* R1 ~6 z4 W6 ?( c: N* `
程序支持STM,FSL, ST 三家公司的MCU,通用的,只要改下头文件就可以了,方便移值; w0 d! ~) r ? D
; Y8 c4 J4 @$ o+ K
5 c @7 U6 ~( j) k- #include "st7585.h"4 {) O1 @: a4 U& ]% N
- #include "asc0508.h"
# o9 Y) U# j0 N) ]( \ -
# S+ X1 o' {* A" \ - const unsigned char hanzi[]=
. o" M% Q+ v0 k! S* o! c$ y - {
5 w( }! H; Z* L0 c! S - /*-- 文字: S --*/! _- x' i, m9 X
- /*-- Trebuchet MS12; 此字体下对应的点阵为:宽x高=16x16 --*/ w( ?% O9 e3 d( L9 U7 `% E3 L4 p/ U
- 0x00,0x70,0x88,0x08,0x08,0x08,0x38,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00," r. c6 _) M* W: K4 J
- 0x00,0x38,0x20,0x21,0x21,0x22,0x1C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
( H6 X) N) B* n2 |9 F5 I9 S - /*-- 文字: T --*/# B5 M' I/ s5 C2 } h2 Q; m
( H+ q, h5 J" q8 g - 0x18,0x08,0x08,0xF8,0x08,0x08,0x18,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
6 j) ~% o( P2 G$ n/ o - 0x00,0x00,0x20,0x3F,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
5 v2 a4 z7 P1 Y8 A - /*-- 文字: M --*/
& i/ P4 w. y6 O - /*-- Trebuchet MS12; 此字体下对应的点阵为:宽x高=16x16 --*/* X! o) y% C3 E) O& g ~# N( N
- 0x08,0xF8,0xF8,0x00,0xF8,0xF8,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
$ M- I. F+ O& T5 A - 0x20,0x3F,0x00,0x3F,0x00,0x3F,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
# E& l$ O9 B, d2 Q - /*-- 文字: 8 --*/
& n) _9 [2 K7 F - /*-- Trebuchet MS12; 此字体下对应的点阵为:宽x高=16x16 --*/
" @0 \4 `0 b7 ` - 0x00,0x70,0x88,0x08,0x08,0x88,0x70,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
; s0 _+ g! ?! b. i( I - 0x00,0x1C,0x22,0x21,0x21,0x22,0x1C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
: k1 A `% S" n$ J7 l( @+ ? - /*-- 文字: 开 --*/
; G0 @9 r5 O2 u3 c v% h/ ~/ V, o - /*-- Trebuchet MS12; 此字体下对应的点阵为:宽x高=16x16 --*/
, V, Q9 y* [: x% f - 0x80,0x82,0x82,0x82,0xFE,0x82,0x82,0x82,0x82,0x82,0xFE,0x82,0x82,0x82,0x80,0x00,2 u+ a4 G3 o4 g) K/ P% ~& J$ S
- 0x00,0x80,0x40,0x30,0x0F,0x00,0x00,0x00,0x00,0x00,0xFF,0x00,0x00,0x00,0x00,0x00,. _. {6 [$ w0 N* }- ^) k! X( C' g
- /*-- Trebuchet MS12; 此字体下对应的点阵为:宽x高=16x16 --*/4 k% A5 W2 M% X4 H
- 0x00,0x00,0x18,0x16,0x10,0xD0,0xB8,0x97,0x90,0x90,0x90,0x92,0x94,0x10,0x00,0x00,1 `/ C6 \2 _) g" U
- 0x00,0x20,0x10,0x8C,0x83,0x80,0x41,0x46,0x28,0x10,0x28,0x44,0x43,0x80,0x80,0x00,
3 Z& H/ Q% ?# c - /*-- 文字: 板 --*/
. }. n0 m: I" T1 P- B5 W# u - /*-- Trebuchet MS12; 此字体下对应的点阵为:宽x高=16x16 --*/
' T$ A7 p% ]7 f2 i: @; M - 0x10,0x10,0xD0,0xFF,0x90,0x10,0x00,0xFC,0x24,0xE4,0x24,0x22,0x23,0xE2,0x00,0x00,8 \! j: Q4 o3 ~; w" i
- 0x04,0x03,0x00,0xFF,0x00,0x83,0x60,0x1F,0x80,0x41,0x26,0x18,0x26,0x41,0x80,0x00,
