void I2C_EEPROM_Init(void) {# P$ W3 D" V- ?; a; h GPIO_I2CSCLInitial(); GPIO_I2CSDAInitial(); RCC->APB1ENR |= RCC_APB1ENR_I2CEN; /* (1) */: ~! T, F( u y- J I2C_CHANNEL->TIMINGR = I2C_TIMINGR; I2C_CHANNEL->CR1 = I2C_CR1_PE; /* (2) */ } void I2C_TransferConfig(uint8_t DevAddress,- L& i' t: z; @+ |8 W uint16_t Size,8 c" r/ N; [# S' Q$ F uint32_t Mode,# e$ t' j4 r8 W! N2 M1 y* a uint32_t Request. ^/ K, U+ B$ Y4 x ) { /* clear tmpreg specific bits */& z0 ^4 d+ k9 k+ a: k$ D I2C_CHANNEL->CR2 &= (uint32_t) ~((uint32_t)(I2C_CR2_SADD | I2C_CR2_NBYTES \4 z z9 e+ ]) Q; l/ y8 ], e | I2C_CR2_RELOAD | I2C_CR2_AUTOEND | I2C_CR2_RD_WRN \ | I2C_CR2_START | I2C_CR2_STOP));) A0 P5 \9 u, i5 C3 A! r ; T1 l! s5 x# t' J. D; P& H# h1 t /* update tmpreg */0 v4 u& @* | h4 s& |' O) A #if I2C_ADDRESSINGMODE_7BIT H5 g1 X& P. f5 I7 |- o3 n I2C_CHANNEL->CR2 |= (uint32_t)(((uint32_t)(DevAddress << 1) & I2C_CR2_SADD) \. w4 R, G, P' s, | | (((uint32_t)Size << 16) & I2C_CR2_NBYTES) \% Q7 R [$ t% Y! B3 F | (uint32_t)Mode | (uint32_t)Request); #else% S0 j! N3 i, L; ?3 I+ r( M I2C_CHANNEL->CR2 |= (uint32_t)(((uint32_t)DevAddress & I2C_CR2_SADD) \ | (((uint32_t)Size << 16) & I2C_CR2_NBYTES) \9 k8 g: l/ n9 U | (uint32_t)Mode | (uint32_t)Request);( j O7 a) b& W |% k, t- g #endif8 g$ Y0 A, F" Z% ~ } void D; X- q. k2 c0 B I2C_Master_Transmit(uint8_t DevAddress, uint8_t eerom_start_address,) l8 i- R; a8 @# U7 H) {7 A const uint8_t * pData,/ l# d, O+ r s0 H, l$ ~1 x, P uint16_t Size ) m0 q" q T1 K' j8 a- ^* ^# j. }% r {; N9 g8 @8 [/ O uint32_t sizetmp;. z, Z4 s6 I3 I( L$ G E% v5 C) }5 b/ M if ((pData == NULL) || (Size == 0))+ X4 [( F9 I# R3 W, m7 M1 S5 S [" Y {! O/ j% \" H% R% \, Y return; } while (__HAL_I2C_GET_FLAG(I2C_ISR_BUSY)) { } 8 p6 M4 G% K( N6 Q, A# ^" w: M /* Send Slave Address */ /* Set NBYTES to write and reload if size > I2C_MAX_BYTES and generate RESTART */2 ~9 ]2 ?" \) g. G2 @: p /* Size > I2C_MAX_BYTES, need to set RELOAD bit */9 x3 A. ^( C( p% _ if (Size > I2C_MAX_BYTES)8 \1 Q* N) G j) v, V% D/ W% { {2 K& p Y9 S1 l& e, w# y) n I2C_TransferConfig(DevAddress, I2C_MAX_BYTES, I2C_CR2_RELOAD, I2C_GENERATE_START_WRITE);' N& u2 h( D# m) F% A8 \ sizetmp = I2C_MAX_BYTES;8 D8 X* u3 M- [ } else8 J/ ]) r1 `9 s% S6 y3 q4 g { I2C_TransferConfig(DevAddress, Size, I2C_CR2_AUTOEND, I2C_GENERATE_START_WRITE); sizetmp = Size;% R% f0 L; T% e- Q- x5 r }) W8 O# j' }& g$ f, y" x while (!__HAL_I2C_GET_FLAG(I2C_ISR_TXIS))! f& D' D6 K, l5 L/ b5 i {( H+ z- L" @1 A6 i6 K @ } Q i! T3 {0 B# d. w I2C_CHANNEL->TXDR = eerom_start_address;! j: L7 Y' Q7 i4 I8 u while ((Size - 1) > 0) { /* Wait until TXIS flag is set */; W7 n! |# _, r9 z while (!