HAL库的DMA串口发送接收问题
a208hlc-57526 提问时间:2015-1-30 14:27 /
昨天看HAL库的串口收发函数,DMA方式,发现函数里竟然有收发同步的操作,但不太确定,莫非HAL的串口DMA方式下不能实现独立的全双工通信么?
收藏 评论7 发布时间:2015-1-30 14:27
7个回答
cxtarm 回答时间:2015-1-30 15:25:30
贴个代码看看
大秦正声 回答时间:2015-1-30 15:32:34
关注!没用过
a208hlc-57526 回答时间:2015-1-30 21:12:47
  * @brief  Receives an amount of data in non blocking mode.
  * @param  huart: pointer to a UART_HandleTypeDef structure that contains
  *                the configuration information for the specified UART module.
  * @param  pData: Pointer to data buffer
  * @param  Size: Amount of data to be received
  * @note   When the UART parity is enabled (PCE = 1) the data received contain the parity bit.
  * @retval HAL status
HAL_StatusTypeDef HAL_UART_Receive_DMA(UART_HandleTypeDef *huart, uint8_t *pData, uint16_t Size)
  uint32_t *tmp;
  uint32_t tmp1 = 0;
  tmp1 = huart->State;
  if((tmp1 == HAL_UART_STATE_READY) || (tmp1 == HAL_UART_STATE_BUSY_TX))
    if((pData == NULL ) || (Size == 0))
      return HAL_ERROR;
    /* Process Locked */
    __HAL_LOCK(huart);
    huart->pRxBuffPtr = pData;
    huart->RxXferSize = Size;
    huart->ErrorCode = HAL_UART_ERROR_NONE;
    /* Check if a transmit process is ongoing or not */
    if(huart->State == HAL_UART_STATE_BUSY_TX)
      huart->State = HAL_UART_STATE_BUSY_TX_RX;
    else
      huart->State = HAL_UART_STATE_BUSY_RX;
    /* Set the UART DMA transfer complete callback */
    huart->hdmarx->XferCpltCallback = UART_DMAReceiveCplt;
    /* Set the UART DMA Half transfer complete callback */
    huart->hdmarx->XferHalfCpltCallback = UART_DMARxHalfCplt;
    /* Set the DMA error callback */
    huart->hdmarx->XferErrorCallback = UART_DMAError;
    /* Enable the DMA Stream */
    tmp = (uint32_t*)&pData;
    HAL_DMA_Start_IT(huart->hdmarx, (uint32_t)&huart->Instance->DR, *(uint32_t*)tmp, Size);
    /* Enable the DMA transfer for the receiver request by setting the DMAR bit
    in the UART CR3 register */
    huart->Instance->CR3 |= USART_CR3_DMAR;
    /* Process Unlocked */
    __HAL_UNLOCK(huart);
    return HAL_OK;
  else
    return HAL_BUSY;
a208hlc-57526 回答时间:2015-1-30 21:13:15
  * @brief  Sends an amount of data in non blocking mode.
  * @param  Size: Amount of data to be sent
HAL_StatusTypeDef HAL_UART_Transmit_DMA(UART_HandleTypeDef *huart, uint8_t *pData, uint16_t Size)
  uint32_t *tmp;
  uint32_t tmp1 = 0;
  if((tmp1 == HAL_UART_STATE_READY) || (tmp1 == HAL_UART_STATE_BUSY_RX))
      return HAL_ERROR;
    __HAL_LOCK(huart);
    huart->pTxBuffPtr = pData;
    huart->TxXferSize = Size;
    huart->TxXferCount = Size;
    /* Check if a receive process is ongoing or not */
    if(huart->State == HAL_UART_STATE_BUSY_RX)
    else
      huart->State = HAL_UART_STATE_BUSY_TX;
    huart->hdmatx->XferCpltCallback = UART_DMATransmitCplt;
    huart->hdmatx->XferHalfCpltCallback = UART_DMATxHalfCplt;
    huart->hdmatx->XferErrorCallback = UART_DMAError;
    /* Enable the UART transmit DMA Stream */
    HAL_DMA_Start_IT(huart->hdmatx, *(uint32_t*)tmp, (uint32_t)&huart->Instance->DR, Size);
    /* Enable the DMA transfer for transmit request by setting the DMAT bit
    huart->Instance->CR3 |= USART_CR3_DMAT;
    return HAL_OK;
  else
    return HAL_BUSY;
a208hlc-57526 回答时间:2015-1-30 21:13:54
已经附上代码了,需要源文件不?
cxtarm 回答时间:2015-1-31 11:59:24
a208hlc-57526 发表于 2015-1-30 21:13
已经附上代码了,需要源文件不?
根据你贴的代码,应该是全双工的。
HenryChen 回答时间:2015-7-2 09:58:11
学习中……感谢分享!
