昨天翻译了USB部分,但是鉴于我有一段翻译实在不知道怎么组织,所以不放上来了,等我什么时候想到了就再放上来; w- n& ^ S' K) n 今天首先学习了CAN部分的芯片手册。这是与can有关的结构体及注释:& i1 k3 G, r" D# B5 |( z5 } typedef struct$ a1 v& M0 g9 Z5 e { CAN_TypeDef *Instance; /*!< Register base address */---这是寄存器的基本地址 CAN_InitTypeDef Init; /*!< CAN required parameters */这是初始化相应的参数 , ~- _' R4 _: S$ g5 W, o/ p CanTxMsgTypeDef* pTxMsg; /*!< Pointer to transmit structure */----类似于UART的--TX 6 W" `2 O( `$ f ~! j CanRxMsgTypeDef* pRxMsg; /*!< Pointer to reception structure */类似于UART的--RX $ J& v e0 B; p! W' b: M HAL_LockTypeDef Lock; /*!< CAN locking object */ H+ ~* b) G' _- Q$ k& i * Y! x$ _! S& A9 p' o9 Y) @8 Y8 j3 X __IO HAL_CAN_StateTypeDef State; /*!< CAN communication state */; V" G: |* R+ O; h : ?. O" k3 h h& h __IO HAL_CAN_ErrorTypeDef ErrorCode; /*!< CAN Error code */' ~$ G; w; f" z, {8 X / S, p- I4 O$ w }CAN_HandleTypeDef;% ~/ C: q2 n& F" t / T" g! Y+ @+ | CAN∴寄存器地址: Q- l$ _. o' _( w$ \; C8 [* b typedef struct {4 u1 s/ I: ?; L( Z+ X0 C1 _ __IO uint32_t MCR; /*!< CAN master control register, Address offset: 0x00 */ __IO uint32_t MSR; /*!< CAN master status register, Address offset: 0x04 */7 H7 U8 p4 ]. a& N- n6 k __IO uint32_t TSR; /*!< CAN transmit status register, Address offset: 0x08 */ __IO uint32_t RF0R; /*!< CAN receive FIFO 0 register, Address offset: 0x0C *// C1 E. }% N6 u$ u' K2 H7 [ __IO uint32_t RF1R; /*!< CAN receive FIFO 1 register, Address offset: 0x10 */5 p g5 W6 G$ Z) u __IO uint32_t IER; /*!< CAN interrupt enable register, Address offset: 0x14 */2 ~9 K$ ]8 S; C9 T+ S4 a: g __IO uint32_t ESR; /*!< CAN error status register, Address offset: 0x18 */, A1 a( Y- m U& w& ^ g/ M __IO uint32_t BTR; /*!< CAN bit timing register, Address offset: 0x1C */ uint32_t RESERVED0[88]; /*!< Reserved, 0x020 - 0x17F */9 Y- J# q, y5 v9 t' v CAN_TxMailBox_TypeDef sTxMailBox[3]; /*!< CAN Tx MailBox, Address offset: 0x180 - 0x1AC */ CAN_FIFOMailBox_TypeDef sFIFOMailBox[2]; /*!< CAN FIFO MailBox, Address offset: 0x1B0 - 0x1CC */. R {3 g% B+ ?. A- b uint32_t RESERVED1[12]; /*!< Reserved, 0x1D0 - 0x1FF */4 R# B* _( R5 k2 E# | __IO uint32_t FMR; /*!< CAN filter master register, Address offset: 0x200 */1 C5 T& W* i& p `$ S6 P __IO uint32_t FM1R; /*!< CAN filter mode register, Address offset: 0x204 */ uint32_t RESERVED2; /*!< Reserved, 0x208 */ __IO uint32_t FS1R; /*!< CAN filter scale register, Address offset: 0x20C */ uint32_t RESERVED3; /*!< Reserved, 0x210 */: {8 B, `+ B6 X( | __IO uint32_t FFA1R; /*!< CAN filter FIFO assignment register, Address offset: 0x214 */ uint32_t RESERVED4; /*!< Reserved, 0x218 */ __IO uint32_t FA1R; /*!< CAN filter activation register, Address offset: 0x21C */, l2 K# [( [4 s uint32_t RESERVED5[8]; /*!