stmf429 usart1 进不了接收中断, 轮询可以接收
liangyuejie 提问时间:2015-3-24 11:15 /
刚学单片机, 弄了2天没有搞定,希望大家帮帮忙。谢谢!
void USART_Config_USART1()
    GPIO_InitTypeDef     GPIO_InitStructure9;
    GPIO_InitTypeDef     GPIO_InitStructure10;
    USART_InitTypeDef  USART_InitStructure;
    NVIC_InitTypeDef   NVIC_InitStructure;
    // Enable GPIO clock
  RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE);
    // Enable USART clock
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);
  // Configure USART Tx as alternate function
  GPIO_InitStructure9.GPIO_Pin = GPIO_Pin_9;
    GPIO_InitStructure9.GPIO_Mode = GPIO_Mode_AF;
    GPIO_InitStructure9.GPIO_OType = GPIO_OType_PP;
  GPIO_InitStructure9.GPIO_Speed = GPIO_Speed_50MHz;
    GPIO_InitStructure9.GPIO_PuPd = GPIO_PuPd_UP;
  GPIO_Init(GPIOA, &GPIO_InitStructure9);
    // Configure USART Rx as alternate function
  GPIO_InitStructure10.GPIO_Pin = GPIO_Pin_10;
    GPIO_InitStructure10.GPIO_Mode = GPIO_Mode_AF;
    GPIO_InitStructure10.GPIO_PuPd = GPIO_PuPd_NOPULL;
  GPIO_Init(GPIOA, &GPIO_InitStructure10);
    // Config AF pin
  GPIO_PinAFConfig(GPIOA, GPIO_PinSource9, GPIO_AF_USART1);
  GPIO_PinAFConfig(GPIOA, GPIO_PinSource10, GPIO_AF_USART1);
  // Initialize USART
  USART_InitStructure.USART_BaudRate = 9600;
  USART_InitStructure.USART_Parity = USART_Parity_No;
    USART_Init(USART1, &USART_InitStructure);
    // Enable USART interrupt
  USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
    //USART_ITConfig(USART1, USART_IT_TXE, ENABLE);
    // Enable USART
  USART_Cmd(USART1, ENABLE);
    // Initialize USART interrupt on NVIC
    NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x0F;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x0F;
void USART1_IRQHANDLER(void)
  if(USART_GetFlagStatus(USART1, USART_FLAG_RXNE) != RESET)
        USART_GetFlagStatus(USART1, USART_FLAG_TC);
        // Read one byte from the receive data register
        USART_SendData(USART1, USART_ReceiveData(USART1));
        while(USART_GetFlagStatus(USART1, USART_FLAG_TC) == RESET)
赞 收藏 评论19 发布时间:2015-3-24 11:15
19个回答
liangyuejie 回答时间:2015-3-25 16:44:11
谢谢大家,同样的程序,因泡桐样例程序之后,工作正常了:
// NVIC configration
    NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
    // USART configuation
    USART_Config();
        GPIO_InitTypeDef    GPIO_InitStructure;
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
        GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
        // Config AF pin
    // Initialize USART
        // Enable USART
        #if defined(INNO_DEBUG)
                USART1_SendDataStrings("USART1 enabled! \n");
        #endif
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x0;
    NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0xF;
                USART1_SendDataStrings("USART1 NVIC enabled! \n");
        #endif
                USART1_SendDataStrings("USART1 IT_RXNE enabled! \n");
        #endif
                USART1_SendDataStrings("USART1 IT_TXE enabled! \n");
        #endif
void USART_Config()
        USART_Config_USART1();
                USART1_SendDataStrings("USART1 configuration finished! \n");
        #endif
                USART1_SendDataStrings("USART all configuration finished! \n");
        #endif
it.c
void USART1_IRQHandler(void)
    uint16_t receiveData = 0;
    if(USART_GetITStatus(USART1, USART_IT_RXNE) != RESET)
        receiveData = USART_ReceiveData(USART1);
        USART1_SendDataCharacter(receiveData);
USART_GetITStatus && USART_ReceiveData
USART_GetFlagStatus && USART_ReceiveData
软件流清标志位都可
liangyuejie 回答时间:2015-3-24 16:24:08
就是不行,我实在找不到原因:
        USART_ClearITPendingBit(USART1, USART_IT_RXNE);
        USART_ClearFlag(USART1, USART_FLAG_RXNE);
        GPIO_InitStructure10.GPIO_PuPd = GPIO_PuPd_UP;
        // Config AF pin
    // Initialize USART
        // Enable USART
                USART1_SendDataStrings("USART1 CMD enabled! \n");
        #endif
        #endif
void USART_Config()
        /* USART configuration */
    USART_Config();
                USART1_SendDataStrings("USART configuration finished! \n");
        #endif
liangyuejie 回答时间:2015-3-25 11:05:00
发现了一点问题,但问题最终没有解决。看似一进中断就死机
        // Enable USART
        #endif
问题: 使能中断不能在使能NVIC 表格之前
kqh1120 回答时间:2015-3-24 11:32:00
小蚂蚁快溜跑 回答时间:2015-3-24 13:14:23
复用端口,时钟没有打开
AnswerRaul 回答时间:2015-3-24 13:40:32
重新配置一下中断优先级;
还不行,把Rx设置成上拉试试,我一直都是Rx跟Tx都上拉。
stary666 回答时间:2015-3-24 14:06:32
帮顶。。。。。。。。。。
liangyuejie 回答时间:2015-3-24 16:08:16
谢谢大家先,f429没有复用时钟的概念。
liangyuejie 回答时间:2015-3-24 16:35:14
CR1 RXNEIE = 1
DR 接收数据正确
SR RXNE = 0 始终
wamcncn 回答时间:2015-3-24 16:43:20
容易出错的地方,看看参考手册
liangyuejie 回答时间:2015-3-24 16:50:14
#define RCC_APB2Periph_USART1            ((uint32_t)0x00000010)
#define RCC_AHB1Periph_GPIOA             ((uint32_t)0x00000001)
应该也没有问题
alvin_ 回答时间:2015-3-24 19:25:10
帮顶.................
左岸右岸 回答时间:2015-3-24 22:09:46
没有复用模式就用模拟模式试试
木木鱼 回答时间:2015-3-25 09:04:02
不懂,帮顶
zhangdaijin 回答时间:2015-3-25 09:32:32
看看帮顶!
12下一页
