HAL_ADC_Init() 中的一段代码 if (hadc->Init.ScanConvMode == ADC_SCAN_ENABLE) { tmp_sqr1 = ADC_SQR1_L_SHIFT(hadc->Init.NbrOfConversion); }复制代码main.c 中adc 初始化的代码 void MX_ADC1_Init(void) { ADC_ChannelConfTypeDef sConfig; /**Common config */ hadc1.Instance = ADC1; hadc1.Init.ScanConvMode = ENABLE; hadc1.Init.ContinuousConvMode = DISABLE; hadc1.Init.DiscontinuousConvMode = DISABLE; hadc1.Init.ExternalTrigConv = ADC_SOFTWARE_START; hadc1.Init.DataAlign = ADC_DATAALIGN_RIGHT; hadc1.Init.NbrOfConversion = 1; HAL_ADC_Init(&hadc1); /**Configure Regular Channel */ sConfig.Channel = ADC_CHANNEL_4; sConfig.Rank = 1; sConfig.SamplingTime = ADC_SAMPLETIME_1CYCLE_5; HAL_ADC_ConfigChannel(&hadc1, &sConfig); }复制代码宏定义 ADC_SCAN_ENABLE 和 ENABLE是永远不会相等的,所以SQR1寄存器无法配置。