< Reserved, 0x220-0x23F */ CAN_FilterRegister_TypeDef sFilterRegister[28]; /*!< CAN Filter Register, Address offset: 0x240-0x31C */- m/ ?: ?9 b* x7 R. [0 k }CAN_TypeDef; typedef struct {1 f: z3 A( v/ x6 }' i. @ {7 X* ~ __IO uint32_t TIR; /*!< CAN TX mailbox identifier register */! p4 u# Y/ ^6 X$ \9 R8 a4 a8 q __IO uint32_t TDTR; /*!< CAN mailbox data length control and time stamp register */ __IO uint32_t TDLR; /*!< CAN mailbox data low register */# g6 z! w" S: a% z) K __IO uint32_t TDHR; /*!< CAN mailbox data high register */ }CAN_TxMailBox_TypeDef; /**& p5 E. D Y' Q- b2 o/ p * @brief Controller Area Network FIFOMailBox* ? |: C: H, X/ B8 v* u" ? */ typedef struct2 z" l$ I1 ~8 v3 U { __IO uint32_t RIR; /*!< CAN receive FIFO mailbox identifier register */( ~% S! I! z2 D6 O __IO uint32_t RDTR; /*!< CAN receive FIFO mailbox data length control and time stamp register */. R% C0 a: L4 T2 f% o __IO uint32_t RDLR; /*!< CAN receive FIFO mailbox data low register */ __IO uint32_t RDHR; /*!< CAN receive FIFO mailbox data high register */ }CAN_FIFOMailBox_TypeDef;: \# r! V7 ]+ H' d9 W0 {' ] /** * @brief Controller Area Network FilterRegister1 j$ c" M& D; d( S */ typedef struct/ ~$ _' U2 k4 l7 Y+ } {5 U {3 L+ X5 z& Q' E9 g0 W( e: k __IO uint32_t FR1; /*!< CAN Filter bank register 1 */, z7 J! k4 ~1 L; D5 T4 e# J! n1 N __IO uint32_t FR2; /*!< CAN Filter bank register 1 */3 v$ h$ u* F9 Q }CAN_FilterRegister_TypeDef; typedef struct { uint32_t Prescaler; /*!< Specifies the length of a time quantum. This parameter must be a number between Min_Data = 1 and Max_Data = 1024. */ . w; `! L. r# }! h: K: w+ H uint32_t Mode; /*!< Specifies the CAN operating mode.% z7 |& A9 R8 n" i5 x! x This parameter can be a value of @ref CAN_operating_mode */ uint32_t SJW; /*!< Specifies the maximum number of time quanta the CAN hardware is allowed to lengthen or shorten a bit to perform resynchronization.5 y- k6 {; N/ ?9 _5 _ This parameter can be a value of @ref CAN_synchronisation_jump_width */% F' j$ |( h! [/ C uint32_t BS1; /*!< Specifies the number of time quanta in Bit Segment 1. This parameter can be a value of @ref CAN_time_quantum_in_bit_segment_1 */9 U. k4 F% N/ e5 Q uint32_t BS2; /*!< Specifies the number of time quanta in Bit Segment 2. This parameter can be a value of @ref CAN_time_quantum_in_bit_segment_2 */ + s: u! X# I# P, Y, g uint32_t TTCM; /*!< Enable or disable the time triggered communication mode. This parameter can be set to ENABLE or DISABLE. */: P7 S6 O# r" ^: z+ F7 c/ S# B: @ 7 [( L; M- {. s( r uint32_t ABOM; /*!< Enable or disable the automatic bus-off management. This parameter can be set to ENABLE or DISABLE. */ uint32_t AWUM; /*!< Enable or disable the automatic wake-up mode. & _) `5 X s. l" ~5 _5 r+ G3 K This parameter can be set to ENABLE or DISABLE. */ ( m0 L4 T- W, j3 i% z5 t w uint32_t NART; /*!