通用定时器的PWM输入捕捉模式下四个通道能同时进行捕捉?
布衣灬强 提问时间:2015-1-30 21:21 /
通用定时器的PWM输入捕捉模式下,定时器的四个通道能同时进行PWM捕捉么?
赞 收藏 1 评论6 发布时间:2015-1-30 21:21
6个回答
hmillionaire 回答时间:2015-1-30 22:32:43
我感觉不能,应该有时间先后顺序,这是我的想法,嘿嘿,菜鸟的想法。我渴望找出答案
lkl0305 回答时间:2015-1-31 09:12:40
楼主实验一下啊
holts1 回答时间:2015-1-31 09:21:15
可  以的
布衣灬强 回答时间:2015-1-31 09:49:22
  1. void TIM_Config(void)
  2. {
  3.         GPIO_InitTypeDef GPIO_InitStructure;
  4.         NVIC_InitTypeDef NVIC_InitStructure;
  5.         TIM_ICInitTypeDef  TIM_ICInitStructure;
  6.         /* TIM4 clock enable */
  7.         RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4, ENABLE);
  8.         /* GPIOB clock enable */
  9.         RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB, ENABLE);
  10.         /* TIM4 chennel2 configuration : PB.07 */
  11.         GPIO_InitStructure.GPIO_Pin   = GPIO_Pin_6;
  12.         GPIO_InitStructure.GPIO_Mode  = GPIO_Mode_AF;
  13.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;
  14.         GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
  15.         GPIO_InitStructure.GPIO_PuPd  = GPIO_PuPd_UP ;
  16.         GPIO_Init(GPIOB, &GPIO_InitStructure);
  17.
  18.         GPIO_InitStructure.GPIO_Pin   = GPIO_Pin_7;
  19.         GPIO_InitStructure.GPIO_Mode  = GPIO_Mode_AF;
  20.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;
  21.         GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
  22.         GPIO_InitStructure.GPIO_PuPd  = GPIO_PuPd_UP ;
  23.         GPIO_Init(GPIOB, &GPIO_InitStructure);
  24.
  25.         GPIO_InitStructure.GPIO_Pin   = GPIO_Pin_8;
  26.         GPIO_InitStructure.GPIO_Mode  = GPIO_Mode_AF;
  27.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;
  28.         GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
  29.         GPIO_InitStructure.GPIO_PuPd  = GPIO_PuPd_UP ;
  30.         GPIO_Init(GPIOB, &GPIO_InitStructure);
  31.
  32.         GPIO_InitStructure.GPIO_Pin   = GPIO_Pin_9;
  33.         GPIO_InitStructure.GPIO_Mode  = GPIO_Mode_AF;
  34.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;
  35.         GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
  36.         GPIO_InitStructure.GPIO_PuPd  = GPIO_PuPd_UP ;
  37.         GPIO_Init(GPIOB, &GPIO_InitStructure);
  38.
  39.         /* Connect TIM pin to AF2 */
  40.         GPIO_PinAFConfig(GPIOB, GPIO_PinSource6, GPIO_AF_TIM4);
  41.         GPIO_PinAFConfig(GPIOB, GPIO_PinSource7, GPIO_AF_TIM4);
  42.         GPIO_PinAFConfig(GPIOB, GPIO_PinSource8, GPIO_AF_TIM4);
  43.         GPIO_PinAFConfig(GPIOB, GPIO_PinSource9, GPIO_AF_TIM4);
  44.
  45.         /* Enable the TIM4 global Interrupt */
  46.         NVIC_InitStructure.NVIC_IRQChannel = TIM4_IRQn;
  47.         NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  48.         NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
  49.         NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  50.         NVIC_Init(&NVIC_InitStructure);
  51.
  52.         TIM_ICInitStructure.TIM_Channel = TIM_Channel_4;
  53.         TIM_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Rising;
  54.         TIM_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI;
  55.         TIM_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1;
  56.         TIM_ICInitStructure.TIM_ICFilter = 0x0;
  57.         TIM_PWMIConfig(TIM4, &TIM_ICInitStructure);
  58.         /* Select the TIM4 Input Trigger: TI2FP2 */
  59.         TIM_SelectInputTrigger(TIM4, TIM_TS_TI2FP2);
  60.         /* Select the slave Mode: Reset Mode */
  61.         TIM_SelectSlaveMode(TIM4, TIM_SlaveMode_Reset);
  62.         TIM_SelectMasterSlaveMode(TIM4,TIM_MasterSlaveMode_Enable);
  63.         /* TIM enable counter */
  64.         TIM_Cmd(TIM4, ENABLE);
  65.         /* Enable the CC2 Interrupt Request */
  66.         TIM_ITConfig(TIM4, TIM_IT_CC1, ENABLE);
  67. }
  1. void TIM4_IRQHandler(void)
  2. {
  3.   RCC_ClocksTypeDef RCC_Clocks;
  4.   RCC_GetClocksFreq(&RCC_Clocks);
  5.   /* Clear TIM4 Capture compare interrupt pending bit */
  6.   TIM_ClearITPendingBit(TIM4, TIM_IT_CC2);
  7.   /* Get the Input Capture value */
  8.   IC2Value = TIM_GetCapture2(TIM4);
  9.   if (IC2Value != 0)
  10.   {
  11.     /* Duty cycle computation */
  12.     DutyCycle = (TIM_GetCapture1(TIM4) * 100) / IC2Value;
  13.     /* Frequency computation
  14.        TIM4 counter clock = (RCC_Clocks.HCLK_Frequency)/2 */
  15.     Frequency = (RCC_Clocks.HCLK_Frequency)/2 / IC2Value;
  16.   }
  17.   else
  18.   {
  19.     DutyCycle = 0;
  20.     Frequency = 0;
  21.   }
  22. }
布衣灬强 回答时间:2015-1-31 09:50:15
这样配置后TIM_GetCapture2(TIM4)一直是0。
布衣灬强 回答时间:2015-1-31 09:52:17
B9是通道4
