stm32f427的I2S问题
colengol 提问时间:2015-2-1 10:39 /
最近项目中用到I2S,研究过官方手册和例程后,准备自己配置下,但是第一步主时钟输出就失败了!主时钟输出是用示波器监测的,以下是代码,请大家帮忙看下,在下感激不尽!谢谢>>>
/* Exported define ------------------------------------------------------------*/
/* Uncomment the line below if you will use the I2S peripheral as a Master */
#define I2S_MASTER
/* Uncomment the line below if you will use the I2S peripheral as a Slave */
/* #define I2S_SLAVE */
/* Uncomment the line below if you will use the I2S2 peripheral */
#define I2S2_Select
/* Uncomment the line below if you will use the I2S3 peripheral */
#define I2S3_Select
/* IDT I2S2 Communication boards Interface */
#ifdef I2S2_Select
#define I2S2                           SPI2
//#define I2S2ext                        I2S2ext
#define I2S2_CLK                       RCC_APB1Periph_SPI2
//#define I2S2_CLK_INIT                  RCC_APB1PeriphClockCmd
#define I2S2_WS_PIN                    GPIO_Pin_12
#define I2S2_WS_GPIO_PORT              GPIOB
#define I2S2_WS_GPIO_CLK               RCC_AHB1Periph_GPIOB
#define I2S2_WS_SOURCE                 GPIO_PinSource12
#define I2S2_WS_AF                     GPIO_AF_SPI2
#define I2S2_CK_PIN                    GPIO_Pin_13
#define I2S2_CK_GPIO_PORT              GPIOB
#define I2S2_CK_GPIO_CLK               RCC_AHB1Periph_GPIOB
#define I2S2_CK_SOURCE                 GPIO_PinSource13
#define I2S2_CK_AF                     GPIO_AF_SPI2
#define I2S2_SD_PIN                    GPIO_Pin_15
#define I2S2_SD_GPIO_PORT              GPIOB
#define I2S2_SD_GPIO_CLK               RCC_AHB1Periph_GPIOB
#define I2S2_SD_SOURCE                 GPIO_PinSource15
#define I2S2_SD_AF                     GPIO_AF_SPI2
#define I2S2ext_SD_PIN                 GPIO_Pin_14
#define I2S2ext_SD_GPIO_PORT           GPIOB
#define I2S2ext_SD_GPIO_CLK            RCC_AHB1Periph_GPIOB
#define I2S2ext_SD_SOURCE              GPIO_PinSource14
#define I2S2ext_SD_AF                  GPIO_AF_SPI2
#define I2S2_MCK_PIN                  GPIO_Pin_6
#define I2S2_MCK_GPIO_PORT            GPIOC
#define I2S2_MCK_GPIO_CLK             RCC_AHB1Periph_GPIOC
#define I2S2_MCK_SOURCE               GPIO_PinSource6
#define I2S2_MCK_AF                   GPIO_AF_SPI2//GPIO_AF_MCO//GPIO_AF_SPI2
#endif /*I2S2_Select*/
* @brief  Configures the I2S Peripheral.