< Enable or disable the non-automatic retransmission mode.; v4 {1 q# g4 u# V This parameter can be set to ENABLE or DISABLE. */4 ^1 i p$ X n0 c& I+ h7 I uint32_t RFLM; /*!< Enable or disable the Receive FIFO Locked mode.* D& o1 Y+ X* X* l' _ This parameter can be set to ENABLE or DISABLE. */ " a' M: ~2 d: x& u uint32_t TXFP; /*!< Enable or disable the transmit FIFO priority.$ E! g: h: Z0 ?, U4 R& M1 G This parameter can be set to ENABLE or DISABLE. */8 i0 P9 f% w4 X5 } }CAN_InitTypeDef; typedef struct1 _5 P8 a( l$ H, z {1 P) A( M" O) n7 z C uint32_t StdId; /*!< Specifies the standard identifier. This parameter must be a number between Min_Data = 0 and Max_Data = 0x7FF. */ . [* R% I3 K* p9 {, n V, |* E7 ?0 I ! ?# f* A' a( r$ c9 F4 d uint32_t ExtId; /*!< Specifies the extended identifier. This parameter must be a number between Min_Data = 0 and Max_Data = 0x1FFFFFFF. */ ! y& M2 G3 {& u8 I * l" m( @; m8 b, k& Q1 } uint32_t IDE; /*!< Specifies the type of identifier for the message that will be transmitted. This parameter can be a value of @ref CAN_identifier_type */9 |9 G# F) g5 p2 X uint32_t RTR; /*!< Specifies the type of frame for the message that will be transmitted.' `1 N9 C F* L9 i This parameter can be a value of @ref CAN_remote_transmission_request */ uint32_t DLC; /*!< Specifies the length of the frame that will be transmitted. This parameter must be a number between Min_Data = 0 and Max_Data = 8. */ ! Y1 x( m# f# C/ S' h1 l! h( | uint32_t Data[8]; /*!< Contains the data to be transmitted. This parameter must be a number between Min_Data = 0 and Max_Data = 0xFF. */4 i) k! v9 _- o3 R) M, G2 b }CanTxMsgTypeDef; # B6 v& k/ k5 e typedef struct { uint32_t StdId; /*!< Specifies the standard identifier. This parameter must be a number between Min_Data = 0 and Max_Data = 0x7FF. */ ! P+ ^! W+ P3 J8 u/ G0 ]/ r uint32_t ExtId; /*!< Specifies the extended identifier.& t6 i9 \7 u; n0 o This parameter must be a number between Min_Data = 0 and Max_Data = 0x1FFFFFFF. */ ; ~5 s. E5 S4 { uint32_t IDE; /*!< Specifies the type of identifier for the message that will be received." L* U4 a9 f, F This parameter can be a value of @ref CAN_identifier_type */" F* c N3 ~! k4 t + z8 |. D/ n/ n( Q uint32_t RTR; /*!< Specifies the type of frame for the received message. This parameter can be a value of @ref CAN_remote_transmission_request */8 I- ^: a K! j6 P0 m2 k5 _ 0 z. W- o u+ _ uint32_t DLC; /*!< Specifies the length of the frame that will be received. This parameter must be a number between Min_Data = 0 and Max_Data = 8. */$ _1 R$ \: h$ V uint32_t Data[8]; /*!