! N% ]3 m3 U: l, ? A- v4 U$ K: ^: S- W$ _ - };) J& q# a9 U9 s( D; ~. N4 {" c
- 3 n$ H# Z3 ]$ I& g9 o7 q
: \4 y8 e2 A- q5 U8 V- extern volatile unsigned char LCDDly;( [) B+ }) j( G/ I- y a* S
' Q/ A) f) e2 O* Y: v# G- //=============================================================
, x3 I( A! b8 |3 z - //延时6 O: S5 U1 p* j' ^8 Y y8 e
5 z! S0 t7 F; M& F& ?: b - void DlyMs(unsigned char nCount)9 r# U/ T8 D5 F- I# \
) P% T6 A' _3 g* ?, x4 K) V, n - LCDDly = nCount ;* T8 v P6 m- |% ^9 I8 T1 c5 P$ I
- while ( LCDDly > 0 );1 }9 t; l+ e/ u$ H9 K
4 m! X# i' E% h
" l- K- T5 H2 |" l/ p- //=============================================================
& P9 \( ~) l! l, g( i5 ^ - //传送数据, E* V- G1 b( t
- //=============================================================: D2 {2 M5 t, \' W- b8 s3 B
- void LCD_WriteBus(unsigned char Value)
, q- h1 ], e; W7 c4 L: i - { unsigned char i; 6 Y0 T) M- Z7 k5 P: K
- LCD_SDA_1; 7 i) n, K" u: U4 W2 i
- LCD_SCL_0;
# F' R: b; n- [! @$ I - for(i=0;i<8;i++)! {+ @$ k7 l/ q- c' p4 k
- { LCD_SCL_0;
6 k8 I* j- m0 I" p: n. @) D' t* q* z$ ]- q - if(Value&0x80) LCD_SDA_1; else LCD_SDA_0;; f( ?( N; j0 j$ _6 H# ?0 U" G) A& U
- LCD_SCL_1; # ~& b4 c8 X) j; |; `
- Value=Value<<1; / V8 |2 L7 n, z
- }5 P2 H$ w- k& v% S7 y* |
- LCD_SCL_1;
- E/ N6 Y& `5 w# I' b0 X& h - LCD_SDA_1;
% |& \3 j7 P1 F; g& e - }
! U% F" Y8 P7 _+ B6 P& X - ' a: a# w/ d5 h" f
- //=============================================================% J9 G( \$ B8 B( Y, D$ ^* Y
- //写命令- \) F3 Z# |) g2 P% ?
- //=============================================================6 n' Y; K( s4 @: N& w4 r
- void LCD_WriteCmd(unsigned char Cmd)
- \5 {: C7 B! S3 |: ? - { 7 ?* p/ M, D* | O( i( Q
- LCD_CS_0;4 h8 K/ @) l% I
- LCD_RS_0;- @2 x7 j- `1 B
- LCD_WriteBus(Cmd);: Z2 T2 s2 Z# U5 v
- LCD_CS_1;; q$ X8 ?4 Y( K' z/ n$ ^1 {
- }% d1 S4 |/ U; r# o# ^0 |& O+ u% z
- 7 O1 l/ F, I' i9 D% U
5 H! ]- v$ n" ^6 L7 I u4 S3 o - //写数据% z9 ]5 K+ z+ c6 P8 ^" _. j
$ m4 ]5 h, j/ w5 x- B. f' U- |( F - void LCD_WriteDat(unsigned char Dat) " M, }7 { @/ B p7 [
- {, \4 r- L" v% y, |7 |; T
- LCD_CS_0;
; H1 [) I9 w, [$ M - LCD_RS_1;3 [6 @( D/ K) d
- LCD_WriteBus(Dat);
( ?4 G4 b8 }( T; ]3 p! K0 O8 r - LCD_CS_1;: c% Y7 U; H! _) O6 h
( b5 z6 ]. a! v! J a3 ~; E - ) x3 B6 a; W3 t( l" E/ [$ }; I
, s/ z" k1 S4 L1 _4 a( ? - *函 数: LCD_SetXY(unsigned char x,unsigned char y) *
4 j4 R% N2 k6 A - *功 能: 移动显示指针到指定位置 *
3 B) C; ]* M$ @( n" F2 d. ]# k - *参 数: X,Y 座标值 *! C8 n5 Z# U; ~- k6 I
