M3串口发送不成功可能是什么原因
千羽猎鹰 提问时间:2015-3-20 08:45 /
片子用的STM32F103C8T6,之前正常,后来板子上的串口位置换了,就把串口换了一下,三个串口都用
串口1和串口3都发送不出去
    USART_SendData(USART1, (u8) ch);
    while(USART_GetFlagStatus(USART1, USART_FLAG_TC)==RESET);
跑到这里,就一直检测标志位了
串口2能够发送成功,配置一样,试了两块板子,效果一样
可能是哪里的问题呢?
赞 收藏 评论16 发布时间:2015-3-20 08:45
16个回答
千羽猎鹰 回答时间:2015-3-20 09:08:16
void UART1_Configuration(void)
        GPIO_InitTypeDef    GPIO_InitStructure;
        USART_InitTypeDef   USART_InitStructure;
        NVIC_InitTypeDef    NVIC_InitStructure;
        Uart1Conf.RXpoint = 0;
        Uart1Conf.RXStart = Uart1Conf.RXpoint;
        Uart1Conf.RXlenth = 0;
        Uart1Conf.TXlenth = 0;
        Uart1Conf.Time    = 0;
        RCC_APB1PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);                                //  USART1ʱÖÓʹÄÜ
        USART_InitStructure.USART_BaudRate = 38400;
        USART_InitStructure.USART_Parity = USART_Parity_No ;
        USART_Init(USART1, &USART_InitStructure);
        RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOA, ENABLE);                                //  I/O¶Ë¿ÚAʱÖÓʹÄÜ
        //Configure the USART1_Tx PA9 as Alternate function Push-Pull
        GPIO_InitStructure.GPIO_Mode  = GPIO_Mode_AF_PP;
        GPIO_InitStructure.GPIO_Pin   = GPIO_Pin_9;
        //Configure the USART1_Rx PA10 as input power-UP
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;                                                //  GPIO_Mode_IN_FLOATING;
    GPIO_InitStructure.GPIO_Pin  = GPIO_Pin_10;
        RCC_APB2PeriphClockCmd( RS485OUTEN_GPIO_CLK | RS485INEN_GPIO_CLK,ENABLE);                                //  I/O¶Ë¿ÚAʱÖÓʹÄÜ
        // Configure the RS485DoutEN PA11 as out Push-Pull
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
    GPIO_InitStructure.GPIO_Pin  = RS485OUTEN_PIN;
    GPIO_Init(RS485OUTEN_GPIO_PORT, &GPIO_InitStructure);
    // Configure the RS485RecvEN PA12 as out Push-Pull
    GPIO_InitStructure.GPIO_Pin  = RS485INEN_PIN;
    GPIO_Init(RS485INEN_GPIO_PORT, &GPIO_InitStructure);
        RS485DoutDIS();                                                     //  ½ûÖ¹·¢ËÍ
        RS485RecvEN();                                                      //  ½ÓÊÕʹÄÜ
        // Enable USART1 Receive  interrupts
        USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
        // DisEnable USART1 SendEmpt  interrupts
        USART_ITConfig(USART1, USART_IT_TXE, DISABLE);
        // DisEnable USART1 SendComplete  interrupts
        USART_ITConfig(USART1, USART_IT_TC, DISABLE);
//        USART_ClearFlag(USART1,USART_FLAG_TC);        //  ·ÀÖ¹ÎÞ·¨Êä³ö¸´Î»ºóµÄÊ××Ö·û£¬Õâ¸ö¹¦ÄÜû·¨ÑéÖ¤
        // Enable the USART1
        USART_Cmd(USART1, ENABLE);        //  USART1ʹÄÜ
        // Enable the USART1 Interrupt
        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
        NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x0;
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
原来用着好好的啊 就是换了一下顺序
串口如果想要发送数据的话 除了允许发送,打开串口 还需要别的不
千羽猎鹰 回答时间:2015-3-20 09:12:53
zfz0122 发表于 2015-3-20 09:04
板子上的串口位置换了,就把串口换了一下,??没懂
原来用串口1实现功能1,串口2实现功能2,串口3实现功能3
换板子以后,用串口1实现功能3,串口3实现功能1,每个串口的引脚也有变化
千羽猎鹰 回答时间:2015-3-20 16:36:15
楼主,你看一下这个配置。
恩恩 太马虎了 谢谢
废鱼 回答时间:2015-3-20 08:59:18
有没有重映射端口?最好把使用的是哪个IO口做串口、配置发一下。
kqh1120 回答时间:2015-3-20 09:04:46
eurphan 回答时间:2015-3-20 09:23:51
不懂帮顶
chendiand 回答时间:2015-3-20 10:45:29
正在学习串口
千羽猎鹰 回答时间:2015-3-20 11:06:19
感觉好凄惨 都没人理我
废鱼 回答时间:2015-3-20 11:17:20
楼主串口1用的还是PA9 PA10吗?
千羽猎鹰 回答时间:2015-3-20 12:13:29
安 发表于 2015-3-20 11:17
楼主串口1用的还是PA9 PA10吗?
嗯 是的 引脚可以确认是对的
废鱼 回答时间:2015-3-20 14:26:27
楼主,你看一下这个配置。
wamcncn 回答时间:2015-3-20 14:43:02
一个一个串口试下正常吗
废鱼 回答时间:2015-3-20 16:38:00
楼主可以正常使用了吗?
拼命三郎 回答时间:2015-3-20 22:44:36
12下一页