< Contains the data to be received. This parameter must be a number between Min_Data = 0 and Max_Data = 0xFF. */ . o k2 b! H$ r. v7 R uint32_t FMI; /*!< Specifies the index of the filter the message stored in the mailbox passes through.& v/ k1 a" f/ M, B! g4 G1 [ h. H This parameter must be a number between Min_Data = 0 and Max_Data = 0xFF. */ : s; A2 i" |; ^" d uint32_t FIFONumber; /*!< Specifies the receive FIFO number. This parameter can be CAN_FIFO0 or CAN_FIFO1 */2 q, h3 ^! m0 X4 U) d , ]2 D7 B/ S7 S1 g- I* x: b! s }CanRxMsgTypeDef;+ a3 b: x0 @2 @9 t- s2 @0 \ 还有CAN异步跳转的数据宽度 #define CAN_SJW_1TQ ((uint32_t)0x00000000) /*!< 1 time quantum *// B$ c* n; l! [ #define CAN_SJW_2TQ ((uint32_t)CAN_BTR_SJW_0) /*!< 2 time quantum */ #define CAN_SJW_3TQ ((uint32_t)CAN_BTR_SJW_1) /*!< 3 time quantum */7 y* [0 H$ n+ p7 T3 S #define CAN_SJW_4TQ ((uint32_t)CAN_BTR_SJW) /*!< 4 time quantum */ ; E# g$ c$ q2 h& ^ 9 Q, R! W9 ^$ d5 b; o5 J4 K8 Q5 s T typedef struct {0 V d, l! w( D" E: w8 J uint32_t StdId; /*!< Specifies the standard identifier. This parameter must be a number between Min_Data = 0 and Max_Data = 0x7FF. */ 4 h+ [. y! \8 `7 d. n uint32_t ExtId; /*!< Specifies the extended identifier. This parameter must be a number between Min_Data = 0 and Max_Data = 0x1FFFFFFF. */ # Z% V9 O% W0 E+ l3 i : F! i$ i* C9 ]6 q6 w$ Z3 k uint32_t IDE; /*!< Specifies the type of identifier for the message that will be received. This parameter can be a value of @ref CAN_identifier_type */% |" D8 Z9 ^ z) A 4 B+ Q9 W8 x3 F3 C uint32_t RTR; /*!< Specifies the type of frame for the received message.. x( o0 W) v, J This parameter can be a value of @ref CAN_remote_transmission_request */ uint32_t DLC; /*!< Specifies the length of the frame that will be received.$ }! i9 S$ D2 Z5 z This parameter must be a number between Min_Data = 0 and Max_Data = 8. */ & [# \8 N! @" q+ n& @ uint32_t Data[8]; /*!< Contains the data to be received. This parameter must be a number between Min_Data = 0 and Max_Data = 0xFF. */$ N: g& ~5 L' t9 S4 j3 D uint32_t FMI; /*!< Specifies the index of the filter the message stored in the mailbox passes through. This parameter must be a number between Min_Data = 0 and Max_Data = 0xFF. */ uint32_t FIFONumber; /*!< Specifies the receive FIFO number. ( R* o5 a8 l) d. E This parameter can be CAN_FIFO0 or CAN_FIFO1 */ }CanRxMsgTypeDef; 这是CAN有关接收数据的参数 还有其他的数据结构定义,不过先回来看我的INIT函数 HAL_StatusTypeDef HAL_CAN_Init(CAN_HandleTypeDef* hcan) {! e4 T0 f# p! ?' P uint32_t status = CAN_INITSTATUS_FAILED; /* Default init status */7 b* R7 D/ u! K" p& C+ q1 u; d uint32_t tickstart = 0; /* Check CAN handle */ if(hcan == NULL)0 L3 X0 q/ K' a3 j: o0 ^( l {: t o+ {4 w1 y) |/ ^ return HAL_ERROR; }; \; |) m' W( N7 D! T$ C / |7 C% q* s f /* Check the parameters */7 `( s. S- v/ n) w* q assert_param(IS_CAN_ALL_INSTANCE(hcan->Instance)); assert_param(IS_FUNCTIONAL_STATE(hcan->Init.TTCM));- }' l% a4 G7 S assert_param(IS_FUNCTIONAL_STATE(hcan->Init.ABOM)); assert_param(IS_FUNCTIONAL_STATE(hcan->Init.AWUM));/ N: `- ~: B& o+ N Z/ B+ m( R$ a) X assert_param(IS_FUNCTIONAL_STATE(hcan->Init.NART));9 Y q4 J7 x, o9 m assert_param(IS_FUNCTIONAL_STATE(hcan->Init.RFLM));7 j/ s# K8 v2 o0 _& j2 A assert_param(IS_FUNCTIONAL_STATE(hcan->Init.TXFP));9 A: m% c6 h5 [ assert_param(IS_CAN_MODE(hcan->Init.Mode));' b8 i% ^3 B/ N f+ C, L assert_param(IS_CAN_SJW(hcan->Init.SJW)); n+ S2 Q3 s7 T/ c assert_param(IS_CAN_BS1(hcan->Init.BS1)); assert_param(IS_CAN_BS2(hcan->Init.BS2));- \8 x( g1 k5 t4 p2 \ assert_param(IS_CAN_PRESCALER(hcan->Init.Prescaler)); if(hcan->State == HAL_CAN_STATE_RESET) {- O- K; v/ F0 D+ ^7 ^' l /* Init the low level hardware */ HAL_CAN_MspInit(hcan); } /* Initialize the CAN state*/ hcan->State = HAL_CAN_STATE_BUSY;! {& M- Z7 M3 A" p) X% a$ K7 ? ( C0 \( x" y- _9 u* b0 j /* Exit from sleep mode */, G/ @& C- y$ a3 P hcan->Instance->MCR &= (~(uint32_t)CAN_MCR_SLEEP);% P* ^ l2 p# h, X ] 9 |; ?- {' F; P! U2 p2 v8 P7 q /* Request initialisation */5 j& P" o: |8 z% V E/ O hcan->Instance->MCR |= CAN_MCR_INRQ ; /* Get tickstart */ tickstart = HAL_GetTick(); 9 c! a( O$ [8 T6 }) j& X/ m) K5 u /* Wait the acknowledge */6 f* g4 C: {' Y. I4 I3 U4 } while((hcan->Instance->MSR & CAN_MSR_INAK) != CAN_MSR_INAK) {( _8 T$ O, }: Z: d) ` E if((HAL_GetTick() - tickstart) > HAL_CAN_DEFAULT_TIMEOUT)1 w# N0 w' L5 r, W4 H { hcan->State= HAL_CAN_STATE_TIMEOUT; return HAL_TIMEOUT;. O: c/ P! B, U' p* E* |+ ] }2 @1 p7 C4 e7 R/ Q }$ x+ {9 j+ D0 | 1 A& z1 ]* A4 y /* Check acknowledge */# a4 G" N e a% H1 | if ((hcan->Instance->MSR & CAN_MSR_INAK) == CAN_MSR_INAK) { /* Set the time triggered communication mode */ if (hcan->Init.TTCM == ENABLE). b! x6 Z2 i' Z3 @: ?; Z {! D& E N; D1 C( W hcan->Instance->MCR |= CAN_MCR_TTCM; }2 K% p/ k/ `4 {; q; s else) E' P3 Z, X- S7 I {8 n* {! V( [4 m+ X% Q+ ^ hcan->Instance->MCR &= ~(uint32_t)CAN_MCR_TTCM; } /* Set the automatic bus-off management */ if (hcan->Init.ABOM == ENABLE)7 d/ }; H3 K. U6 M- O* P { hcan->Instance->MCR |= CAN_MCR_ABOM; }! p% y' k* o% L# ~8 q else# ~; J( ~# ]( F# n. v9 E* d: N4 P {& y! Y" X) C% w. \% _ hcan->Instance->MCR &= ~(uint32_t)CAN_MCR_ABOM;: P, h' L& J; N' {8 F5 ^/ H1 C }1 k/ K" ^. y( J /* Set the automatic wake-up mode */3 ^% d( f) b9 H# _0 ? if (hcan->Init.AWUM == ENABLE) { hcan->Instance->MCR |= CAN_MCR_AWUM; }& ~* L# x9 e9 |2 E2 i) U else# T! ?