stm32l053的comparator驱动及中断
stary666 发布时间:2015-4-9 15:57
uint16_t
+ C0 `0 g4 D; J$ g$ iComparatorInitial(void)# i' h( q; D1 y2 j! D! i4 O
{1 @# ^. }8 I% z8 T; e
    uint32_t u32_StsCheckimeOut;# C8 y% o2 {4 w( j" e  y
+ y* a0 l& S: m: R  T/ U    GPIOPinInitial(LOOP_POSITIVE_ISOLLATED_MONITOR_PORT, LOOP_POSITIVE_ISOLLATED_MONITOR_PIN_NUMBER, GPIO_MOD_ANALOG_FUNCTION, GPIO_NOPUPD);& T% u- g3 v5 F/ y) Q1 b+ O
" D) l4 v+ G' v1 U4 W$ s    /* Enable the VREFINT by setting EN_VREFINT bit in the CFGR3 register */& U6 @0 M! E+ z' _! P& T
    RCC->APB2ENR      |= (RCC_APB2ENR_SYSCFGEN);
5 b7 u# v! Q: l    SYSCFG->CFGR3     |= SYSCFG_CFGR3_EN_BGAP;
! ?/ e, E8 `+ j+ _# X    /* Enable the Buffer for the COMP by setting EN_VREFINT bit and the ENBUFLP_VREFINT_COMP in the CFGR3 register */; U+ W0 p1 b* Q
    SYSCFG->CFGR3     |= (SYSCFG_CFGR3_ENBUFLP_BGAP_COMP | SYSCFG_CFGR3_EN_BGAP);
, `, T6 ~: W8 r2 v* {( S6 i  M// CLEAR CSR
6 e, e- T! ~. t0 {7 Y  L# T: M    COMP2->CSR         =  0;
  U! k( D( o8 T$ Z/ |    COMP2->CSR        |= (COMP_CSR_COMP2INPSEL_PA3);3 Z2 g  a2 q! |6 r9 A% S8 ~
    #if ((LOOP_POSITIVE_ISOLLATED_MONITOR_PORT == GPIO_A) && (LOOP_POSITIVE_ISOLLATED_MONITOR_PIN_NUMBER == 3))
! f1 n. F- z9 Q" a, z& d) w5 o' y* b    COMP2->CSR        |= (COMP_CSR_COMP2INPSEL_PA3 | COMP_CSR_COMP2INNSEL_VREFINT_3_DIV_4);# [) u( ~' Q+ D0 c3 Z+ x/ |
    #elif ((LOOP_POSITIVE_ISOLLATED_MONITOR_PORT == GPIO_B) && (LOOP_POSITIVE_ISOLLATED_MONITOR_PIN_NUMBER == 4))/ p( b& }# ^% @8 _+ F
    COMP2->CSR        |= (COMP_CSR_COMP2INPSEL_PB4 | COMP_CSR_COMP2INNSEL_VREFINT_DIV4);# K2 A( d, D8 L
    #else
! @, y- U  ]. [; _+ L7 ^    COMP2->CSR        |= (COMP_CSR_COMP2INPSEL_PA3 | COMP_CSR_COMP2INNSEL_VREFINT_3_DIV_4);& {# R& B" x! y/ i/ j) E) E" B5 U
    #endif7 D. @4 k9 a0 e7 B& d, t
    COMP2->CSR        |= COMP_CSR_COMP2SPEED;7 B9 A; e* i% Y9 k$ |& _2 i
    COMP2->CSR        &=  (~COMP_CSR_COMPxEN);9 `4 x+ i/ Q) A: T% M1 E$ n$ I. E
    EXTI->FTSR        |= COMP_EXTI_LINE_COMP2_EVENT;/ f6 ~3 f! |6 g8 f1 f
    EXTI->RTSR        |= COMP_EXTI_LINE_COMP2_EVENT;
- H; A6 b# x- `    EXTI->IMR         |= COMP_EXTI_LINE_COMP2_EVENT;0 e. j4 x5 }1 r( r
    EXTI->PR          |= COMP_EXTI_LINE_COMP2_EVENT;) B# `0 j$ |+ ~# d6 a7 M$ f
    // VREFINT Check
. w! ?+ \4 P/ ~    /* VREFINT reference for ADC enable bit*/; _1 S1 @3 q7 t9 h9 L' Y0 m
    SYSCFG->CFGR3     |= (SYSCFG_CFGR3_ENBUF_BGAP_ADC);1 f8 C& F( _4 @# G6 n
    u32_StsCheckimeOut = GET_SYSTEM_TICK_VALUE();. H$ u# ?9 K, Q/ w$ _
& J4 F5 x% U5 U9 c6 P: ~. V
    while (RESET == (SYSCFG->CFGR3  &= (~SYSCFG_VREFINT_ADC_RDYF)))
1 |3 n& z' j$ z  F  H1 C) s    {3 [& ^" ]8 C  K* r) I
        if (GET_SYSTEM_TICK_ECLIPSE(u32_StsCheckimeOut) > CHECK_STATUS_TIMEROUT_TICK)
0 Q0 h& R/ x' F0 d" X/ u        {
- ?0 ~* t) ^1 O            return ERROR;
" j- K1 v' Q0 I# T; t/ S3 l, |        }
7 \9 R; a0 A9 [; |7 [    }
% e7 G9 t  e" g
% Q% B8 w4 d2 n% B    while (RESET == (SYSCFG->CFGR3  &= (~SYSCFG_CFGR3_VREFINT_COMP_RDYF)))* q/ r4 E8 ?4 z6 b* r* @
    {: Y( z$ b% o% ]  A/ p, J! l! Z
: Y7 u6 q; z+ Y3 H. e, N' ]) o        {8 ?% i5 g5 E; d& g2 b- W
            return ERROR;( V6 R" T5 G0 e2 K
6 T/ R1 A8 p( W. z' d& ]  x' x9 m    }  F/ ~1 s2 `( N7 X
$ `) Z2 G  {" ~" f1 e5 S    /*Configure the NVIC for COMP2 */
  @0 \1 y4 W# T! c; u- O    NVIC_SetPriority(ADC1_COMP_IRQn, INTERRUPT_PRIORITY_COMPARATOR);, n; I& z1 e, [8 s  [* T) o
    NVIC_EnableIRQ(ADC1_COMP_IRQn);
3 y1 Z' m" p% S$ Z; k! _    return SUCCESS;
& a4 M1 ^% Z* I2 M# S. b}3 D' w- r" r3 U- k# _
* A! A$ ?) H# q4 B3 J  s' ?) q" u9 x
void8 P/ J% r, b; Z
ComparatorConfig(FlagStatus enum_SetReset)- A9 H6 F# V2 H( E6 k
{* x/ r7 ]  A( d# ~7 {; l* F5 y
    if (enum_SetReset == RESET)
3 j0 Z6 q; Z, ?+ y' ~8 Z$ K    {: o) l5 O1 f6 v/ x; [
        COMP2->CSR &=  (~COMP_CSR_COMPxEN);& O0 i, e. O* y/ [/ H2 o) N- x4 i
4 E8 h( Y  q9 X( v' y    else5 K' q( {- J0 ?, L
5 d) V/ W  W$ k7 E  k% y! @        COMP2->CSR |=  COMP_CSR_COMPxEN;; D) Y3 z9 c( G+ @
! a$ p  S0 T* u- }}
$ M; ]/ b# _- _8 y! M. P/ P( F; I) v
赞 收藏 评论1 发布时间:2015-4-9 15:57
moyanming2013 回答时间:2015-4-9 21:25:54
然后呢( X, O5 A" b- X; }" ?