__HAL_I2C_GET_FLAG(I2C_ISR_TXIS))- T. Z2 ~0 P9 y( w" S2 ^ {, q0 h0 H1 o! N w/ m1 }1 [ } /* Write data to TXDR */ I2C_CHANNEL->TXDR = (uint32_t)*pData;& U- y b8 C% J& U4 I pData++; sizetmp--; Size--; if ((sizetmp == 0) && (Size != 0)) {2 R9 A% y+ i0 s6 y8 \ /* Wait until TXE flag is set */4 s I4 z8 ~5 g! y7 @2 g; U while (!__HAL_I2C_GET_FLAG(I2C_ISR_TCR))) X( X2 i' T3 W! i$ n7 h* v {2 I) K% y& F" R7 y z/ V; U } } if (Size > I2C_MAX_BYTES): j1 v4 Y+ ^8 n- D {+ Y: \ B6 n# m( S9 y2 g: i2 t I2C_TransferConfig(DevAddress, I2C_MAX_BYTES, I2C_CR2_RELOAD, I2C_NO_STARTSTOP);! `/ P2 i: ^ N. a/ V5 K) _$ e sizetmp = I2C_MAX_BYTES; }* Z, L6 a# _# m7 Q1 ` else {: ?/ A7 B; ^- _3 F- G- U I2C_TransferConfig(DevAddress, Size, I2C_CR2_AUTOEND, I2C_NO_STARTSTOP);% q6 ?2 r6 U Z; K1 ] @; q- ` sizetmp = Size; } } }) c6 |1 N3 x% ?5 ~% s6 J /* No need to Check TC flag, with AUTOEND mode the stop is automatically generated */6 C: U0 J0 \0 D' U3 ? /* Wait until STOPF flag is set */ while (!__HAL_I2C_GET_FLAG(I2C_ISR_STOPF))9 B" t6 }! {, P5 ?# W, j/ P3 i7 s { }5 k3 Y. w( x# D2 t: T 0 _& y3 [, C, m& _ /* Clear STOP Flag */ __HAL_I2C_CLEAR_FLAG(I2C_ISR_STOPF); $ e( I: H" @' L; D0 }* g /* Clear Configuration Register 2 */ __HAL_I2C_RESET_CR2(); } void( @, B3 C; i2 N I2C_Master_Receive(uint8_t DevAddress,; ?& {3 B& s: q5 k uint8_t eerom_start_address, uint8_t * pData, uint16_t Size )) i3 |% {3 s/ c. D" I) I8 g% s { uint32_t sizetmp;5 j1 e" v! e$ T& v. }+ h ! T& X! m: y1 r( r% [) v; W" a if ((pData == NULL) || (Size == 0)) { return; } while (__HAL_I2C_GET_FLAG(I2C_ISR_BUSY)). j5 ^: B+ l2 _' n2 X {2 N1 k8 O) \/ E$ v* b, \3 J }1 E5 f9 P6 P+ {; {* g - x& k( p6 {* D0 e- h A /* Send Slave Address */3 u& q; k+ `) b /* Set NBYTES to write and reload if size > I2C_MAX_BYTES and generate RESTART */ /* Size > I2C_MAX_BYTES, need to set RELOAD bit */: k1 H; x* x5 Y I2C_TransferConfig(DevAddress, 1, I2C_CR2_AUTOEND, I2C_GENERATE_START_WRITE); . T" b" f0 L) T# k% y while (!__HAL_I2C_GET_FLAG(I2C_ISR_TXIS))8 p" R* u" v O {; e' q: V" x( c8 |( s0 E }# l# U8 x# ]4 b& J( o9 _8 m3 u I2C_CHANNEL->TXDR = eerom_start_address;( l- `# c: N' d/ B1 X if (Size > I2C_MAX_BYTES) { I2C_TransferConfig(DevAddress, I2C_MAX_BYTES, I2C_CR2_RELOAD, I2C_GENERATE_START_READ); sizetmp = I2C_MAX_BYTES;& v2 s& }9 u& [; o; j } else1 J; V! R& t1 c% ^1 X3 m T { I2C_TransferConfig(DevAddress, Size, I2C_CR2_AUTOEND, I2C_GENERATE_START_READ);1 o h5 a. _3 o& s sizetmp = Size; } 3 C* k. z. I' G* K4 b: Q% X while (Size > 0) {# J# e/ h' e: E) ^- y }6 l8 G" H /* Wait until RXNE flag is set */% @$ z( z3 i) m/ b4 Y, I( y while (!__HAL_I2C_GET_FLAG(I2C_ISR_RXNE))1 y6 k( \9 Y' w6 a, ?