/ T4 ^! B; e0 J$ U" z& `. x {* K% }0 Q8 L# L6 v4 t- x6 d2 H hcan->Instance->MCR &= ~(uint32_t)CAN_MCR_AWUM; }% D$ A4 U6 Y5 B: _' i . l" F5 \7 W0 P2 H! p /* Set the no automatic retransmission */ U/ i- r1 V7 |2 u7 x5 o if (hcan->Init.NART == ENABLE) { hcan->Instance->MCR |= CAN_MCR_NART;3 {4 ^. Z- ?6 K7 E: | } else+ y/ S; l* v6 P# u, B- } Q { hcan->Instance->MCR &= ~(uint32_t)CAN_MCR_NART;+ `% A! ^' J8 q4 h+ t7 t }# w: m L8 [! Q # ]- N+ P. Y2 U. o /* Set the receive FIFO locked mode */ if (hcan->Init.RFLM == ENABLE)7 O8 q* G6 h+ r/ R { hcan->Instance->MCR |= CAN_MCR_RFLM; }: l' {6 u0 S1 A& I4 d0 x% H% K else { hcan->Instance->MCR &= ~(uint32_t)CAN_MCR_RFLM; } 9 \# N' f9 b/ {. Z /* Set the transmit FIFO priority */ if (hcan->Init.TXFP == ENABLE) { hcan->Instance->MCR |= CAN_MCR_TXFP;5 j' {* S6 k, e/ P: k m }- w; N+ |4 V+ k0 |7 Q7 l- ~ else { hcan->Instance->MCR &= ~(uint32_t)CAN_MCR_TXFP; }' y# s8 B- r8 C! t3 l6 B" s y* I1 w /* Set the bit timing register */ hcan->Instance->BTR = (uint32_t)((uint32_t)hcan->Init.Mode) | \) O. a7 Y0 D% x. C Z1 Y! B ((uint32_t)hcan->Init.SJW) | \ ((uint32_t)hcan->Init.BS1) | \ ((uint32_t)hcan->Init.BS2) | \ ((uint32_t)hcan->Init.Prescaler - 1);5 F! _/ }3 Z2 s9 ^3 i) r% D& s$ Q1 q6 o 3 s. e7 N; P) P" H: A" }1 N" X5 J+ c /* Request leave initialisation */1 Z4 Q( _: T/ j- Y3 J- K0 ~ hcan->Instance->MCR &= ~(uint32_t)CAN_MCR_INRQ;/ c* [' y, q3 m* |) t* s /* Get timeout */ tickstart = HAL_GetTick(); + P: K( P9 m3 C* |" g5 c: }. Z /* Wait the acknowledge */ while((hcan->Instance->MSR & CAN_MSR_INAK) == CAN_MSR_INAK)9 @1 m* O: }+ z, f- C" i { if((HAL_GetTick() - tickstart) > HAL_CAN_DEFAULT_TIMEOUT)2 f: q" Q0 l6 k" @: Q9 K { hcan->State= HAL_CAN_STATE_TIMEOUT;9 d8 O1 I& i7 m' n! v6 y" m return HAL_TIMEOUT;! n2 o( U0 F& r4 A" E5 Y, i) b1 i1 ] }" O$ y, I$ a+ |" ?( x }0 l2 e( \. M* V1 P6 p : s2 t0 W- S/ O /* Check acknowledged */ if ((hcan->Instance->MSR & CAN_MSR_INAK) != CAN_MSR_INAK) {! t. e! ^4 w% {2 o. [9 u" q status = CAN_INITSTATUS_SUCCESS; }, j# G; S4 Y, ^0 v' z0 f }) B' J% M4 W- ` Z, s# B8 ?7 K3 j9 b" t if(status == CAN_INITSTATUS_SUCCESS)& d3 p5 I: w: J1 A& D {* Q3 T8 X, D e0 |: { N+ v6 x /* Set CAN error code to none */ hcan->ErrorCode = HAL_CAN_ERROR_NONE; % X& D2 X/ P$ d, n5 I9 ?8 F$ ?: k /* Initialize the CAN state */ hcan->State = HAL_CAN_STATE_READY; " e- f0 S. L/ T- L! r& N /* Return function status */ return HAL_OK; }2 q, F) U W6 M9 M# |+ T: O else { /* Initialize the CAN state */# M+ ]. B3 h/ W$ Y8 \ hcan->State = HAL_CAN_STATE_ERROR; /* Return function status */# ~! F6 \1 O% ~( R return HAL_ERROR;+ i. {- z" {: q+ s }& B. [- n9 J ]! \" N1 ?+ k' K } k+ i- P7 s6 F% D 7 [$ k0 r( [5 P |
| CAN工业上用的多点吧,记得有一次看见万东的高频机使用了 can,还特地学习了下CAN的原理 |
谢谢分享。学习了
| 我也在弄CAN。打算移植CANOPEN协议做主站 |
| 坚持就是胜利系列~ |
| 谢谢分享。 |
| 谢谢分享。 |
| 楼主辛苦了! |
| 不明觉厉,顶 |
| 工业上CAN多,还有其他一些,个人汽车 |
没怎么看懂。。。。 |
| 不懂帮顶! |
| 不明觉厉。。。。。。。。。。。 |
