stm32f1xx HAL库CanRxMsgTypeDef定义错误【已解决】
captainliuy 提问时间:2015-3-26 10:45 /
  1. typedef struct
  2. {
  3.   uint32_t StdId;       /*!< Specifies the standard identifier.
  4.                              This parameter must be a number between Min_Data = 0 and Max_Data = 0x7FF. */
  5.   uint32_t ExtId;       /*!< Specifies the extended identifier.
  6.                              This parameter must be a number between Min_Data = 0 and Max_Data = 0x1FFFFFFF. */
  7.   uint32_t IDE;         /*!< Specifies the type of identifier for the message that will be received.
  8.                              This parameter can be a value of @ref CAN_identifier_type */
  9.   uint32_t RTR;         /*!< Specifies the type of frame for the received message.
  10.                              This parameter can be a value of @ref CAN_remote_transmission_request */
  11.   uint32_t DLC;         /*!< Specifies the length of the frame that will be received.
  12.                              This parameter must be a number between Min_Data = 0 and Max_Data = 8. */
  13.   uint32_t Data[8];     /*!< Contains the data to be received.
  14.                              This parameter must be a number between Min_Data = 0 and Max_Data = 0xFF. */
  15.   uint32_t FMI;         /*!< Specifies the index of the filter the message stored in the mailbox passes through.
  16.                              This parameter must be a number between Min_Data = 0 and Max_Data = 0xFF. */
  17.   uint32_t FIFONumber;  /*!< Specifies the receive FIFO number.
  18.                              This parameter can be a value of @ref CAN_receive_FIFO_number_constants */
  19. }CanRxMsgTypeDef;
can接收数据应该是8个字节
在“STM32Cube_FW_F1_V1.2.0”中已fix。
赞 收藏 1 评论7 发布时间:2015-3-26 10:45
7个回答
肖久 回答时间:2015-3-27 09:13:27
帮顶 学习学习
党国特派员 回答时间:2015-3-27 09:32:13
是定的的8字节数组,哪里有错了? blank.png blank.png blank.png blank.png blank.png blank.png blank.png blank.png blank.png blank.png
wamcncn 回答时间:2015-3-30 14:17:31
谢谢分享
captainliuy 回答时间:2015-5-5 14:14:16
这样定义也许不是错误的,只是和CAN协议不同,初次见到会觉得有问题
Tension 回答时间:2015-5-6 17:05:12
对不对不能确定,但显然太随意了,浪费空间。
jameslee 回答时间:2015-8-4 14:01:41
他这样定义确实有些奇怪,但是他发送或接受的时候是没错的,注意给它赋值的时候就不要用memcpy这类接口函数了,你8个字节其实只是对数组的前两个成员赋值了,你需要一个个单独赋值
晴天-380557 回答时间:2016-2-26 14:59:28
这也有错????
