stmf429 usart1 进不了接收中断, 轮询可以接收
liangyuejie 提问时间:2015-3-24 11:15 /
赞 收藏 评论19 发布时间:2015-3-24 11:15
19个回答
liangyuejie 回答时间:2015-3-25 11:32:00
回12楼: 不是没有复用模式,是没有复用时钟
拼命三郎 回答时间:2015-3-25 12:45:35
拼命三郎 回答时间:2015-3-25 12:46:50
废鱼 回答时间:2015-3-25 14:54:57
优先级不对吧,你改成0试试。这我得看一下M4内核手册。
liangyuejie 回答时间:2015-3-25 16:44:11
谢谢大家,同样的程序,因泡桐样例程序之后,工作正常了:
// NVIC configration
    NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
    // USART configuation
    USART_Config();
void USART_Config_USART1()
        GPIO_InitTypeDef    GPIO_InitStructure;
        USART_InitTypeDef   USART_InitStructure;
        NVIC_InitTypeDef    NVIC_InitStructure;
        // Enable GPIO clock
    RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE);
        // Enable USART clock
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);
    // Configure USART Tx as alternate function
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
        GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
        // Configure USART Rx as alternate function
        // Config AF pin
    GPIO_PinAFConfig(GPIOA, GPIO_PinSource9, GPIO_AF_USART1);
    GPIO_PinAFConfig(GPIOA, GPIO_PinSource10, GPIO_AF_USART1);
    // Initialize USART
    USART_InitStructure.USART_BaudRate = 9600;
    USART_InitStructure.USART_Parity = USART_Parity_No;
        USART_Init(USART1, &USART_InitStructure);
        // Enable USART
    USART_Cmd(USART1, ENABLE);
        #if defined(INNO_DEBUG)
                USART1_SendDataStrings("USART1 enabled! \n");
        #endif
    // Initialize USART interrupt on NVIC
        NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x0;
    NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0xF;
                USART1_SendDataStrings("USART1 NVIC enabled! \n");
        #endif
    // Enable USART interrupt
    USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
                USART1_SendDataStrings("USART1 IT_RXNE enabled! \n");
        #endif
        //USART_ITConfig(USART1, USART_IT_TXE, ENABLE);
                USART1_SendDataStrings("USART1 IT_TXE enabled! \n");
        #endif
void USART_Config()
        USART_Config_USART1();
                USART1_SendDataStrings("USART1 configuration finished! \n");
        #endif
                USART1_SendDataStrings("USART all configuration finished! \n");
        #endif
it.c
void USART1_IRQHandler(void)
    uint16_t receiveData = 0;
    if(USART_GetITStatus(USART1, USART_IT_RXNE) != RESET)
        receiveData = USART_ReceiveData(USART1);
        USART1_SendDataCharacter(receiveData);
USART_GetITStatus && USART_ReceiveData
USART_GetFlagStatus && USART_ReceiveData
软件流清标志位都可
12