- *******************************************************************************/ / t" p+ w" w% ?5 b) {+ y' ]; ?: }
- void LCD_SetXY(unsigned char X,unsigned char Y)
* B' H- h5 k0 R! u! n7 p: J9 t - {
( M! r; r, i; @8 F - LCD_WriteCmd(0x80 | X); // row% E0 C" H$ H9 s" i" M% A" D
- LCD_WriteCmd(0x40 | Y); // column) B1 F% K7 a. h8 F3 @, y7 g1 K. p/ O
+ W1 F- v, x7 Z. F - 9 c h0 a p6 p9 \- c% R% v. q
- @2 {" w: a) B4 e& g2 C - *函 数: lcd_goto1(unsigned char x) *
4 \3 f% K/ K: o: C% v, A) Y - *功 能: 移动到第一行的指定位置 *) B- {, I3 a! _+ s T0 U
- *参 数: 字符在屏上的位置 ( 0 - 16 ) *4 V/ [. E, ~1 f/ t s
- *******************************************************************************/ " R4 Y, g8 B7 l2 e& n$ E/ e" s
- void lcd_goto1(unsigned char x){LCD_SetXY(x*6,7);} //第1行x位2 h3 L! K+ f& x, {, O0 n
- void lcd_goto2(unsigned char x){LCD_SetXY(x*6,6);} //第2行x位3 Y: [* Z( p) g6 ~' y3 @% b/ \/ _
- void lcd_goto3(unsigned char x){LCD_SetXY(x*6,5);} //第3行x位
8 P; i* q/ [6 M/ I4 }' z - void lcd_goto4(unsigned char x){LCD_SetXY(x*6,4);} //第4行x位; }9 m8 F* U% T
- void lcd_goto5(unsigned char x){LCD_SetXY(x*6,3);} //第5行x位
" K( j* e6 { }7 \8 v& t - void lcd_goto6(unsigned char x){LCD_SetXY(x*6,2);} //第6行x位* S9 v/ M7 @8 `& g/ H
- void lcd_goto7(unsigned char x){LCD_SetXY(x*6,1);} //第7行x位3 u3 q" w Q! G J% W* O4 j
- void lcd_goto8(unsigned char x){LCD_SetXY(x*6,0);} //第8行x位& ^' ]! Z& \" J' K3 e/ \, `# s
- + }. w7 Q$ h; ]" G( T% N; ?
6 o2 Q2 g9 f* g - *函 数: lcd_cls(unsigned int Color) *
1 a( I7 o" P/ O$ F X# e. v+ m - *功 能: 清屏 *
6 t$ z. F! e5 r3 q - *参 数: Color *
3 m$ `, ~" d; n- X5 q; @1 r! L - *******************************************************************************/# W0 D: W7 v1 o0 A
- void lcd_cls(unsigned int Color)9 |2 s( u7 u! ^, `
- {: ~8 K0 _/ B! L$ Y8 H {
- unsigned char t;
3 }) R& J/ c9 u! D' t6 ? - unsigned char k;: w0 I6 Y& z3 [
- LCD_SetXY(0,0);
" E0 s9 L3 r; z: V! g) I - for(t=0;t<9;t++)" M! h' h# ]& ~# N
- { for(k=0;k<LCD_W;k++) { LCD_WriteDat(0x00); } } ?) K1 w, W1 C2 Z+ U% ^
1 N" ^- _% j0 E0 [: L - 7 j z- E, l6 x5 k0 o' t! E
- void lcd_putc(unsigned char asc)1 q% g! `, d+ T( G. o* [+ C
- {, _, Q4 q5 p4 m9 Q5 M2 T# B4 B. s
- unsigned char line;
4 ?: p% S* d: c; [6 D* N d - for (line=0; line<5; line++)
3 a" z! K) t+ r$ S' s - LCD_WriteDat(Asc0508[(asc-32)*5+line]);
- k* b+ p d! | - LCD_WriteDat(0x00);
5 d! C8 D; ?8 m( S - }
: B. c; |2 x# ^( E# v
! a# ?+ E7 x: H2 p* w0 b. r- void lcd_puts(char *s)" P9 r, F2 ]+ g# C0 B
- { while (*s) { lcd_putc(*s++); } }
* b! k! ^) s, P7 [
" e3 c: l+ c. s, ?