* @param  None
* @retval None
static void IDT0_I2S_GPIO_Config(void)
    /* Enable GPIO clocks */
    RCC_AHB1PeriphClockCmd(I2S2_WS_GPIO_CLK | I2S2_CK_GPIO_CLK | \
        I2S2_SD_GPIO_CLK | I2S2ext_SD_GPIO_CLK | I2S2_MCK_GPIO_CLK, ENABLE);
    /* I2S GPIO Configuration --------------------------------------------------*/
    /* Connect I2S pins to Alternate functions */
    GPIO_PinAFConfig(I2S2_WS_GPIO_PORT, I2S2_WS_SOURCE, I2S2_WS_AF);
    GPIO_PinAFConfig(I2S2_CK_GPIO_PORT, I2S2_CK_SOURCE, I2S2_CK_AF);
    GPIO_PinAFConfig(I2S2_SD_GPIO_PORT, I2S2_SD_SOURCE, I2S2_SD_AF);
    GPIO_PinAFConfig(I2S2ext_SD_GPIO_PORT, I2S2ext_SD_SOURCE, I2S2ext_SD_AF);
    GPIO_PinAFConfig(I2S2_MCK_GPIO_PORT, I2S2_MCK_SOURCE, I2S2_MCK_AF);
    GPIO_InitStructure.GPIO_PuPd  = GPIO_PuPd_UP;//GPIO_PuPd_DOWN;
    /* I2S WS pin configuration */
    GPIO_InitStructure.GPIO_Pin = I2S2_WS_PIN;
    GPIO_Init(I2S2_WS_GPIO_PORT, &GPIO_InitStructure);
    /* I2S CK pin configuration */
    GPIO_InitStructure.GPIO_Pin =  I2S2_CK_PIN;
    GPIO_Init(I2S2_CK_GPIO_PORT, &GPIO_InitStructure);
    /* I2S SD pin configuration */
    GPIO_InitStructure.GPIO_Pin = I2S2_SD_PIN;
    GPIO_Init(I2S2_SD_GPIO_PORT, &GPIO_InitStructure);
    /* I2S Extended SD pin configuration */
    GPIO_InitStructure.GPIO_Pin =  I2S2ext_SD_PIN;
    GPIO_Init(I2S2ext_SD_GPIO_PORT, &GPIO_InitStructure);
    /* I2S MCK pin configuration */
    GPIO_InitStructure.GPIO_Pin = I2S2_MCK_PIN;
    GPIO_Init(I2S2_MCK_GPIO_PORT, &GPIO_InitStructure);
* @param  None
* @retval None
static void IDT0_I2S_Config(void)
    I2S_InitTypeDef I2S_InitStructure;
    IDT0_I2S_GPIO_Config();
    /* Peripheral Clock Enable -------------------------------------------------*/
    /* Enable the I2Sx/I2Sx_ext clock */
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI2, ENABLE);
    /* I2S configuration -------------------------------------------------------*/
    /* Initialize  I2Sx and I2Sxext peripherals */
    SPI_I2S_DeInit(I2S2);
    /* Configure the Audio Frequency, Standard and the data format */
    I2S_InitStructure.I2S_AudioFreq = I2S_AudioFreq_8k;
    I2S_InitStructure.I2S_Standard = I2S_Standard_PCMShort;//I2S_Standard_Phillips;
    I2S_InitStructure.I2S_MCLKOutput = I2S_MCLKOutput_Enable;
    I2S_InitStructure.I2S_CPOL = I2S_CPOL_Low;
    I2S_InitStructure.I2S_DataFormat = I2S_DataFormat_16b;
#ifdef I2S_MASTER
    /* Master full Duplex configuration ----------------------------------------*/
    /* Configure I2Sx in Master Transmitter Mode */
    I2S_InitStructure.I2S_Mode = I2S_Mode_MasterRx;
    I2S_Init(I2S2, &I2S_InitStructure);
    /* Configure the I2Sx_ext (the second instance) in Slave Receiver Mode */
    I2S_FullDuplexConfig(I2S2ext, &I2S_InitStructure);
    /* Enable the I2Sx peripheral */
    I2S_Cmd(I2S2, ENABLE);
    /* Enable the I2Sx_ext peripheral for Full Duplex mode */
    I2S_Cmd(I2S2ext, ENABLE);
#endif /* I2S_MASTER */
#ifdef I2S_SLAVE
    /* Slave full Duplex configuration ----------------------------------------*/
    /* Configure I2Sx in Slave Receiver Mode */
    I2S_InitStructure.I2S_Mode = I2S_Mode_SlaveRx;
    /* Configure the I2Sx_ext (the second instance) in Slave Transmitter Mode */
#endif /* I2S_SLAVE */
收藏 评论4 发布时间:2015-2-1 10:39
4个回答
colengol 回答时间:2015-2-1 10:46:30
没人来吗?。。自己顶下!!!
colengol 回答时间:2015-2-1 11:01:11
不要沉啊!顶起。。。。
colengol 回答时间:2015-2-1 11:28:23
大神,快来吧!!!
埃斯提爱慕 回答时间:2015-2-1 20:06:31
意法半导体边缘AI套件
ST - 理想汽车豪华SUV案例
ST意法半导体智能家居案例
STM32 ARM Cortex 32位微控制器
