HAL之DAC篇------三
一花一世界003 提问时间:2015-2-16 12:58 /
二里面是产生梯形波,为什么可以产生梯形波?然后产生三角波、等等
重点在HAL_DAC_Start_DMA(&DacHandle, DACx_CHANNEL, (uint32_t *)aEscalator8bit, 6, DAC_ALIGN_8B_R)
HAL_StatusTypeDef HAL_DAC_Start_DMA(DAC_HandleTypeDef* hdac, uint32_t Channel, uint32_t* pData, uint32_t Length, uint32_t Alignment)
  uint32_t tmpreg = 0;
  /* Check the parameters */
  assert_param(IS_DAC_CHANNEL(Channel));
  assert_param(IS_DAC_ALIGN(Alignment));
  /* Process locked */
  __HAL_LOCK(hdac);
  /* Change DAC state */
  hdac->State = HAL_DAC_STATE_BUSY;
  if(Channel == DAC_CHANNEL_1)
    /* Set the DMA transfer complete callback for channel1 */
    hdac->DMA_Handle1->XferCpltCallback = DAC_DMAConvCpltCh1;
    /* Set the DMA half transfer complete callback for channel1 */
    hdac->DMA_Handle1->XferHalfCpltCallback = DAC_DMAHalfConvCpltCh1;
    /* Set the DMA error callback for channel1 */
    hdac->DMA_Handle1->XferErrorCallback = DAC_DMAErrorCh1;
    /* Enable the selected DAC channel1 DMA request */
    hdac->Instance->CR |= DAC_CR_DMAEN1;
    /* Case of use of channel 1 */
    switch(Alignment)
      case DAC_ALIGN_12B_R:
        /* Get DHR12R1 address */
        tmpreg = (uint32_t)&hdac->Instance->DHR12R1;
        break;
      case DAC_ALIGN_12B_L:
        /* Get DHR12L1 address */
        tmpreg = (uint32_t)&hdac->Instance->DHR12L1;
        break;
      case DAC_ALIGN_8B_R:
        /* Get DHR8R1 address */
        tmpreg = (uint32_t)&hdac->Instance->DHR8R1;
        break;
      default:
        break;
  else
    /* Set the DMA transfer complete callback for channel2 */
    hdac->DMA_Handle2->XferCpltCallback = DAC_DMAConvCpltCh2;
    /* Set the DMA half transfer complete callback for channel2 */
    hdac->DMA_Handle2->XferHalfCpltCallback = DAC_DMAHalfConvCpltCh2;
    /* Set the DMA error callback for channel2 */
    hdac->DMA_Handle2->XferErrorCallback = DAC_DMAErrorCh2;
    /* Enable the selected DAC channel2 DMA request */
    hdac->Instance->CR |= DAC_CR_DMAEN2;
    /* Case of use of channel 2 */
    switch(Alignment)
        /* Get DHR12R2 address */
        tmpreg = (uint32_t)&hdac->Instance->DHR12R2;
        break;
        /* Get DHR12L2 address */
        tmpreg = (uint32_t)&hdac->Instance->DHR12L2;
        break;
        /* Get DHR8R2 address */
        tmpreg = (uint32_t)&hdac->Instance->DHR8R2;
        break;
      default:
        break;
  /* Enable the DMA channel */
    /* Enable the DAC DMA underrun interrupt */
    __HAL_DAC_ENABLE_IT(hdac, DAC_IT_DMAUDR1);
    HAL_DMA_Start_IT(hdac->DMA_Handle1, (uint32_t)pData, tmpreg, Length);
  else
    __HAL_DAC_ENABLE_IT(hdac, DAC_IT_DMAUDR2);
    HAL_DMA_Start_IT(hdac->DMA_Handle2, (uint32_t)pData, tmpreg, Length);
  /* Enable the Peripharal */
  __HAL_DAC_ENABLE(hdac, Channel);
  /* Process Unlocked */
  __HAL_UNLOCK(hdac);
  /* Return function status */
  return HAL_OK;
函数编写也很容易看懂。
static void DAC_Ch1_TriangleConfig(void)
  /*##-1- Initialize the DAC peripheral ######################################*/
  if (HAL_DAC_Init(&DacHandle) != HAL_OK)
    /* Initiliazation Error */
    Error_Handler();