1 v2 A$ X1 d f+ V+ P! D- void LcdWriteHanzi(unsigned char row,unsigned char page,unsigned char c), @: ^8 ]/ v3 |0 K0 {
- {/ Q; \3 v, ?/ H* c- v+ m
- unsigned char i;
2 G4 e2 y. ]2 U, h0 V4 \ - 6 \3 L' G" f/ K( c: F
- LCD_SetXY(row*8, page);// 列,页+ t+ Y# i6 S' [! U- a$ E7 B
- for(i=16; i<32;i++) { LCD_WriteDat(hanzi[c*32+i]); } 4 Z, w1 ?; Y9 l
- LCD_SetXY(row*8, page+1);// 列,页 7 J) C* [$ u, a8 m( ]
- for(i=0; i<16;i++) { LCD_WriteDat(hanzi[c*32+i]);}
, X$ ]/ a7 r" o) i7 z( p; o0 L - ; e A D M3 t/ V# m. @$ k3 U" a
- }- D4 P9 c& `# m e
' _4 L# n5 `7 B- //=============================================================
7 N$ b7 B( M- Q# }$ M7 K2 g6 e - //初始化LCD
1 A4 q: k! i T8 D# [ - //=============================================================
0 l$ v0 G! v' \- ]- Y, P( l - void lcd_init(void)+ Y" p" u6 Y6 L3 L
. u9 {5 ~6 d+ E* X) r - //LCD_AdjBacklight(255);$ R1 h* x! Q; |) G
- /* Configure the LCD pins --------------------------------------------*/
& C* w+ [$ d- N0 `' ~2 e - // SET_BUS_OUTPUT();) [. I5 D) K5 P' M' c7 g
3 b9 U, L) C: L# ?) C1 J, j2 `- gpio_init(LCD_CS, 1, 0);
1 s4 m' d+ r2 v# L1 p - gpio_init(LCD_RES, 1, 0);( E) ^% x1 [3 K+ t; u' X
- gpio_init(LCD_RS, 1, 0);
' L/ k; i( G, d. V! U - gpio_init(LCD_SDA, 1, 0);
9 e/ i# s3 H6 T/ m1 U: w; h - gpio_init(LCD_SCL, 1, 0);
% M; S2 `4 I. F. D& R - 3 {% p& T/ ?: t# q$ p v8 K: z$ ]
- DlyMs(MS10);+ r$ R: `8 ~) G( X. L
- LCD_CS_0;+ t& k% Q4 d8 R6 F& q1 e3 T
- LCD_RES_0;
: Y# X$ B0 M: g1 B - DlyMs(MS10);3 ? c8 |. P$ T9 I) W' z
- LCD_RES_1;
5 f3 M+ |* n! t1 X/ X' y - DlyMs(MS10);
1 w- N9 i. p. l) K0 I% Y# X' B - * I2 t ]& O* w9 q
- LCD_WriteCmd(0x21);//LCD功能设置:芯片活动,水平寻址,使用扩展指令+ Q; ? q S) L6 Q. U X3 Y
- LCD_WriteCmd(0x9C);//设置VOP值,室温下的编程范围为3.00-10.68- s/ t9 f8 b' t" y
- LCD_WriteCmd(0x30);
2 P* w, t& Y& ] - DlyMs(MS50);
+ M+ A8 x! S9 I* R4 C0 D
6 c* Y* J" p1 B/ b' K6 j. U- LCD_WriteCmd(0x20);//LCD功能设置:芯片活动,水平寻址,使用基本指令
A# Y+ Y9 ]6 K - LCD_WriteCmd(0x0C);//设定显示配置:普通模式
/ y# w* S3 O0 W# f' X4 j - }. b( x7 V8 m3 J* @# B
% k: C8 v/ l) ?% ?) l- ( C7 l6 U* w- U. x6 l
- void LcdTest(void). |: q" Y" D) v2 r: H3 a# E/ c2 E' R
5 c, G/ c" ^; p2 T9 W# P& ]; g - lcd_init(); //初始化LCD模块 " h, |. G! ]) w
- lcd_cls(0x00); //清屏幕4 M+ {2 D4 {# P7 _: H( A
- & y: t, Y7 R3 F$ S, ^4 D
- LcdWriteHanzi(0,2,0); //S
/ o6 m* U* v6 }; ?% n* r - LcdWriteHanzi(1,2,1); //T2 |+ u$ R/ o6 x7 T H: v: m
- LcdWriteHanzi(2,2,2); //M9 _+ j. _% j8 j+ o
- LcdWriteHanzi(3,2,3); //8
6 ~, T1 y: ~+ k1 ` - LcdWriteHanzi(4,2,4); //开" Y1 S0 s; I% t0 ?
- LcdWriteHanzi(6,2,5); //发7 u, x7 [+ m, x K' N
- LcdWriteHanzi(8,2,6); //板# v% c4 _/ w4 U3 W' u( t9 @
3 d1 q, R/ [) a% g- lcd_goto1(0);0 |" U6 X* a \. V6 `: o4 B
- lcd_puts("This is a demo."); ; }8 b! M- v, W' i5 p* A
- " g* p7 n2 r. P5 {
- lcd_goto2(0);! @4 x1 r+ `: D- {1 z! q
- lcd_puts("1234567890ABCDEFG");
2 q6 A1 B' Q6 h( @1 r - 8 F1 a0 t) ?: J; F) Q+ p
- lcd_goto4(1);
y+ D5 G' @/ V- \2 h6 s: b - lcd_puts("1234567890ABCDEFG");
9 ` W0 P# Q: q0 D; O; }6 ]0 T* x - }3 W' b; V! p$ Y" B
1 }' y! Z4 y+ d' x0 W, {4 N& @7 T0 n
9 h, T b* S: S1 _9 h" I4 T$ P* D( ?- N
只知道是串行口= =' w: y, _: E- P% n6 B& G
