stm32 dac驱动
stary666 发布时间:2015-4-8 13:45
void: G2 ]; Q% S( J: E' ?
DAC_Init(void)- A. ~( c9 r0 `, E7 k& a: F8 C
! N3 u. p+ O9 v* O! ~: B( y5 ]" \    /* (1) Enable the peripheral clock of GPIOA */
/ q2 v1 W$ ]  ^* F; r( x    /* (2) Select analog mode for PA4 (reset value) */
8 q) c: M0 s4 r8 x9 s0 ?    GPIOPinInitial(ZITON_COMM_TX_PORT," Q% N7 t9 [% K  {" V5 ]
                   ZITON_COMM_TX_PIN_NUMBER,& e) p$ I) b- @, C9 p
                   GPIO_MOD_ANALOG_FUNCTION,# \' Z3 g6 u; W; J
                   GPIO_NOPUPD);
  `1 C' G: W+ H% V! _7 X    /* (1) Enable the peripheral clock of the DAC */* R: j% m% z& C3 L& X7 _+ j+ b
    /* (2) Enable the DAC ch1 */
1 R* ]/ `% q( R6 ?3 T5 U  p/ B* [9 m    /* (3) disable the DAC ch1 */9 T5 D7 _! o& O9 B; c- e) a. c
    RCC->APB1ENR |= RCC_APB1ENR_DACEN;          /* (1) */; @, _3 k) r$ j' z- ~; }% ?
    DAC->CR      |=  DAC_CR_EN1 | DAC_CR_BOFF1; /* (2) */
, N/ I0 d) {: o. K' c9 O0 M1 \    #if 0' W0 W5 h3 z) N- J
    DAC->CR      &=  ~DAC_CR_EN1;               /* (3) */
9 H$ Y& N( u9 {# a/ F7 n    #endif' g: i. h1 J; ?4 e' J
赞 收藏 评论2 发布时间:2015-4-8 13:45
kqh1120 回答时间:2015-4-8 19:22:01
wyxy163@126.com 回答时间:2015-4-8 20:25:09