# ` {8 }: f$ x* }) }! \ }$ y2 }9 ]5 I$ u9 _+ g5 Q+ ^ /* Write data to RXDR */# w8 W5 b* B# k$ d/ L0 m# p: a* U( C *pData = (uint8_t)I2C_CHANNEL->RXDR;* V+ E0 k. q' o6 a; ~ pData++;* Q0 f2 ^3 {8 K/ I sizetmp--; Size--; if ((sizetmp == 0) && (Size != 0)). Z7 v. S4 I9 L- u7 L0 X { x) R7 _" x7 R /* Wait until TCR flag is set */ while (!__HAL_I2C_GET_FLAG(I2C_ISR_TCR)) { } if (Size > I2C_MAX_BYTES) { I2C_TransferConfig(DevAddress, I2C_MAX_BYTES, I2C_CR2_RELOAD, I2C_NO_STARTSTOP);' W+ B5 `7 a# C$ q/ P sizetmp = I2C_MAX_BYTES;6 D6 x5 t4 w6 V( ]: L& C } else {! D/ b$ v! ?4 f- R I2C_TransferConfig(DevAddress, Size, I2C_CR2_AUTOEND, I2C_NO_STARTSTOP);) P( L) U R- y! ~1 } sizetmp = Size;8 w; _$ z3 p3 v7 @ } }7 N: p" m# x( C. T2 z" } }' j: \) D1 J5 Z) A' I7 b* H9 f /* No need to Check TC flag, with AUTOEND mode the stop is automatically generated */ b1 I5 z! E# f% q1 ]$ e$ ^/ g /* Wait until STOPF flag is set */ while (!__HAL_I2C_GET_FLAG(I2C_ISR_STOPF))% a, F/ _2 Z2 A& Z {) ^; [% K+ L& a3 R! l+ ^ }2 t: t" d, H: @6 r /* Clear STOP Flag */( M8 n2 o9 A8 N __HAL_I2C_CLEAR_FLAG(I2C_ISR_STOPF); /* Clear Configuration Register 2 */ __HAL_I2C_RESET_CR2(); } |
GPIO_I2CSCLInitial(void)2 H6 c2 G9 n3 T
{4 A5 l4 D& e6 o+ s/ [# ]
/* Enable the peripheral clock of GPIOB */
RCC->IOPENR |= RCC_IOPENR_I2CEN;
I2C_PORT->PUPDR = (I2C_PORT->PUPDR & ~GPIO_PUPDR_PUPD_SCL); /* (1) */
I2C_PORT->OTYPER |= GPIO_OTYPER_OT_SCL; /* (2) */5 f& ~5 I/ b0 J/ z- ` p
#if (I2C_SCL_PIN < AFR_MAX_PINNUMBER): m- ]$ M+ G2 x: B5 V6 s# w
I2C_PORT->AFR[0] |= (SCL_ALTERNATE_NUMBER << (I2C_SCL_PIN * 4)); /* (5) */
#else" D. Y0 k/ r( q# \
I2C_PORT->AFR[1] |= (SCL_ALTERNATE_NUMBER << ((I2C_SCL_PIN - AFR_MAX_PINNUMBER) * 4)); /* (5) */4 B/ b; U5 ]' l2 m
}/ L8 ~1 l$ X; v5 W7 a( y; B
#endif+ N* P e/ I7 l8 S$ Q
I2C_PORT->MODER = (I2C_PORT->MODER & ~GPIO_MODER_MODE_SCL) | GPIO_MODER_MODE_SCL_1;$ _# @* P, g4 K4 r; y) _6 Z7 W8 Z
GPIO_I2CSDAInitial(void)
{1 ^* n0 B+ @, \. e
/* (1) PU for I2C signals */
/* (2) open drain for I2C signals */9 J% e7 {/ c9 D/ O- |" k# A3 v. O/ Q
/* (3) AF1 for I2C signals */9 h3 `/ _ x! q" G) d0 D( A
/* (4) Select AF mode on PB and PB */
I2C_PORT->PUPDR = (I2C_PORT->PUPDR & ~GPIO_PUPDR_PUPD_SDA); /* (1) */
I2C_PORT->OTYPER |= GPIO_OTYPER_OT_SDA; /* (2) */: X4 o7 R: c$ a5 c9 v
#if (I2C_SDA_PIN < AFR_MAX_PINNUMBER)
{2 `* l3 N) i4 G$ {" U O
I2C_PORT->AFR[0] |= (SDA_ALTERNATE_NUMBER << (I2C_SDA_PIN * 4)); /* (5) */" w$ s( R% }0 t2 [
#else
{6 T( m! o; s! a3 t! Z
I2C_PORT->AFR[1] |= (SDA_ALTERNATE_NUMBER << ((I2C_SDA_PIN - AFR_MAX_PINNUMBER) * 4)); /* (5) */
#endif
I2C_PORT->MODER = (I2C_PORT->MODER & ~GPIO_MODER_MODE_SDA) | GPIO_MODER_MODE_SDA_1; /* (4) */
