固件库中已经定义好了2个结构体,使用起来非常方便:- RTC_DateTypeDef RTC_DateStructure;1 g; T" n/ k& ^' q% B2 K7 K
- RTC_TimeTypeDef RTC_TimeStructure;
复制代码 在STM32F30X_RTC.H文件中已定义:
" F5 Y3 w N `1 ?# @6 Y C5 f# I
# B& ^) G. {- \- s- M x- /** 7 w+ P; v- L6 d* G N, O
- * @brief RTC Date structure definition . c+ D2 J5 h" D; y6 C, g
0 b! E6 N2 [ p X( a u - typedef struct
4 F/ t! F" w/ |0 o% Q - {( y- w" D7 T- T% o
- uint8_t RTC_WeekDay; /*!< Specifies the RTC Date WeekDay.
2 @; ]# U% O; i - This parameter can be a value of @ref RTC_WeekDay_Definitions */( |2 B" S8 J& D' R
- / s) i. ~% j8 c$ b: A
- uint8_t RTC_Month; /*!< Specifies the RTC Date Month (in BCD format).
. F `+ h; \/ K' M8 |2 S - This parameter can be a value of @ref RTC_Month_Date_Definitions */
: k# u0 s* \2 U* ~: b0 x! l - 4 }. V5 w" @/ ^8 B
- uint8_t RTC_Date; /*!< Specifies the RTC Date.
, A$ O, I0 I8 K1 k( N9 a2 ~ - This parameter must be set to a value in the 1-31 range. */8 L! z* U; X6 l. w6 n2 ]- W
- % e U9 `, T8 s4 d4 G+ H% w; f
- uint8_t RTC_Year; /*!< Specifies the RTC Date Year.
; k) T$ G3 Y v0 u4 P - This parameter must be set to a value in the 0-99 range. */
# ?) V0 P3 l+ N% U2 O - }RTC_DateTypeDef;7 ?+ ]- {8 H: u t4 Z
复制代码- typedef struct
: [" S* \. H* ^5 m+ F' j6 @ - {( G% Q2 S- a7 E% m, E3 _- R
- uint8_t RTC_Hours; /*!< Specifies the RTC Time Hour.$ d; U; t' N! t* O! A
- This parameter must be set to a value in the 0-12 range
3 w3 z& \4 i" y0 ` - if the RTC_HourFormat_12 is selected or 0-23 range if* s( w: w9 D! h% S: f U* b( v+ p
- the RTC_HourFormat_24 is selected. */ c3 D# D; t% D U3 v, I
! H5 j i. b2 v6 C0 M: s- uint8_t RTC_Minutes; /*!< Specifies the RTC Time Minutes.. ~) n+ w/ J0 N3 ?1 p7 v/ K
- This parameter must be set to a value in the 0-59 range. */( K V1 {+ V F
- 9 b: L+ i. d9 w v+ ]
- uint8_t RTC_Seconds; /*!< Specifies the RTC Time Seconds.
% v7 f5 r+ z+ K* n; o* c J! s - This parameter must be set to a value in the 0-59 range. */% Q5 C+ J, l$ n+ V% ]
% a3 B; \; I. ? ?. L7 D% \( E+ \- uint8_t RTC_H12; /*!< Specifies the RTC AM/PM Time.1 G3 {. t6 e5 X
- This parameter can be a value of @ref RTC_AM_PM_Definitions */: t' \9 a& m" P; R/ k2 }
- }RTC_TimeTypeDef;
复制代码 在.C文件里做申明:
$ V+ j E% z- w- RTC_DateTypeDef RTC_DateStructure;
- W' ~+ ]1 W% @) [( B6 } - RTC_TimeTypeDef RTC_TimeStructure;
复制代码 在main.c中:5 W N" |4 P; A$ W6 m+ z U2 h4 e
- RTC_Config();) `/ F7 g% c1 R, T0 i5 j
- while (1)
p# z& P# O" z! c# p6 ^* L - {
0 V& Q* p# W& n+ }9 ^* h - /* Get the RTC current Time */
3 `. c$ ]9 M! [6 w - RTC_GetTime(RTC_Format_BIN, &RTC_TimeStructure);
; n: q: W6 {$ C- Y+ S% N! { - /* Get the RTC current Date */
8 z1 R) v2 i# L* ~ - RTC_GetDate(RTC_Format_BIN, &RTC_DateStructure);& ]' m. ?( w9 O! \
- /* Display time Format : hh:mm:ss */
" _% F0 i) R4 h! Z6 M- v - sprintf((char*)showtime,"%.2d:%.2d:%.2d",RTC_TimeStructure.RTC_Hours, RTC_TimeStructure.RTC_Minutes, RTC_TimeStructure.RTC_Seconds);3 ^) x [8 @7 l- E. V
- /* Display date Format : mm-dd-yy */3 ]& H" m9 X+ ? I+ ?1 F
- sprintf((char*)showdate,"%.2d-%.2d-%.2d",RTC_DateStructure.RTC_Month, RTC_DateStructure.RTC_Date, 2000 + RTC_DateStructure.RTC_Year);
% P: D' U. I7 ^6 m0 ~& { - ) \5 ]* W( x3 s' {4 }
复制代码 在中断中描输出:7 Y& d$ z: u1 w# _4 [
- void RTC_Alarm_IRQHandler(void)
+ x* M8 T( R- p& c9 {. W' } - {9 y2 R8 V A8 g2 a* l
# d+ r2 l3 Z3 q- if(RTC_GetITStatus(RTC_IT_ALRA) != RESET)5 H- k. p- o4 S6 V
- {( G4 ^$ _5 m5 z" h/ V3 r; E
+ y5 c; M1 G( n6 h1 U - if(GPIO_ReadOutputDataBit(GPIOA, GPIO_Pin_5)==0)7 r/ _7 b, {2 b9 V
- GPIO_SetBits(GPIOA, GPIO_Pin_5); //Green LED9 y( F$ y2 `' h5 v4 n
- else6 Z7 @) t% M, t# n# T2 J( u) r* w1 y: P
- GPIO_ResetBits(GPIOA, GPIO_Pin_5); //Green LED1 m; N x l' B# ]/ R
& r' |' N, h, y! u7 r( M- RTC_ClearITPendingBit(RTC_IT_ALRA);
7 Z! N8 s" |4 F# @% M - EXTI_ClearITPendingBit(EXTI_Line17);
2 G8 A- F6 f% B: c- x - }
0 y" K/ ]0 N, m& c - }
复制代码 附件:
- l" |% t7 S9 E( f1 _8 E( H
Nucleo_F334R8_RTC.zip
(3.87 MB, 下载次数: 10)