  /*##-2- DAC channel2 Configuration #########################################*/
  sConfig.DAC_Trigger = DAC_TRIGGER_T6_TRGO;
  sConfig.DAC_OutputBuffer = DAC_OUTPUTBUFFER_ENABLE;
  if (HAL_DAC_ConfigChannel(&DacHandle, &sConfig, DACx_CHANNEL) != HAL_OK)
    /* Channel configuartion Error */
    Error_Handler();
  /*##-3- DAC channel2 Triangle Wave generation configuration ################*/
  if (HAL_DACEx_TriangleWaveGenerate(&DacHandle, DACx_CHANNEL, DAC_TRIANGLEAMPLITUDE_1023) != HAL_OK)
    /* Triangle wave generation Error */
    Error_Handler();
  /*##-4- Enable DAC Channel1 ################################################*/
  if (HAL_DAC_Start(&DacHandle, DACx_CHANNEL) != HAL_OK)
    /* Start Error */
    Error_Handler();
  /*##-5- Set DAC channel1 DHR12RD register ################################################*/
  if (HAL_DAC_SetValue(&DacHandle, DACx_CHANNEL, DAC_ALIGN_12B_R, 0x100) != HAL_OK)
    /* Setting value Error */
    Error_Handler();
三角波类似,重点也是HAL_DACEx_TriangleWaveGenerate(&DacHandle, DACx_CHANNEL, DAC_TRIANGLEAMPLITUDE_1023)
HAL_StatusTypeDef HAL_DACEx_TriangleWaveGenerate(DAC_HandleTypeDef* hdac, uint32_t Channel, uint32_t Amplitude)
  assert_param(IS_DAC_LFSR_UNMASK_TRIANGLE_AMPLITUDE(Amplitude));
  __HAL_LOCK(hdac);
  /* Enable the selected wave generation for the selected DAC channel */
  MODIFY_REG(hdac->Instance->CR, ((DAC_CR_WAVE1)|(DAC_CR_MAMP1))<<Channel, (DAC_WAVE_TRIANGLE | Amplitude) << Channel);
  hdac->State = HAL_DAC_STATE_READY;
  /* Process unlocked */
  __HAL_UNLOCK(hdac);
  return HAL_OK;
其中#define MODIFY_REG(REG, CLEARMASK, SETMASK)  WRITE_REG((REG), (((READ_REG(REG)) & (~(CLEARMASK))) | (SETMASK)))
再说一下HAL的DAC驱动的基本程序及思想方法
配置DAC通道函数:
HAL_StatusTypeDef HAL_DAC_ConfigChannel(DAC_HandleTypeDef* hdac, DAC_ChannelConfTypeDef* sConfig, uint32_t Channel)
  uint32_t tmpreg1 = 0, tmpreg2 = 0;
  /* Check the DAC parameters */
  assert_param(IS_DAC_TRIGGER(sConfig->DAC_Trigger));
  assert_param(IS_DAC_OUTPUT_BUFFER_STATE(sConfig->DAC_OutputBuffer));
  __HAL_LOCK(hdac);
  /* Get the DAC CR value */
  tmpreg1 = DAC->CR;
  /* Clear BOFFx, TENx, TSELx, WAVEx and MAMPx bits */
  tmpreg1 &= ~(((uint32_t)(DAC_CR_MAMP1 | DAC_CR_WAVE1 | DAC_CR_TSEL1 | DAC_CR_TEN1 | DAC_CR_BOFF1)) << Channel);
  /* Configure for the selected DAC channel: buffer output, trigger */
  /* Set TSELx and TENx bits according to DAC_Trigger value */
  /* Set BOFFx bit according to DAC_OutputBuffer value */
  tmpreg2 = (sConfig->DAC_Trigger | sConfig->DAC_OutputBuffer);
  /* Calculate CR register value depending on DAC_Channel */
  tmpreg1 |= tmpreg2 << Channel;
  /* Write to DAC CR */
  DAC->CR = tmpreg1;
  /* Disable wave generation */
  DAC->CR &= ~(DAC_CR_WAVE1 << Channel);
  __HAL_UNLOCK(hdac);
  return HAL_OK;
收藏 1 评论6 发布时间:2015-2-16 12:58
6个回答
feel-376797 回答时间:2015-2-16 15:14:13
谢谢分享
123tango 回答时间:2015-2-16 15:27:22
谢谢分享
wyxy163@126.com 回答时间:2015-2-16 17:07:47
alvin_ 回答时间:2015-2-16 17:38:20
楼主有没有HAL串口篇?最近被串口搞得很闹心……
_ilikerome_ 回答时间:2015-2-17 08:56:49
跟着学习一下。。。。
拼命三郎 回答时间:2015-2-18 10:42:43
意法半导体边缘AI套件
ST - 理想汽车豪华SUV案例
ST意法半导体智能家居案例
STM32 ARM Cortex 32位微控制器
