetLatency(FLASH_Latency_2);
  38.       FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
  39.             RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
  40.             RCC_PLLCmd(ENABLE);
  41.             while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
  42.             RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
  43.             while(RCC_GetSYSCLKSource() != 0x08);
  44.           }
  45.                 RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_GPIOA, ENABLE);
  46.                 RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1|RCC_APB2Periph_TIM8, ENABLE);
  47. }
  48. void TIM8_Configuration(void)
  49. {
  50.         TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
  51.         TIM_ICInitTypeDef  TIM_ICInitStructure;
  52.   TIM_TimeBaseStructure.TIM_Period = 65000;
  53.         TIM_TimeBaseStructure.TIM_Prescaler=1000-1;
  54.         TIM_TimeBaseStructure.TIM_ClockDivision=TIM_CKD_DIV1;
  55.         TIM_TimeBaseStructure.TIM_CounterMode=TIM_CounterMode_Up;
  56.         TIM_TimeBaseInit(TIM8,&TIM_TimeBaseStructure);
  57.         TIM_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Rising ;
  58.         TIM_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI;
  59.   TIM_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1;
  60.         TIM_ICInitStructure.TIM_ICFilter = 0xF;                                                   //这句即使放在本函数的最后TIM1也没有输出
  61.         TIM_ICInitStructure.TIM_Channel = TIM_Channel_1;
  62.         TIM_ICInit(TIM8, &TIM_ICInitStructure);
  63.         TIM_ICInitStructure.TIM_Channel = TIM_Channel_2;
  64.         TIM_ICInit(TIM8, &TIM_ICInitStructure);
  65.         TIM_ICInitStructure.TIM_Channel = TIM_Channel_3;
  66.         TIM_ICInit(TIM8, &TIM_ICInitStructure);
  67.         TIM_ITConfig(TIM8, TIM_IT_CC1|TIM_IT_CC2|TIM_IT_CC3,ENABLE);
  68.         TIM_Cmd(TIM1,ENABLE);
  69. }
  70. void TIM1_Configuration(void)
  71. {
  72.         TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
  73.         TIM_OCInitTypeDef TIM_OCInitStructure;
  74.         TIM_TimeBaseStructure.TIM_Period = 90-1;
  75.         TIM_TimeBaseStructure.TIM_Prescaler=10000-1;
  76.         TIM_TimeBaseStructure.TIM_ClockDivision=TIM_CKD_DIV1;
  77.         TIM_TimeBaseStructure.TIM_CounterMode=TIM_CounterMode_CenterAligned1;
  78.         TIM_TimeBaseInit(TIM1,&TIM_TimeBaseStructure);
  79.         TIM_OCInitStructure.TIM_OCMode=TIM_OCMode_PWM2;
  80.         TIM_OCInitStructure.TIM_OutputState=TIM_OutputState_Enable;
  81.         TIM_OCInitStructure.TIM_OutputNState=TIM_OutputState_Disable;
  82.         TIM_OCInitStructure.TIM_Pulse=0;
  83.         TIM_OCInitStructure.TIM_OCPolarity=TIM_OCPolarity_High;
  84.         TIM_OC1Init(TIM1,&TIM_OCInitStructure);
  85.         TIM_OC2Init(TIM1,&TIM_OCInitStructure);
  86.         TIM_OC3Init(TIM1,&TIM_OCInitStructure);
  87.         TIM_OC4Init(TIM1,&TIM_OCInitStructure);
  88.         TIM_OC1PreloadConfig(TIM1, TIM_OCPreload_Enable);
  89.         TIM_OC2PreloadConfig(TIM1, TIM_OCPreload_Enable);
  90.         TIM_OC3PreloadConfig(TIM1, TIM_OCPreload_Enable);
  91.         TIM_SetCompare1(TIM1,10);
  92.         TIM_SetCompare2(TIM1,20);
  93.         TIM_SetCompare3(TIM1,30);
  94.         TIM_CtrlPWMOutputs(TIM1,ENABLE);
  95.         TIM_Cmd(TIM1,ENABLE);
  96.
  97. }
这个程序是设置TIM8进行捕获,TIM1进行PWM输出。TIM1没有输出。如果在主程序中先写TIM1在写TIM8,TIM1输出正常。如果在TIM8的配置中设置滤波为0x0;TIM1有输出。如果在TIM1中取消通道1的设置,TIM1有输出。如果在TIM1设置最后重新设置TIM1->CR2=0x0;TIM1有输出。以上情况都可以使TIM1有输出,调试过程中观察TIM1寄存器,TIM->CR2和TIM1->CRC会被意外改变。不能解释以上各种原因。
赞 收藏 评论8 发布时间:2015-1-24 13:30
8个回答
Dylan疾风闪电 回答时间:2015-1-24 13:51:52
   73     TIM_ITConfig(TIM8, TIM_IT_CC1|TIM_IT_CC2|TIM_IT_CC3,ENABLE);
   74     TIM_Cmd(TIM1,ENABLE); //这里的寄存器错了!!!
第74行代码写错了,你TIM8没有被使能。-----------------------------------------------------
其他问题没有细看,大致浏览了一下,先找到了这一处。
shouliudan 回答时间:2015-1-24 14:22:37
那个可能是写错了,主要是TIM1的问题困扰着我。
shouliudan 回答时间:2015-1-24 14:26:38
是这样的,在一个程序里单独出现高级定时器的PWM输出或者捕获功能都是没有问题的,但是如果在同一个程序里用到两个定时器的话就出现问题了,如以上描述。
shouliudan 回答时间:2015-1-24 18:12:59
还有就是直接写寄存器就不会出现问题。 TIM_ICInitStructure.TIM_ICFilter = 0xF; 这句无论出现在void TIM8_Configuration(void)的任何位置都会使TIM1没有输出。刚把TIM1改为TIM2,没有出现问题。
真的很无解为什么会这样。
zzz111xxx 回答时间:2015-1-24 22:56:09
赞一个
wyxy163@126.com 回答时间:2015-1-25 14:49:42
qimeiya 回答时间:2015-5-13 15:59:24
支持一下
mark0668 回答时间:2015-5-13 16:13:24
TIM1  和 TIM8  断路和死区寄存器 (TIMx_BDTR)
位 15 MOE:主输出使能 (Main output enable)
只要断路输入变为有效状态,此位便由硬件异步清零。此位由软件置 1,也可根据 AOE 位状
态自动置 1。此位仅对配置为输出的通道有效。
0:OC 和 OCN 输出禁止或被强制为空闲状态。
1:如果 OC 和 OCN 输出的相应使能位(TIMx_CCER 寄存器中的 CCxE 和 CCxNE 位)均
置 1,则使能 OC 和 OCN 输出。
有关详细信息,请参见 OC/OCN 使能说明( 第 379  页的第 14.4.9  节: TIM1  和 TIM8  捕获 /
比较使能寄存器 (TIMx_CCER))。
要使能PWM 才会有输出的
